New Tundra: need opinions
Discussion in '1st Gen Tundras (2000-2006)' started by NWCTfirstGen, Sep 9, 2024.
  1. Oct 12, 2024 at 4:45 AM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I should've mentioned that white dot for the crank and the actual T timing marks
    however, at TDC, the cam pulley marks should aline with the mark just to the left of the T as mine are in the pictures in my previous post
    Either method confirms you are properly aligned
    here's pictures of mine when I advanced the crank from TDC to the white dot
    and as I told the OP, I had already rotated the crank twice just as he had done so my marks on the timing belt are no longer at the timing marks on the truck. And it would take hundreds of turns before The belt matches up again.
    if you turn the crank and follow the marks on the belt you will see it takes several more turns for the belt to make a full pass
    shifty`[QUOTED] likes this.
  2. Oct 12, 2024 at 6:33 AM
    NWCTfirstGen
    NWCTfirstGen [OP] New Member
    2002 SR5 V6 3.4L AC manual 4WD
    Thanks Weagle. That makes me feel so much better. For the life of me, I couldn’t figure out what was going on and I was so worried I destroy the engine. I guess I’m just gonna test everything again. Your pictures are really helpful.
    Weagle and KNABORES like this.
  3. Oct 12, 2024 at 8:26 AM
    Weagle
    Prattville, AL
    Glad it helped. trust me I am quite familiar with the angst of something going wrong or potentially going wrong
  4. Oct 12, 2024 at 8:39 AM
    NWCTfirstGen
    Did a few more 2x rotations and marks look good. Annoying that the lines on the timing belt move. Think I’m good now thanks to your helpIMG_5811.jpg IMG_5812.jpg IMG_5813.jpg IMG_5814.jpg
  5. Oct 12, 2024 at 8:52 AM
    I'm guessing that's supposed to say now... :D
    G_unit3000, Weagle and shifty` like this.
  6. Oct 12, 2024 at 9:12 AM
    I had to read twice also ;)
    G_unit3000 and Weagle like this.
  7. Oct 12, 2024 at 9:17 AM
    Weagle
    Prattville, AL
  8. Oct 12, 2024 at 9:18 AM
    Weagle
    Prattville, AL
    Your timing marks are very different from mine. But I believe you said you turned it over manually twice, so there is no contact and I believe you are good to go
    Be sure you route the crank sensor wire behind the radiator fan bracket before you bolt it down.
    it should be behind that bracket but outside of the timing belt area. it will be outside of the timing belt cover once that is installed and thereby protected from the timing belt and then protected from the serpentine belt, etc. when it's routed behind the fan bracket
    G_unit3000 and shifty` like this.
  9. Oct 12, 2024 at 9:32 AM
    G_unit3000 likes this.
  10. Oct 12, 2024 at 9:38 AM
    Weagle
    Prattville, AL
    if they get my eye straightened out, I'm going to try to type up written step-by-step instructions that match up with the AA Auto videos. Not extremely detailed, but just what order for the disassembly and reassembly of components and what bolts or nuts
    One thing he did not do was specifically point out that sensor wire should be behind the bracket when you install it he just said to make sure it's not bound or caught by the bracket and the video is not very close up for you to observe him routing it
    The video is great to watch first. Then to refer to when it gets a little confusing. But for me when I actually get ready to do it I want written step-by-step instructions. And include a few gotchas and warnings based on me doing it fully or partially 4 or 5 times in the last two months haha
    ps i'm about to wrap up. That AC compressor is a bitch. And I didn't even totally remove it. That little screw on the compressor that has the ground wire for the AC is also a PITA
    shifty`[QUOTED] and G_unit3000 like this.
  11. Oct 12, 2024 at 1:25 PM
    they should be, OP is rocking the 6’er
    Weagle[QUOTED] and shifty` like this.
  12. Oct 12, 2024 at 1:45 PM
    NWCTfirstGen
    One missing letter and it looks like an insult. Yes I meant to say all good now.
    KNABORES[QUOTED] likes this.
  13. Oct 12, 2024 at 1:48 PM
    NWCTfirstGen
    Thanks. I believe I routed it correctly. At first I was not behind the bracket because there is a little divot there that made me think the wire followed that path and I thought I would pinch the wire with the bracket. But a close inspection shows a space behind the bracket for the wire. I am rocking the V6
    Weagle[QUOTED] and KNABORES like this.
  14. Oct 12, 2024 at 2:27 PM
    Manual V6 4wd is dope. Like a more modern and capable T100.
  15. Oct 12, 2024 at 4:17 PM
    Weagle
    Prattville, AL
    I didn't realize you had a six cylinder. So yours may be different.
