New Tundra! And R20 TRD Wheel Tire question
Discussion in '3rd Gen Tundras (2022+)' started by Taikowaza, Aug 5, 2022.
  1. Aug 14, 2022 at 6:00 PM
    Taikowaza
    Taikowaza [OP] New Member
    Thanks SB95! The appearance of your truck's stance and tires is really, really good. I think that 285/65R20 is probably one of the most perfect with zero rub or adjustment necessary even with mudflaps. 295/65R20 is sweet but apparently requires some modifications for some. Same with 35X12.5R20. I am going to compare 35X11.5R20 along w/your tire size, and I still kind of like the 295/60R20, but it has a bit more of a 'street racer" look to me compared with your 285/65, which is clean, mean, off-road machine. Awesome! And thanks for your spacer info, is that for both front and back? And lol re: your wife's thoughts on your Lunar Rock! Take my word for it, yours is awesome (I think that both our "greens" in our 3rd gen models are fantastic! :)
  2. Aug 14, 2022 at 6:03 PM
    SkiBum95
    SkiBum95 New Member
    ‘24 Tundra TRD Pro
    Tonneau cover 35” Toyo tires Tint
    I only needed a spacer on the front. I initially asked for a 1” on the back but they said it didn’t need one. I may have them do one later just so I don’t look backwards when towing.
    Taikowaza[OP] likes this.
  3. Aug 14, 2022 at 6:05 PM
    Taikowaza
    First purchase after buying my Tundra was the Talon's Garage Catalytic Converter Shield. It is awesome and I received it really quickly. Install was straightforward even under the truck with tires on, holding everything up with my knees! I couldn't get the last passenger seat second from the front bolt to thread properly. I have just ordered the front (white) TRD Pro skidplate and will reattempt to install the Talon along w/front skid bolts once that arrives.
  4. Aug 14, 2022 at 6:07 PM
    SkiBum95
    SkiBum95 New Member
    ‘24 Tundra TRD Pro
    One more thing. I think the TRD Sport has a slightly lower front stance (-1/2”) than the Offroad so you may only need a 2” level. I’d just take it to a quality shop to see.
  5. Aug 14, 2022 at 6:11 PM
    Taikowaza
    Another factor with the tire install is that I only have 6.5" of clearance left in my garage! So I need to be careful as I do intend to continue to park inside!
  6. Aug 14, 2022 at 6:16 PM
    Taikowaza
    The black exhaust tip was a super easy install and I am really happy with the appearance.
  7. Aug 14, 2022 at 6:21 PM
    Taikowaza
    The emblem overlay was also incredibly easy to install and made a huge difference in the appearance. Along with the black exhaust tip and the TUNDRA lettering on the tailgate, it gave the truck a "night" appearance (except for the mustache, rear tailgate panels, door handles, tailgate latch and window trim lol :) But I like the contrast and no longer plan to try to color match everything. I'm embracing the differences of the Limited, she is totally awesome.
    IMG_5456.jpg IMG_5457.jpg IMG_5458.jpg IMG_5460.jpg IMG_5462.jpg IMG_5474.jpg IMG_5470.jpg IMG_5473.jpg IMG_5472.jpg IMG_5467.jpg IMG_5463.jpg IMG_5465.jpg IMG_5466.jpg IMG_5461.jpg IMG_5464.jpg
    matgor, Yaboy, LukeS and 1 other person like this.
  8. Aug 14, 2022 at 6:29 PM
    Taikowaza
    At first I thought I wanted to change the front grille for the TRD Pro "heritage" grille. But now with the Red Decal in the TRD location I think the appearance of the Limited TRD offRoad is awesome.
    TundraDan723 likes this.
  9. Aug 14, 2022 at 8:31 PM
    Taikowaza
    I made this chart for my research comparing Toyo with Falken, Nitto and BFG. My main criteria was that they be 3 snowflake certified, and in the sizes 35X11.5R20, 285/65R20, or 295/60R20. This was mainly because I need great snow traction, and I want the tires to fit w/o a lift or spacers etc. I could argue that 295/65/20 would fit no problem, but I want to stay sub-35". Any errors in this chart are my own.
    TundraDan723, Bigphilski and H20-bar like this.
  10. Aug 14, 2022 at 8:52 PM
    Taikowaza
  11. Sep 7, 2022 at 12:19 PM
    ELiDirtTundra
    ELiDirtTundra New Member
    WA
    2022 Tundra Limited
    Which tires did you go with?
  12. Sep 11, 2022 at 5:28 AM
    Taikowaza
    Hi ELiDirtTundra! Thanks for your post and your question! Tires and lift have been the hardest decision for me with my truck. I went with the 285/65R20 Falken Wildpeaks and sent them back, from my research it seems like that size Falken are made in the PRC.
    Just based on the numbers I really want to go with a Toyo 285/65R20. Less tire weight, better speed and weight ratings. They have been really difficult for me to find. The only other tire I'd go with is the Toyo 35X11.5R20 but they weigh (a lot) more and have less speed and weight rating. Is there any other advantage to the inch-flotation rating over metric, do they look a lot better?
    I have decided to pair the Toyos (either 285/65R20 or 35X11.5R20) with the black anodized Westcott 3/1 lift. Re: the Westcott, there too I'm stating to doubt myself (probably reading too many reviews!). I am not sure whether I should continue w/the Westcott plan, or go with changing the shocks to Bilstein (I have been happy w/the 5100s on my Sequoia).
    I had thought that going w/the TRD offroad setup meant I didn't have to change shocks, don't we have Bilsteins already? (Let me guess, the red shock bodies aren't as good as the 5100s perhaps...) The OEM Toyota lift and the other "big boy" lifts (Icon etc) are a major investment and I don't think I require that much, I do want the ride to be really good however.
    Bottom line is that, right now I'm going w/the Westcott 3/1 and Toyo (either of the two listed above). I'm not sure (if I stick w/the Wescott) whether I'll do the full 3/1, or remove the shim on the front and go 2/1, or even 2/0. I'm looking for a subtle and BA lift nothing too high or extravagant. I would be grateful for any thoughts or advice re: any of the above. Thanks again ELiDirtTundra!
  13. Sep 20, 2022 at 8:50 PM
    ELiDirtTundra
    WA
    2022 Tundra Limited
    Hello Taikowaza thanks for the reply. Toyos are nice! And there are a lot of Westcott 3/1 set ups around the forum, youtube, facebook and there seems to be more of a hit instead of a miss. I do have Westcott’s leveling kit but I would wait until I get new tires put in and see how I like the stance before I decide to have it installed. I’ve decided to go with Nitto Recon Grappler 275/65R20 116H as I wanted to stay under E rated tires.
    The OEM lift kit are above my budget for the parts and to have it installed, so will stick with either leveling kit or the 3/1 set up.
    The spare tire is 265/70R18 Michelin LTX Trail, are you planning of replacing that as well? If not, are you going to remove it so as not to carry a dead weight or leave it as is? I’m planning of taking it out but I don’t know how the back will handle because of weight distribution.
  14. Sep 25, 2022 at 12:02 PM
    alex17117
    alex17117 New Member
    Alex
    2024 limited, Lunar Rock
    I have the same truck on the way. What tires did the trd sport come with?
  15. Sep 26, 2022 at 6:42 AM
    JBASS2
    JBASS2 New Member
    My TRD sport came with bridgestone duelhers. Some come with a yokohamoa geolander, but they look like street tires.
  16. Sep 26, 2022 at 7:14 AM
    alex17117
    Alex
    Great, thanks a ton. I may keep my Falken Wildpeaks in that case :)
  17. Sep 26, 2022 at 6:19 PM
    knewcomb
    knewcomb New Member
    Mine came with the Geolanders.
    Jongie123 and alex17117 like this.
  18. Dec 28, 2022 at 5:36 AM
    GutPunch
    GutPunch New Member
    Idaho
    2023 Tundra 1794 4x4 OR MBM
    OEM Tonneau Cover TRD Running Boards
    Hey! Wanted to see how your experience has been since your last post here? Do you think the lift was necessary for either the 35x11.5R20 or the 285/65R20 Toyos? Love to not have to lift the truck so it still fits in the garage.
    Would you change your decision based on the last couple of months?
  19. Dec 28, 2022 at 8:39 AM
    #49
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    My Canadian Limited TRD Offroad came with 265/70/R18 wheels and Michelin Trail tires. I have ordered some Toyo AT3 295/60/R20 tires and Flow Formed Fast Wheels, Should be here this week. I also ordered a 1.75" RC levelling kit. I am hoping my long truck looks a bit shorter :).
    I really like the red strip on the steering wheel and the red shifter.
  20. Jan 8, 2023 at 5:59 AM
    #50
    4DIMAD
    4DIMAD New Member
    Are they rubbing without spacer?
  21. Jan 8, 2023 at 7:39 PM
    #51
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    I bought Toyo OC 285/65/20 at Town Fire Tire. Guys in NH gave me a great price at $1500 out the door and no state tax. Had my dealer install when I picked up my truck. Also installed RC level and Borla spacers at the same time.
    socaldad likes this.
  22. Jan 8, 2023 at 9:03 PM
    #52
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    Love the discussion on tire size. I'm giving serious consideration to 285/65/20. Now the only question is which tires?
    Wildpeak AT3 are OEM on some Tundra models, so it's at least not going to be a problem on 3rd gen Tundras. My 1794 came with Wildpeak AT3-a, that's the off road/highway combo looking tire. It has the advantage of having a nice straight grove either side of center which is good for shedding water in the rain. From what I've read, the more blocky the tire is, read lack of that left and right straight groove, the more easily it will hydroplane because it can't shed the water easily.
    So....with looks aside, what do y'all think are good wet traction yet better off road than the rather crappy Wildpeak AT3-a tires? Oh, those AT3-a have a pretty low load rating at 2450 pounds (I recall), which is at max pressure of 51 pounds and the Tundra door sticker says to normally run at 35 pounds, so these tires are really stressed under heavy towing load at 35psi. I think they should be aired up to 45 or so for heavy towing to avoid exceeding their load capability. The larger 285/65/20 of just about any tire will take care of that problem.
    Thoughts?
  23. Jan 12, 2023 at 3:14 AM
    #53
    Reihengti
    Reihengti New Member
    South Jersey
    22 tundra limited or mgm
    I installed everything at the same time so im not sure if they would rub or not.
  24. Jan 12, 2023 at 5:11 AM
    #54
    Yota802
    Yota802 New Member
    I’ve been a long term BFG guy but switch to Toyo OC 285/65/20. So far I’m really liking them. Relatively quiet and look good, slightly more street look IMO versus an off-road-mud tire.The BFG is slightly more aggressive looking IMO but the Toyo look good. The biggest negative I’ve had over the years with BFG was the road noise around 45-50k, they are loud. Basically, the last year on former trucks would be louder. The BFG did ride a little rough too but, so did the Gen 2 trucks. I did run a higher PSI 45-50 which probably contributed to great ware. Generally, I would get 69-65k out of the tires, then sell while still inspectable.
    With all that said would I buy BFG again, 100% Yes.
    Long term verdict on Toyo, we’ll see…
  25. Sep 10, 2023 at 8:57 AM
    #55
    Bobohood
    Bobohood New Member
    Lunar Rock 2023 limited 4x4
  26. Sep 10, 2023 at 8:58 AM
    #56
    Bobohood
    Bobohood New Member
    On your stock tundra, did you add a level kit in front to get those Nittos on?
  27. Sep 10, 2023 at 9:29 AM
    #57
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    That tire size will fit these trucks just fine without a level or spacers
  28. Nov 18, 2023 at 6:22 PM
    #58
    kleangpun88
    kleangpun88 New Member
    2022 Tundra TRD Sport
    You didn't need any spacers or anything?
  29. Nov 20, 2023 at 9:06 PM
    #59
    SkiBum95
    SkiBum95 New Member
    ‘24 Tundra TRD Pro
    No spacers. The tires are not 12.5 wide…closer to 11.5”.
  30. Nov 20, 2023 at 9:12 PM
    #60
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    these 2 sizes sound more assuring in terms of proper fitment.
