New to me 1st Gen Tundra - What to look for/change out due to mileage/age
Discussion in '1st Gen Tundras (2000-2006)' started by SouthPaw, Sep 12, 2019.
  1. Sep 14, 2019 at 9:08 PM
    SouthPaw
    SouthPaw [OP] The headlight guy
    2000 Limited 4x4 AC
    I’m thinking the same thing. I picked a can of MAF sensor cleaner and throttle body cleaner tonight.
    speedtre likes this.
  2. Sep 15, 2019 at 1:05 AM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    If it does it again after you clean the maf sensor,then I would replace it.I know this may sound strange but fill the tank with gas and then pour an entire quart of dexron 2 or 3 transmission fluid in the tank.it will clean the injectors better then anything and the entire fuel system.I would also run a can of seafoam through the intake and valves.take the brake booster vacuum line loose while the engine is running and slowly pour in 3/4 of a can into the hose.pour slowly because the engine will try to stall.after it is poured in,turn off the engine and let it sit for 10 minutes.be sure it is sitting level and in a well ventilated area because when you start the engine,it will smoke awful.that is ok.it It is burning off the build up.I promise it will run smoother and much better.I do this in all my vehicles.
    Sangre Kid and speedtre like this.
  3. Sep 15, 2019 at 6:18 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    When you do the drums stay away from the centric kit from RA. I had a shoe crack on me before install, and it was missing parts.
    MS22 likes this.
  4. Sep 15, 2019 at 7:15 PM
    SouthPaw
    2000 Limited 4x4 AC
    I ran a can of seafoam through the tank and the next one will be through the intake. I’ve done it on other vehicles and yes, it smokes like crazy lol.
  5. Sep 15, 2019 at 7:16 PM
    SouthPaw
    2000 Limited 4x4 AC
    Thanks for the advice. I plan on doing both drums, shoes and wheel cylinders so I know it’s all new.
    I did get a quote from a guy that will bed line the whole under body for $400. Something I may look into.
