**New to Forum - Work in Progress**
Discussion in 'New Member Introductions' started by CSZer0, Dec 23, 2024.
  1. Dec 23, 2024 at 9:00 AM
    CSZer0
    CSZer0 [OP] New Member
    Cameron
    2006 Tundra Crew Cab SR5 Phantom Grey
    AISIN TKT-021 Engine Timing Belt Kit with Water Pump Rough Country 2.5" Lift Kit w/N3 Struts & Shocks TRQ Front Lower Control Arm Set KSP Upper Control Arm, 2-4”Front Control Arms MOOG Suspension Stabilizer Bar Link MEVOTECH Lower Ball Joints
    Hello everyone,
    New to the group and purhcased a 2006 Tundra, Double Cab, XSP, Phantom Grey (178K) a couple of months ago. I have already been using this forum for "how do I fix this".
    Loacted in the Tampa, FL area.
    Already upgraded/replaced the following:
    Projects in the works:
    • Door snagging and squeaking repair
    • Snugtop repair back glass - broken
      • Snugtop wiring harness for lights
    • Audio Upgrade
      • Headunit - DCPA81W 8-inch
      • Speakers & Tweeters - TBD
      • Siless 80 mil Car Sound Deadening mat within the door panels
    • Front and Backup Camera - recording
      • WOLFBOX G900 PRO Mirror Dash Cam with STARVIS 2 IMX678
    • Headlight upgrades - TBD
  2. Dec 23, 2024 at 9:31 AM
    Welcome from NY.
  3. Dec 23, 2024 at 10:14 AM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Welcome, from Texas!. Please read THIS, my man! Read it, read it again. Pin it and reference it often for anything you do. Then come join us on the FGT side :D
    First Gen Lower Ball Joint(LBJ) Failures | Toyota Tundra Forum
    shifty`[QUOTED] and FrenchToasty like this.
  4. Dec 23, 2024 at 10:59 AM
    CSZer0
    Cameron
    Looks like an OEM lower ball joint replacement is going on the project list, adding it to the TOP of the list too.
  5. Dec 23, 2024 at 5:59 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  6. Dec 23, 2024 at 6:07 PM
    shifty` We call it “riding the gravy train”
    Read that thread TBM linked up.
    You can always fix your suspension by getting that Rough Country crap out sooner than later. Other brands to avoid are in that thread along with suggestions. Also, avoid blocks out back if you plan to tow or your leaf packs are old, unless you want problems associated with axle wrap. Hopefully you don’t buy the kit that uses spacers to lift, it’ll bend your spindles. For a couple hundred more you can get a proper lift that won’t cause problems/damage.
    Also note those KSP arms, I keep seeing people posting pics on Facebook of the arms snapping clean off at the ball joint tube. They’re cheaply produced in mainland china, they get rebranded under several brands, KSP is one of them. The off-name brands on scAmazon and fleaBay are the same product, but cheaper. In general, tubular uppers outside of Total Chaos and one or two others who fab up in-house, are poor in quality. 49 out of 50 will probably be fine. But knowing my luck I’d be the 1 in 50.
    Welcome to the forum!! Not knocking, only trying to help. I know nothing sucks worse than finding out after-the-fact that you fucked up and spent hard earned cash on shit products. I don’t want to rub salt in the wound but don’t want you wrecking your truck either! I’m the type of dude who tells my friends when they’ve got a booger hanging out of their nose, instead of letting them rock it!
