New suspension 2021 dbl cab
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tob, Feb 24, 2021.
  1. Feb 24, 2021 at 5:57 AM
    Tob
    Tob [OP] New Member
    I'm considering putting bilstein 6112 and 5160 on my trd sport double cab.
    I want to lift the front a bit from stock.
    The dealership is telling me I will have issues with the tss features if I alter the ride height.
    Does anyone have experience with doing this? Did hour tss start acting up?
    Tires will be scs ray 10 w 275 70 18.
    Thanks!
  2. Feb 24, 2021 at 6:09 AM
    The dealer is full of it. Every leveled and lifted truck on here 2018 and newer has TSS. I have a Toytec setup on my 2020. I am right about 4 inches on the front and 2 inches in the rear on 34's and no issues at all.
  3. Feb 24, 2021 at 6:16 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    plenty of folks here have lifted TSS featured trucks. If you are nose high, yes could be issues. But some have also reported no problem. If you keep some rake, that is what the TSS sensor is looking for and everything can work fine. Also, the sensor can be re-calibrated by Toyota after the lift if you have a problem.
    This has been discussed many times here, bet you will find some good threads on it if you search TSS lift or similar. Here is a start-
    https://www.tundras.com/threads/tss-p-sensor-with-front-end-lift.19544/#post-2055344
    https://www.tundras.com/threads/poll-2018-tss-radar-precollision-problems.30411/
    https://www.tundras.com/threads/lifted-2020-with-tss-issues.78089/#post-1981588
    https://www.tundras.com/threads/2018-lifted-tundra-problems.27599/
    and there are more out there I am sure.
  4. Feb 24, 2021 at 6:48 AM
    DUKFVR
    DUKFVR New Member
    Houston & Young County TX
    2020 Cement Tundra DC SR5, Stage 1 Icon kit, LT75/60/20 Toyo AT III, Ranch Hand Midnight Bumper Replacement
    No issues with my leveled truck.
  5. Feb 24, 2021 at 9:03 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Great question to post here. https://www.tundras.com/forums/suspension.19/
  6. Feb 24, 2021 at 1:41 PM
    Tob
    Tob [OP] New Member
    Thanks guys!
  7. Feb 24, 2021 at 1:48 PM
    java230
    java230 New Member
    No issues.
  8. Feb 24, 2021 at 1:57 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I had more issues with the TSS before I went to a 3/1 with 285-75/18's.
