New bumper
Discussion in '3rd Gen Tundras (2022+)' started by AND, Jan 28, 2023.
  1. Feb 13, 2023 at 1:14 PM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    The bumper will not come with plate covers, Scorpion does not offer them at this time.
  2. Feb 13, 2023 at 1:23 PM
    Krusher22plat
    Krusher22plat New Member
    22plat
    Thanks for the confirmation..i may just see if i can do a few covers for those spots
  3. Feb 17, 2023 at 2:54 PM
    AND
    AND [OP] New Member
    Washington, PNW
    Installed.
    Satisfied with the product, well made.
    Winch is a Warn VR EVO 10S
    Baja Designs 20” S8 Lightbar and squadrons.
    ((((Slight modification needed to fit the Warn VR EVO)))
  4. Feb 19, 2023 at 9:49 PM
    Odithtfg747
    Odithtfg747 New Member
    2022 SR5
    Any errors flashing for the front air dam?
  5. Feb 20, 2023 at 5:32 AM
    AND
    AND [OP] New Member
    Washington, PNW
    My truck didn’t come with an air dam.
    The bumper does come with hardware and instructions on how to relocate the air dam.
    Odithtfg747 likes this.
  6. Feb 26, 2023 at 7:08 AM
    Odithtfg747
    2022 SR5
    Any chance you can share a picture of the instructions? Curious where they have you store it
  7. Feb 26, 2023 at 7:26 AM
    AND
    AND [OP] New Member
    Washington, PNW
    Yes I can send you a pic of the instructions.
    It’ll be a while tho, I’m on vacation till the 2nd week of March. @Odithtfg747
  8. Mar 17, 2023 at 10:19 PM
    AND
    AND [OP] New Member
    Washington, PNW
  9. Mar 18, 2023 at 6:07 AM
    Odithtfg747
    2022 SR5
    Thank you! Hope you had a great vacation
    AND[OP] likes this.
  10. Apr 5, 2023 at 4:20 PM
    99ways2die
    99ways2die New Member
    NJ
    2022 Tundra Platinum
  11. Apr 5, 2023 at 4:27 PM
    GoFast157
    GoFast157 New Member
  12. Sep 4, 2023 at 1:26 PM
    Oakman
    Oakman New Member
    Michigan
    Congrats, looks great. What did you do to fit the warn winch?
    AND[QUOTED][OP] likes this.
  13. Sep 4, 2023 at 1:36 PM
    AND
    AND [OP] New Member
    Washington, PNW
    Had to grind down gusset by about half 1/2inch.
    Oakman[QUOTED] likes this.
  14. Sep 4, 2023 at 1:45 PM
    Oakman
    Oakman New Member
    Michigan
    Thanks for replying, did you have to relocate the control pack (upper control part) of the Winch?
  15. Sep 4, 2023 at 1:52 PM
    AND
    AND [OP] New Member
    Washington, PNW
    No I did not, but it could easily be done if needed. Theres plenty of threaded holes and bolts near the control pack.
  16. Sep 5, 2023 at 11:31 AM
    AND
    AND [OP] New Member
    Washington, PNW
    Its on sale for $679 right now.
  17. Sep 5, 2023 at 2:09 PM
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    Do all aftermarket steel bumpers require cutting and trimming of the factory plastics?
  18. Sep 5, 2023 at 2:13 PM
    Foques
    Foques New Member
    wow.. sexy and cheaper than alternatives for cheaper Toyotas 0_0
  19. Sep 5, 2023 at 2:13 PM
    #49
    Oakman
    Oakman New Member
    Michigan
    Yes, I am not aware of any bumper that can be installed without cutting or modifying.
  20. Sep 7, 2023 at 5:33 PM
    #50
    HLR_NM
    HLR_NM New Member
    Harry
    I just ordered the Scorpion from Bumper Superstore, will be pairing with a Warn Evo 10K with synth line. I don't plan on any crazy wheeling in this truck but I have encountered some sticky, soupy mud in the forest roads around here so it's more of a back-up plan than a tool I'll be using regularly.
    I'm also hoping I don't have to upgrade my springs by keeping the weight down, fingers crossed. The truck rides AMAZING in stock form and I'm not in a hurry to update the suspension. What's been other's experience after installing the Scorpion and the weight of the winch up front?
    @AND any feedback?
    AND[OP] and 4mm like this.
  21. Sep 8, 2023 at 7:43 AM
    #51
    Oakman
    Oakman New Member
    Michigan
    Anyone can recommend a site/place to watch for warn winch offers?
  22. Sep 8, 2023 at 7:47 AM
    #52
    HLR_NM
    HLR_NM New Member
    Harry
    Warn is offering a $100 rebate through September.
    Prices seem to fluctuate a lot - I just kept watching the prices on Google until I struck.
  23. Sep 8, 2023 at 8:47 AM
    #53
    AND
    AND [OP] New Member
    Washington, PNW
    The front will go down about 1inch after bumper and winch.
  24. Sep 8, 2023 at 8:59 AM
    #54
    Oakman
    Oakman New Member
    Michigan
    interesting!! less clearance defeats the purpose of replacing the pumper, did you have to swap suspension?
  25. Sep 8, 2023 at 9:15 AM
    #55
    AND
    AND [OP] New Member
    Washington, PNW
    Yes I have Dobinsons suspension but I was planning on getting it.
    I currently have Dobinsons 2" 110-220Lb in the front and 2" 0-110Lb + rear swaybar links + Panhard/Trackbar in the rear.
    The suspension is definitely stiffer but I hate the marshmallow feeling of the stock suspension.
    EDIT..... I did run the bumper and winch without new suspension for a while with no problems.
    HLR_NM likes this.
  26. Sep 8, 2023 at 10:38 AM
    #56
    Oakman
    Oakman New Member
    Michigan
    Installing the bumper seems like opening a can of worms :)
    Thanks for the info, is the suspension job complicated or it can be performed at my own garage? did you have to add additional steps i.e computer reset, alignment and adding more parts??
    sorry to ask too many questions, I would like to know what am I up against with this installation
  27. Sep 8, 2023 at 11:01 AM
    #57
    AND
    AND [OP] New Member
    Washington, PNW
    Im happy to answer all your questions.
    I wouldnt install a bumper just for the looks, id do it only if youre planning on getting a winch, because youll be adding 160ish Lbs to the stock suspension which was not designed for that so the spring rate will have to eventually be addressed.
    I did the suspension and bumper/winch in my garage and no i didnt have to reset any computers or anything, i did remove the battery positive but just out of habit.
    RickyBobbysTundra likes this.
  28. Sep 8, 2023 at 11:07 AM
    #58
    Oakman
    Oakman New Member
    Michigan
    Thank you, That helps alot.
    AND[OP] likes this.
  29. Sep 9, 2023 at 4:48 AM
    #59
    Oakman
    Oakman New Member
    Michigan
    I researched this topic, looks like the suspension and coil spring needs to be replaced eventually as you said, it's very expensive, I went the rabbit hole to get all the details and the shock job is shocking, after installing the bumper.
  30. Sep 9, 2023 at 7:54 AM
    #60
    AND
    AND [OP] New Member
    Washington, PNW
    You gotta pay to play :burnrubber:
