NEW Bi-LED Projector Retrofits (100% Plug N Play) *2 Options Available*
Discussion in 'Lighting' started by eledobleu, Sep 24, 2017.
  1. Dec 9, 2017 at 12:41 PM
    #61
    jro05065
    jro05065 New Member
    Denver
    2017 CM Tundra TRD
    Has anyone had issues with fog on their MLED projectors lens? I have had mine installed for about two weeks and this morning I realized some fog buildup on both driver and passenger side. I don' think this is typical and wanted to see if anyone has any insight?
    bHM41DnHR6u6Yo+UqiKJ+Q.jpg D92I1fvJSqOe04lRNd149Q.jpg hKT0DJssSJ+Bag65yMjAZw.jpg
  2. Dec 9, 2017 at 3:00 PM
    #62
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    thats odd and no i wouldnt think thats the norm. i assume it burns off when they are fired up?
    in for answers as im considering these as a retrofit
  3. Dec 9, 2017 at 7:54 PM
    #63
    j2007
    j2007 New Member
    VA
    2017 DC Bronze Limited TRD
    Full Debadge, TRD Antisway, Platinum Grille, Baja Designs Squadron Sport Fogs, Morimoto MLED Headlight Retros, Tekonsha P3 Trailer Brake Controller with dash mount, Front Tint, Tyger Tonneau Cover, Anytime Fogs, FRAC, Fortin Evo One Remote Start, 12 Volt Bed Power Socket
    @eledobleu - do you have any thoughts on this projector fog issue?
  4. Dec 10, 2017 at 5:04 AM
    #64
    Stig
    Stig New Member
    I have brand new headlamps off my 17 Limited with leveling motors for sale. They'd be perfect to get that retrofit going. Let me know if interested.
  5. Dec 10, 2017 at 7:06 AM
    #65
    eledobleu
    eledobleu [OP] retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    By those being mled projectors, the rubber grommet in the back leaves a slight opening. Usually with hid the igniters can be wrapped around the grommet for a perfect seal. The mleds have nothing to use to wrap it around. Turn the lights on and let the heat remove the moisture, the y use some form of silicone around the rubber grommet center to seal
  6. Dec 10, 2017 at 9:01 AM
    #66
    jro05065
    jro05065 New Member
    Denver
    2017 CM Tundra TRD
    Why don't you do this as part of the retrofit if it is a known issue with an easy fix? The moisture in the light housing was frosted/frozen this morning.
    Berdine likes this.
  7. Dec 10, 2017 at 9:13 AM
    #67
    eledobleu
    Orlando, FL
    This is a new issue as the MLED projectors has only been out for less than 2 months and the weather has just begun to change. Now that its noted this will be addressed accordingly.
    SuaveRC and Pudge like this.
  8. Dec 10, 2017 at 12:51 PM
    #68
    jro05065
    jro05065 New Member
    Denver
    2017 CM Tundra TRD
    Is this where you recommend using silicone to seal the back of the rubber grommet? Do you have a recommendation on a silicone? Can you confirm this will not cause any other heat/airflow issues to the projector?
  9. Dec 11, 2017 at 3:19 PM
    #69
    eledobleu
    Orlando, FL
    I recommend ordering TRS 80mm housing caps and cutting a hole that just fit the cable through. This would be a lot cleaner than silicone. But if you use silicone just place it around the hole and fill. There will be no heat issues as they were designed to be sealed inside the headlights.
  10. Jan 12, 2018 at 9:26 AM
    #70
    eledobleu
    Orlando, FL
  11. Jan 14, 2018 at 3:01 PM
    #71
    j2007
    j2007 New Member
    VA
    Despite the 18 degree temps and having to work outside, today I installed my new lights. They’re triple black Morimoto MLED retros with Panamera shrouds and LED strips. I did the switchback installation and DRL delete with them. They look great and the light output is so much more than the OEM 2017 Limited lights they replaced. The M on the ground is more visible than I realized it would be. The fog lights are Baja Designs Squadron Sports with the clear driving combo lenses that I had installed a few months back and they look more yellow than the new headlights.
    (Pay no attention to my Christmas wreath still up in January - I spent my free day doing mods on my truck instead of the house projects I should have been doing :) ).
    00F1D8DD-557B-451D-8B18-A1AFA5D7A6AA.jpg C9AFEEE7-42CD-4B53-ACC3-7191C8F5CA52.jpg 12AFAC02-BE30-47D5-B026-AC71EB484464.jpg 6121854F-B77A-411D-9C34-7E3FEEB40F7E.jpg
    Y0TA PR0 likes this.
  12. Jan 15, 2018 at 5:28 AM
    #72
    94slowbra
    john
    new orleans
    2016 TRD pro
    They look great. I didn't realize the M was that prominent either, if have to do something about that.
    Who did the retro?
    Get some night shots!
  13. Jan 16, 2018 at 6:34 PM
    #73
    j2007
    j2007 New Member
    VA
    @eledobleu did the retrofit. The light output from them is pretty incredible and the cutoff is so sharp it’s easy to get them aligned well. I’ve only been able to see the M on the ground in my driveway on light colored cement. Driving around I don’t see it at all.
    Night shots are tough with a phone camera while driving. Here is one from a highway with no streetlights, no other cars on my part of the road and just low beams. I’ll try to get some others.
    Considering I used to frequently wonder if my OEM lights were actually on at night, it’s a HUGE improvement.
    Gtfour43 likes this.
  14. Jan 27, 2018 at 5:11 PM
    #74
    SuaveRC
    SuaveRC New Member
    May be off topic, but how do y'all get the headlights tinted in the outside?
  15. Mar 14, 2018 at 10:58 AM
    #75
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Anyone have a LED strip that just quit working? My driver side did. I ran out of light last night to finish checking all the wiring. I did the DRL delete to activate the swithcbacks. Passenger side is fine so fuse is good and the lead from the IGN fuse is powered. I believe the ground to the light is good too because it works fine in turn signal mode. Not sure what I am going to do if I have to send back under warranty. My next and maybe last step is to check for power to the red lead out of the LED. If that fails I guess I will wire LED straight to the battery. Planning for the worst but hoping for the best (like loose wire or connection in the cable).
  16. Mar 14, 2018 at 7:04 PM
    #76
    ruiner
    ruiner New Member
    2017 Tundra CM 4x4
    Get a multi-meter tool and see if you can properly detect power. Start slow and go piece by piece to narrow down the cause. You'll figure it out I'm sure.
  17. Mar 14, 2018 at 7:08 PM
    #77
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I did. It is the male end of quick connect on light side. I unplugged and when I put it back together I notice that right before it latched the light came on. Cleaned prongs and did a little bending and it works. Probably needs a different connector but don't want to mess with the thin ass wires if I don't have to.
    ruiner[QUOTED] likes this.
  18. Mar 14, 2018 at 7:11 PM
    #78
    ruiner
    ruiner New Member
    2017 Tundra CM 4x4
    Excellent. I guess while I'm here, I'll post some pics of the MLED install and output since people were asking.
    Completed build:
    Mounted on the truck:
    Daytime Running Lights (DRLs):
    Switchback for blinker/hazards:
    Lights on in the daytime:
    Lights on at night (camera iris closed):
    Lights on at night (camera iris open):
    A foot away from my garage door. The Morimoto 'M' can be blocked out if you want. It should give you an idea of the beam pattern:
    Low beam into the woods - nice cutoff line:
    High beam into the same woods:
    headlights off looking down the road (the DRLs were on as the truck was running):
    low beams on the same road:
    1UPPER, PermaFrostTRD and Pudge like this.
  19. Mar 14, 2018 at 7:27 PM
    #79
    j2007
    j2007 New Member
    VA
    Nice install. I have these as well and love the light output and the look of the switchback LED turn signals and DRLs. But I find the Ms in the beam kind of ridiculous. How do you block them out? Does it have to be done when they’re being built?
  20. Mar 14, 2018 at 7:32 PM
    #80
    ruiner
    ruiner New Member
    2017 Tundra CM 4x4
    Yeah, it has to be done when they are being built (or if you can somehow get inside to do it). Most people put some aluminum tape over the M or something. I, personally, don't find them distracting and are somewhat a conversation piece at times.
  21. Mar 14, 2018 at 7:35 PM
    #81
    j2007
    j2007 New Member
    VA
    Thanks for the info. It’s not a huge deal but if it was something I could do now I would. Certainly not going to open them up though. I see the Ms every time I park now since I installed a front camera and FRAC harness.
  22. Mar 15, 2018 at 8:34 PM
    #82
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Is there a website somewhere that shows images of the shrouds that are available for these. I don't know much about retrofits other than they look so much better, are brighter, and I want some of i can afford them. I'd like to see different shroud options. Thanks
  23. Mar 16, 2018 at 5:34 AM
    #83
    j2007
    j2007 New Member
    VA
  24. Mar 16, 2018 at 7:56 AM
    #84
    ruiner
    ruiner New Member
    2017 Tundra CM 4x4
    Yep, that's correct. Just remember that if you are doing a Bi-LED (or other similar with that projector housing), you can use all shrouds but “Mini” or “Square” I do believe.
    You can also have them painted as well. I went with the normal turbines, in black, for mine.
    Pudge likes this.
  25. Mar 22, 2018 at 10:49 PM
    #85
    TUNDRAZX1400
    TUNDRAZX1400 New Member
    2013 Gun Metal Gray Texas Edition Tundra
    Toneau BakFlip 7' Bed Cover Yakima Bike Rack
    Options for Spyder DRL HEADLIGHTS or Something Resembling 2018 HEADLIGHTS
    What would you suggest for 2016 MGM limited crewmax on a major budget!
    Spending Limit $500 with installation
    Going for looks and Output resembling infinity QX 60 2017
  26. Apr 13, 2018 at 9:31 AM
    #86
    DustinP5
    DustinP5 New Member
    Austin, TX
    2015 Magnetic Grey SR5 Crewcab
    Retrofit Headlights, Heated/Cooled leather seats, Leveled, Pro Grille, Wireless counsel charger, TRD Shif Knob
    Definitely interested in having a set made
  27. Apr 13, 2018 at 9:42 AM
    #87
    Shaggypeach
    Shaggypeach New Member
    Same here ... Can go a little higher but I rather not.
  28. Apr 25, 2018 at 5:15 PM
    #88
    atxtundra
    atxtundra New Member
    If you can get retrofits for $500, I think the person you got them from did it for free. All the parts that go into them cost almost that so you’d be hard pressed to do it yourself for that much.
    They’re expensive for a reason. They’re awesome. And it’s a lot of work to build them. Good luck with your search tho!
