Needing advice starting 2006 tundra Build
Discussion in '1st Gen Tundras (2000-2006)' started by Walker-Wheels, Apr 18, 2021.
  1. Apr 18, 2021 at 9:55 PM
    Walker-Wheels
    Walker-Wheels [OP] New Member
    Bryce
    2006 Silver DC Tundra TRD off-road 4x4
    Hey guys I'm starting to pick out parts I would like to purchase for my 2006 dc. I'm mainly building this truck around lighter trails and driving on long stretches of washboard. I do know that I'll probably hit some other trails around the southern Idaho region from time to time so I would like to be prepared for whatever I throw at the truck. Any help/suggestions would be greatly appreciated, Thank You!
  2. Apr 19, 2021 at 10:40 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  3. Apr 19, 2021 at 12:09 PM
    speedtre
    speedtre New Member
    Inland Northwest
    Budget?
    Darkness and 2006Tundra like this.
  4. Apr 19, 2021 at 1:37 PM
    Professional Hand Model
    Hand Protectors
    Yes. We’ll spend his money real good. :rofl:
  5. Apr 19, 2021 at 9:16 PM
    Walker-Wheels
    Bryce
    Under 5k for now I'm 19 so I'm pretty much just aiming to get some stuff done now and then add on here and there
  6. Apr 19, 2021 at 10:01 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    2.5” Lift/level of your choice
    285 tires or skinny 33’s
    With those two alone, you have a pretty capable rig.
    alb1k, Glock 40 and speedtre like this.
  7. Apr 20, 2021 at 6:55 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Assuming all important maintenance is up to date, I concur with this. For what the OP describes describe, I think the Bilstein 6112/5160 combo with new leaf springs would be where I'd start. I think those are the best bang for the buck (not THE best quality, but damn good for the price). It's what I have and a Wheelers 3-leaf add-a-leaf, which I've been happy with, but probably should have just gone with a set of ATS HD springs for only a couple hundred more. Even if you have to pay to have all that installed, you'll be well-under $5k. If you can wrench, you'll only barely be over 1/2 that. :thumbsup:
    alb1k and Darkness like this.
  8. Apr 20, 2021 at 8:12 AM
    Long stretches of washboards speaks to some remote reservoir shocks to manage all that heat. Maybe a softer spring rate. Keep your teeth from chattering.
    chrisb, Darkness and speedtre like this.
  9. Apr 20, 2021 at 6:27 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Custom deaver or similar leafs with some decent rear shocks
    Icons or kings or even the nicer bilsteins up front.
    About a 33" tire
    Extended brake lines, new upper control arms, t case drop, and the ecgs differential bushing.
    Might get @MDobb79 to add his two cents. His truck looks like a pretty solid all around and comfortable setup.
    MDobb79 likes this.
  10. Apr 20, 2021 at 7:02 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    This is what I built my truck for. I’m starting on a budget and going to upgrade shocks, maybe.
    I just did 200+ Off road miles in Death Valley on incredible washboard roads. Aired down to 13ish PSI I was cruising at 60mph. I average about 40mph.
    My setup is; Front 5100’s with 885 Coils on lowest setting, about 2.5” lift. Rear, Icon 3 leaf add a leaf with overload removed. 5100’s and Firestone airbags with daystar cradles. Tires Toyo ATII’s 285/70r17 on factory wheels with 1.25” Spidertrax spacers.
    Truck did awesome. I’ve done this $hit for years. Really all you need is a great set of AT tires and a air compressor to air back up.
    That being said my friend ran the same trip with a fully stock 02 sequoia on P rated tires. We ran Titus canyon, Lippincott Rd and Saline Valley and a bunch of other roads.
    71E5307B-7D12-4AE4-BBF8-CF3A1F7B4D4D.jpg C18A5946-1D5C-4168-A213-D98F84D5132E.jpg
    alb1k, Darkness, Lil Steve and 4 others like this.
  11. Apr 20, 2021 at 7:36 PM
    KarmaKannon
    Utah
    Some junk
    X2 on the good tires. My tires work good on dirt roads, but I've been on some rocky trails with the rocks poking out of the hard dirt everywhere and it eats tires fast.
    Diablo169[QUOTED] likes this.
  12. Apr 22, 2021 at 3:45 PM
    Walker-Wheels
    Bryce
    Thanks for the help guys, I also use this truck for my company (landscaping) so I may need to go a tad bit heavier in the rear when I'm loading my bed or hauling a trailer. Any suggestions?
    MDobb79 likes this.
  13. Apr 22, 2021 at 3:49 PM
    Hand Protectors
    ATS Springs makes a HD Version (500lbs extra per spring). A few members here have the HD and really like them. Affordable quality as well. Made in USA for less than $500 out the door with new U-bolts and mounting bolts. @rock climber @Lil Steve @onesojourner
    Lil Steve likes this.
  14. Apr 22, 2021 at 4:21 PM
    Walker-Wheels
    Bryce
    Thanks I'll look into them!
  15. Apr 22, 2021 at 4:41 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
  16. Apr 24, 2021 at 10:49 AM
    Walker-Wheels
    Bryce
    I've never heard of the ecgs differential bushings could you explain?
  17. Apr 24, 2021 at 12:22 PM
    Just tackled this swap myself. The drivers side front CV axle for the 4wd system rides on a needle bearing on the inboard side. The needle bearing is in the front differential where the axle is inserted. The needles wear out over time and the shaft has excessive play making noises and flopping a bit. The East Coast Gear Supply bushing is a replacement with no bearings in it to go bad. Pull the shaft, pull the needle bearing, replace with the ECGS bushing. reinstall the shaft.
  18. Apr 24, 2021 at 2:05 PM
    KarmaKannon
    Utah
    Some junk
    Good summary right there, but if the bearing goes bad you get a serious rumble and your diff will leak like crazy because the inner portion of the cv axle will have play in it. I guess it's pretty common that the bearing goes bad after a lift due to the added angle and stress. Much like the cv boots.
    Some good info here too https://www.tundras.com/threads/ecgs-bushing-tool.59664/
  19. Apr 25, 2021 at 12:12 PM
    Walker-Wheels
    Bryce
    Okay so currently I'm thinking of going with the toytec alumas and then adding the ats hd leafs in the rear. Still uncertain with everything for the most part so I'll gladly take all of the input I can get.
    hendybop likes this.
  20. Apr 27, 2021 at 12:36 PM
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    3.5" Lift, ICON Extended Travel 2.5" Coilovers, Camburg Upper Control Arms, Total Chaos Steering Rack Bushings and Differential Drop Kit. Rear ICON Add-A-Leafs, ICON 2.0 VS Extended Travel Shocks. 16x8 SCS Ray10's and BFG All Terrain KO2's 295/75/16s
    I would take a serious look at the @Archive Garage Shackleton Medium Duty or Heavy Duty spring packs. I got the medium for an RTT and camping gear, tools etc and I am very happy with the ride even without a load. While at it I would do the U bolt flip kit. Eric is very helpful and answers his phone (cell) at all times if you have questions. As for the rest, I have ICON fronts at about 3" of lift with the 700# springs and ICON 2" shocks in the rear. If I did it again I would get the 2.5" with CDC valving for the rear. Also, I run Camburg upper control arms, BFG AT KO2s 295/75/16 on Stealth Custon Series Ray 10 16x8 backspacing is 4" with mild rubbing at almost full lock either way. I trimmed quite a bit of plastic out of the wheel wells and from the front bumper cover. Cut down and hammered the pinch weld on the cab as well. Photos are the only two I have on my phone with the latest setup.
    https://archivegarage.com/explore-archive/ols/products/archive-shackleton-med-springs
    huntsonora, chrisb and KarmaKannon like this.
  21. Apr 27, 2021 at 12:50 PM
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    @KarmaKannon are you saying you have had issues with your KO2s in or around rocks?
  22. Apr 28, 2021 at 12:03 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I think that is a great kit to go with and my suggestions would be to skip the block in the back and get some SPC UCAs for the front.
  23. Apr 30, 2021 at 11:40 AM
    Walker-Wheels
    Bryce
    I'm so torn for a couple reasons, I need a work truck that functions well for towing/loading the bed, but I also want this truck to feel comfortable off-road. Might just end up buying an older square body f250 or something for work lol.
    D4x4TRD likes this.
  24. Apr 30, 2021 at 1:32 PM
    AL_TUNDY
    AL_TUNDY New Member
    The Land of Nye
    2005 Tundra
    Airbag setup in the rear with the daystar cradles should stiffen things up for work, and allow you to deflate them for the trails.
    chrisb likes this.
  25. Apr 30, 2021 at 1:34 PM
    KarmaKannon
    Utah
    Some junk
    Not really issues I guess. I have just had about 3-4 rock punctures on ko2s and I wasn't aired down or spinning and they didn't really look sharp. Both trips when this happened the areas just looked like rough dirt trails with rocks coming out of the ground. So pretty much it looked like every dirt trail coming off a fairly main gravel/dirt road. My tires are load range c, so maybe a thicker or heavier tire would help.
  26. Apr 30, 2021 at 1:52 PM
    Walker-Wheels
    Bryce
    Do you or anyone you know on here run them?
  27. Apr 30, 2021 at 3:13 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I actually just removed my Firestone airbags as I didn't have a use for them and they were limiting my travel in back. Otherwise they were fine. I'm sure there's a way to run them with a lift so they don't cause an issue.
  28. Apr 30, 2021 at 6:16 PM
    AL_TUNDY
    AL_TUNDY New Member
    The Land of Nye
    2005 Tundra
    Not personally. I do have the cradles and was planning on doing this airbag setup on my long travel 1st gen, but then I bought a 2nd gen for the heavy towing duties. I've heard good things about the setup and was going all in when I bought my 2nd gen.
  29. Apr 30, 2021 at 6:21 PM
    AL_TUNDY
    AL_TUNDY New Member
    The Land of Nye
    2005 Tundra
    These:
    Daystar aribag cradles
    des2mtn likes this.
  30. Apr 30, 2021 at 9:47 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Ugh, post #10 I said I run them with cradles.
