Need your opinion on lift/bigger tires
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Jun 28, 2020.
  1. Sep 24, 2020 at 6:49 PM
    #91
    Voss
    Voss [OP] Not a new member
    2003 AC TRD 4x4
    Are the leaf springs supposed to be different lengths?344F4FF3-16DC-4222-A984-F0D5E6C5694D.jpg
  2. Sep 24, 2020 at 7:05 PM
    #92
    Casper421
    In the woods
    06 DC
    No and those look to be the same length. Did you measure eye to eye?
    Voss[QUOTED][OP] likes this.
  3. Sep 24, 2020 at 7:11 PM
    #93
    Voss
    2003 AC TRD 4x4
    Thanks. They are the same length and I’m an idiot lol.
    Casper421[QUOTED] likes this.
  4. Sep 25, 2020 at 5:48 AM
    #94
    Gmillz85
    Gmillz85 Ski Bum Extraordinaire
    greg
    2004 Salsa Red AC 4x4 Pro Edition
    She's a Pro
    Gotta love a good mind fuck
  5. Sep 26, 2020 at 6:35 PM
    #95
    Voss
    2003 AC TRD 4x4
    Checked CV boots today. Passenger side is completely torn off the strap. Driver side still intact but looks like it’s close to tearing as well.
    Did some research and I’m fairly sure my CV joint is damaged. There’s a vibration when I accelerate quickly/no vibration otherwise. Bummer
    E1088B13-367A-447A-A132-8A5F90E302E6.jpg 65C3F094-47BF-41D7-B6D0-684951393CE3.jpg 29FC31E2-187D-46F2-90B1-06AF3D26CF2D.jpg
  6. Apr 9, 2021 at 6:48 AM
    #96
    Voss
    2003 AC TRD 4x4
    Morn’n all. So I’ve had this swirling in my head for a while now... what if I got the 700lb springs to replace the 650lb I originally ordered with the kings.
    Would doing so keep my ride smooth while giving me more lift? How much of a lift you all think I could achieve this way?
    Another thought was if it wouldn’t be better to simply lessen the preload on the shocks and rely mainly on the springs for lift... would this stiffen the ride, soften the ride, potential issues? Etc
    Thanks!
  7. Apr 9, 2021 at 6:53 AM
    #97
    Proper spring will ride better than compressed more for more lift spring. Proper spring will have the lift you want and ride better. Which spring that is for your application? not sure on that. Someone here with a setup like yours that has it dialed in could chime in. Or call the off-road shops that deal with this and get their expert opinion.
    Voss[OP] likes this.
  8. Apr 9, 2021 at 6:55 AM
    #98
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Let's go back to your goals. What problem are you trying to fix or what are you hoping to achieve with the Kings?
    I don't think changing the spring rate is going to give you more/less lift. It's just going to change the way it rides. If you are planning to run a bunch of weight up front(aftermarket bumper, winch, skids etc) it might make sense to go with the 700lb springs. Otherwise, leave it as is. When I added my BFF bumper I didn't notice a drop in ride quality with my 650lb springs.
  9. Apr 9, 2021 at 6:56 AM
    #99
    Is there a spring that will allow him to keep the lift, but dial back the perch position?
  10. Apr 9, 2021 at 6:59 AM
    #100
    Professional Hand Model
    Hand Protectors
    Check out that Self-Greasing Frame. Looks rust free and well protected. :D(My boots did this too).
    des2mtn and Voss[OP] like this.
  11. Apr 9, 2021 at 7:01 AM
    #101
    Voss
    2003 AC TRD 4x4
    Ok good to know. Not planning on a bumper but skids and sliders are in my plans.
    My goal was to eliminate any sag I would potentially have from the excess weight and I wouldn’t mind another 1” lift but not at the expense of maxing out the preload/having a terrible ride.
    Mainly wondering if there’s a way to achieve about another 1” lift while not sacrificing ride quality.
  12. Apr 9, 2021 at 7:13 AM
    #102
    Hand Protectors
    Any time you add weight you are sacrificing ride quality. More weight equals more strain on all components. Balance of the truck is effected, as well.
    Out of all the ‘lift threads’ (of which I am no expert) that I have read usually start with whats the best? How do I get? What will happen?
    Basically, nobody knows exactly but in the end the truck changes and you’ll adapt.
