Need your opinion on lift/bigger tires
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Jun 28, 2020.
  1. Jun 28, 2020 at 6:22 PM
    Voss
    Voss [OP] Not a new member
    2003 AC TRD 4x4
    Hi all, planning on a 2.5” lift with Radflo coil overs, Deaver leaf springs and I have Camburg UCA’s as well since anything over 1” lift isn’t recommended with stock UCAs on our trucks. I want to put 305/70 R16 KO2 tires, 33’s 12” width basically. I’m excited but at the same time a little worried I might be missing things I need to do to accommodate these upgrades. Worried I need to re-gear or have larger brakes etc.
    I was hoping you all could give me your insights on my plans and what you think I might be overlooking.
    P.S. I have basically new Bilstein 5100 and fairly new 265/70 R16 KO2s now. I’m treating myself to something I really want for my truck but at same time, I wonder if I can’t pull off what I want with my 5100’s. 2nd guessing myself constantly and I feel your opinions can help me decide on my path forward.
    the only modification I’ve made suspension wise are the 5100’s on the first notch in front which is about a 1” lift to level our the truck.
    Rims are TRD Beadlocks and I have 1.25” spacers.
    Thanks!
    Darkness likes this.
  2. Jun 29, 2020 at 5:02 AM
    Professional Hand Model
    Hand Protectors
    Since you want opinions and thoughts I’ll give you mine even though it might not blow your skirt up. Do not take offense, please.
    Keep it stock and go 285/75/R16 which is as big a tire as possible without ruining things. You‘ll save money by not buying a lift and then causing other lift related issues you’ll have to chase afterwards. Our trucks have a great design and work nicely as is.
    Post up your truck details so others who comment have a better understanding. We have lots of lift guys and you’ll get all types of info to help you.
    tvpierce, Rex Kramer and speedtre like this.
  3. Jun 29, 2020 at 8:18 AM
    Voss
    2003 AC TRD 4x4
    Thanks, no offense taken. Exactly what I’m looking for, a different view point. So we can fit 285/75/R16 tires without a lift on our trucks?... That’s a 32.8” by 12.4” tire. Thought we needed a lift to make tires that big fit our trucks.
  4. Jun 29, 2020 at 8:46 AM
    Hand Protectors
    Been on them for about 16 years (285/75/r16) with the Starfish Original Wheels. They do rub slightly on a full turn into a parking spot/etc on the inside Chassis.
    Other Access Cabs guys around here with lifts and springs with aftermarket wheels have bigger rubbings and end up losing mudflaps and then chase into other unintended consequences.
  5. Jun 29, 2020 at 8:55 AM
    Voss
    2003 AC TRD 4x4
    Interesting. Any lift at all? What’s the offset on your Rims? Have the TRd Beadlock that have a 10mm offset and I have 1.25” spacers which I can remove if necessary.
  6. Jun 29, 2020 at 9:00 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    DITTO, but I run the next smaller size tire.
  7. Jun 29, 2020 at 9:36 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Nonsense. If he has 5100s already then it isn't stock. Depending on what notch your 5100s are on you should be able to hit 2" of lift.
    Depending on what tire you want, with 2" of lift you might clear a 285/75/16 (32.8x11.4). There are some tires with milder treads that clear fine, others with more aggressive mud treads will hit here and there.
    You may need to trim the bottom inside corners of your bumper, it isn't noticable when done right. You may need to ditch the front mud flaps. You may need to pull back the inner fender liner and give the old pinch weld a few good whacks with a hammer to flatten it inward, then pop the inner fender liner back in place.
    Consider the Camburg arms, or safe a buck and get SPC arms, or save two bucks and get the rebranded SPC arms. Not just for articulating but because they offer more clearance for your tires. I don't know which TRD wheels you run or what width or backspace they are. An 8" wide wheel with 4" backspaceis abouts sweet as it gets to run a 285 or 305 tire.
    A full Deaver rear leaf pack you should only consider if you don't carry weight in the bed or do any towing. They flex more and ride smoother at the cost of strength. If you want to lift the rear without losing that, consider a 3 pack addition but go with a heavy duty one and keep the overload in place. This is a third of the price of full deavers. To be fair a stock tundra can clear 35s in the rear stock, no lift.
    You won't need to regear for a 285/75/16, but you'd be cooler if you did. I run this tire with 4.56 gears and the combo works well. I ran this tire with stock gear for 2 years without a problem.
  8. Jun 29, 2020 at 9:58 AM
    Voss
    2003 AC TRD 4x4
    Thanks! When I’m off-road/mainly on trails my bed is usually loaded. Great bit of info on the Deaver springs. Sounds like I’d be worse off with them.
    The tires I want are the KO2s and the 285 and 305 both have a width of 12"+... seems like I'd have rubbing and what concerns me even more is how that rubbing can damage my truck offroad. Need to do a good bit of research it seems.
  9. Jun 29, 2020 at 11:59 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    They have different options but they all have pros and cons. Check into https://archivegarage.com/ they've been building stuff tailored to first gen. They previously made a Deaver leaf that worked well with weight off road but made the back end pretty tall when it didn't have weight. They have a newer design now that should be better.
    Take your time and plan it out. Spend some time in our first gen build pages and ask others what their experiences have been with their set ups.
  10. Jun 29, 2020 at 12:19 PM
    Hand Protectors
    No lift except the Billys up front are set at one notch higher than stock. I don’t know the offset off the top of my head. They are the Factory Starfish Aluminums. I forgot to mention about avoiding spacers as a good idea.
    Not so sure its nonsense, but I told you you’d get some good info from the lift guys. @Darkness confirmed all the extra stuff you’ll be chasing when you do a lift so just as long as you are prepared for it you should be good to go. He is actually the one you’ll want to listen to if you go the lift route. I usually don’t post up on these Spacer/lift/tire size threads because they get touchy, but since you asked...
    How much is your budget so we know how far you are willing to go?
    Darkness and Rex Kramer like this.
  11. Jun 29, 2020 at 12:23 PM
    Casper421
    In the woods
    06 DC
    No shit, I’ll confirm! I’m almost 3.5” higher in the rear with absolutely no weight. First time in over a year with no weight and it drove rough but not bad.
  12. Jun 29, 2020 at 12:48 PM
    Voss
    2003 AC TRD 4x4
    Thanks
  13. Jun 29, 2020 at 12:54 PM
    Voss
    2003 AC TRD 4x4
    I was hoping to stay under $5k for everything. This is a forever truck for me. Thought about the new Tundras or possibly a Taco but the new Tundras are too big for some trails and a taco wouldn't have the towing power a V8 does.
  14. Jun 29, 2020 at 12:58 PM
    Hand Protectors
    Good decision on your truck. You have a decent budget that is realistic for a nice lift. Others will make some fine recommendations.
    Voss[QUOTED][OP] likes this.
  15. Jun 30, 2020 at 9:21 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    What are your goals with the truck?
    I met a local guy who had the 305's and he had to remove the mudflaps and do the pinchweld. Neither of which are hard or expensive. He also had to trim that little plastic bit off the bumper, but again pretty easy. I don't know about regearing though.
    I've had multiple tire sizes, 285/75/16, 265/75/16, 285/70/17 and now 265/70/17. The 285's in either size definitely looked the best, but I took a pretty big hit in gas mileage and I could feel the weight of them on acceleration. I'm really liking the 265/70/17's, they are good year duratrac and I love the look of the tread. I can't say I've noticed the decreased ground clearance and I take my truck to moab every couple of months.
  16. Jun 30, 2020 at 11:32 AM
    Voss
    2003 AC TRD 4x4
    I'd love to Moad one day...
    My goals are 2 part, I want a little more clearance for when I'm on trails and I love the 2"-3" lift with 33"s look on our trucks. I've never had any issues even with my modest 1" lift with the 5100s but recently I followed a Raptor on a trail and ended up somewhere I was concerned could damage my truck... I made it through after some careful planning tho.
    I'm stuck between spending a good chunk of change to upgrade my suspension or if I should just stick with my 5100s, get a 2 inch lift using springs like this guy does.. youtube video: https://www.youtube.com/watch?v=F7UYLbNct4g&list=LL2rDlrb5nITovtnliqGKQLA&index=7&t=233s
    Add a leaf in the back for an extra inch so I level out the truck and get some 305's to bring it all together.
    TX-TRD1stGEN likes this.
  17. Jun 30, 2020 at 1:02 PM
    Casper421
    In the woods
    06 DC
    All I will say about suspension is buy once, cry once. Most likely after a year or less you will want bigger and better.
  18. Jun 30, 2020 at 1:09 PM
    Voss
    2003 AC TRD 4x4
    Funny cause less than a year ago I got the 5100s and now I want bigger and better lol
  19. Jun 30, 2020 at 3:15 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Just go full on like Apimpdad's old truck
  20. Jun 30, 2020 at 3:27 PM
    Voss
    2003 AC TRD 4x4
    Lol, as awesome as that is, too much for me. This is my daily driver as well
    Darkness[QUOTED] likes this.
  21. Jun 30, 2020 at 4:59 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    I went a 7" lift about 6 months ago, and now I want to lower it a few inches. I can t take curves like I want to.
    Voss[OP], N84434 and Darkness like this.
  22. Jul 1, 2020 at 12:08 AM
    FREEDOMEDIA
    FREEDOMEDIA New Member
    Nate
    2002 TRDOR Accesscab 4x4
    3/2 Bilstein suspension, 285/70R17 Ridge Grapplers on SCS Ray10 Wheels
    Who makes a 7" lift? Only DB kits I've seen is the 4" RCD but not sure they're in business anymore??
  23. Jul 1, 2020 at 6:35 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
  24. Jul 1, 2020 at 6:53 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    What's not recommended about it? I have stock UCAs w/ 7" lift and all is fine.
    BDS
  25. Jul 1, 2020 at 7:27 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    He means achieving lift by coilovers, not by a bracket. Brackets are an entirely different ball game.
    :rolleyes: and...
    MNtundra, Tundra2, SC_TRD and 7 others like this.
  26. Jul 1, 2020 at 7:32 AM
    Uhhhh....
    Dave
    7” BDS, 37s
    LOL! Touche
    Voss[OP], Kung, bmf4069 and 2 others like this.
  27. Jul 1, 2020 at 8:52 AM
    Hand Protectors
  28. Jul 1, 2020 at 8:54 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I swear that never gets old!
  29. Jul 1, 2020 at 8:58 AM
    Uhhhh....
    Dave
    7” BDS, 37s
    Notice Barney is standing behind him in the last frame. I ain't goin anywhere! ;)
    SC_TRD and Darkness like this.
  30. Jul 1, 2020 at 10:07 AM
    rock climber
    I'd go full OME, plus rear lift, 3 leaf AAL if yore leafs are in good shape, or custom if not. If you want more, you can't go wrong with full coil overs like king, toytec, etc... OME is a good balance of high end, but not too expensive.
    imDementeD likes this.
