NEED NEW HEADERS any cheaper options then jba or dirty deeds? Still looking for high quality.
Discussion in '1st Gen Tundras (2000-2006)' started by 04 Tundra, Apr 18, 2020.
  1. Apr 18, 2020 at 3:57 PM
    04 Tundra
    04 Tundra [OP] New Member
    Albert
    2004 Toyota Tundra 4x4 AC Limited
    DIFF Breather, Painted Rims, Interior Wrap, Tint,
    Any cheaper options then jba or dirty deeds? Still looking for high quality.
  2. Apr 18, 2020 at 6:14 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    JBA are pretty cheap as is, consider the time it takes to weld them up.
    Pacesetter? :notsure: I see them on Summit under $300
  3. Apr 18, 2020 at 6:17 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Cheap and high quality don't go together.
  4. Apr 18, 2020 at 6:23 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    What happened to your old headers?
  5. Apr 18, 2020 at 7:53 PM
    04 Tundra
    Albert
    Big crack in the manifold tried the quick putty fix but it failed.
    Rex Kramer[QUOTED] likes this.
  6. Apr 18, 2020 at 7:54 PM
    04 Tundra
    Albert
    Thinking of cheaper then JBAs but not garbage. Might just have to bite the bullet on the shorties
  7. Apr 18, 2020 at 8:52 PM
    Danimal86
    Daniel
    Sacramento, CA
  8. Apr 18, 2020 at 9:12 PM
    NWPirate
    Zach
    WA
    :popcorn:
    Wife is tired of the exhaust tick on her 4.7 Sequoia.
    @04 Tundra you plan on swapping them yourself?
  9. Apr 18, 2020 at 11:23 PM
    04 Tundra
    Albert
    Yeah I i will be doing them myself. I feel like it's not rocket science at all just need lots of patience and beer. One of those slow and tidus jobs.
    Darkness and Mountun Goat like this.
  10. Apr 19, 2020 at 5:07 AM
    Rex Kramer
    Georgia
    That happened to me back in '03, I installed JBA shorties because they were a direct bolt on solution. They are still running strong with over 140,000 miles on them.
  11. Apr 19, 2020 at 6:27 AM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    Are there any cons?
    I thought I remember someone saying there was a problem if you get headers. Something about it made a sensor hard to get to or could not be replaced. But not sure that was it.
    I also have the ticking and will replace mine one of these days. But I like to keep things stock and simple to work on. So oem as much as possible. Rare, but sometimes I know you can actually get something better than OEM and even better when it is cheaper.
    Thanks for any suggestions
  12. Apr 19, 2020 at 8:04 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    @RR60 yes, JBA shorties put the passenger side O2 sensor in a stupid spot. It doesn't leave room to remove the sensor, if my sensor goes bad I'll have to pull the header to replace it. Luckily the passenger side is the easy one.
  13. Apr 19, 2020 at 3:41 PM
    RR60
    RR60 New Member
    Thanks. And I know I am asking for a guess.
    But o2 sensor. How much do they charge if I get a new one at the sametime. And are they a once in 110K thing or less.
  14. Apr 19, 2020 at 4:14 PM
    04 Tundra
    Albert
    I just got a new 02 sensor for 54 form Rockauto.com
  15. Apr 19, 2020 at 9:32 PM
    RR60
    RR60 New Member
    Seems to be about 483.00 anyone seen a better price?
  16. Apr 19, 2020 at 9:37 PM
    RR60
    RR60 New Member
    Did you mean the Driver side is in a bad spot?
  17. Apr 20, 2020 at 4:05 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    The driver side AND the passenger side are in very tight spots even on factory exhaust in the way....IMMHO !
  18. Apr 20, 2020 at 6:35 AM
    04 Tundra
    Albert
    Nope! I'm from canada looking at 680.....
  19. Apr 20, 2020 at 6:59 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Nope, driver side is fine. The passenger side O2 almost butts against the pan, not much clearance to back it out.
  20. Apr 20, 2020 at 7:36 AM
    skywalker474
    skywalker474 New Member
    san diego
    06 DC 4x4 trd
    Do you think its a problem to move the bung just a bit? cap the inaccesible bung with a bolt and weld in a new one in a more convenient spot.
    Is clocking important? ive had differing views from friends in auto industry.
    ive only heard never mount off bottom bc condensation.
  21. Apr 20, 2020 at 7:55 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    If/when my O2 sensor fails I'll be clocking it more upward. Weld in a new bung and thread a bolt in the old one.
    Or I might shell out the $560 for new long tubes :D
  22. Apr 20, 2020 at 9:19 AM
    04 Tundra
    Albert
    Give me a deal on your shorties and you can order your long tubes today
    Darkness[QUOTED] likes this.
  23. Apr 20, 2020 at 1:10 PM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    I have some jba shorties...whats a deal for you? I wanted long tube but the extra work in my mind made me reconsider then I got my quote to install and feel like I should have gone long tube.....
  24. Apr 20, 2020 at 2:24 PM
    04 Tundra
    Albert
    How long ago did you get your headers and what material ? Also do you have any pictures of your current headers
  25. Apr 20, 2020 at 3:21 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    How would you go long tube without spending a fortune on the exhaust? Maybe I need to reconsider. DD was going to be $3200...
  26. Apr 20, 2020 at 4:24 PM
    imDementeD
    I bought them on FB Market Place used back in Jan. They have never been used and came with all gaskets and hardware for installation.
    https://www.tundras.com/threads/wha...t-gen-tundra-today.2558/page-480#post-1574865 (pic of them) They are stainless. Same condition as they are when I got them a few months ago. I understand they aren't shiny new but this is how stainless looks after a short time (worse once it's actually been used)
  27. Apr 20, 2020 at 4:38 PM
    imDementeD
    Idk what you were getting from Keith but that seems like a LOT.
    If I did sell the shorties and went long tube, I would get the headers ($550), o2 Simulator ($150?), Dirty Deeds bolt-on race exhaust with no cats/mid-pipes are $899.That's $1600 + shipping. Which, also makes me question selling the shorties because I have brand new cats, bamuffler that I just bought and the JBA shorties so I am done already minus install. The problem is, what I was quoted for install by my usual mechanic was $1000 for labor and that's too much for what will probably be a small improvement.
  28. Apr 20, 2020 at 4:51 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I thought the same thing. You need to call Keith. His website is not updated. Long tubes plus his exhaust is $3,200. I'm not sure if you saw my other post last week but I just had a long talk with him.
  29. Apr 20, 2020 at 9:20 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    https://www.ebay.com/ulk/itm/202743450952
    I was always curious about the Gibson headers before I got my JBA’s.
    The seller is taking offers. I’d put an offer of $300 and see what happens. Gibson does make quality products.
  30. Apr 21, 2020 at 6:46 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    UPDATE: I was reading some reviews on these headers and they sound like pure shit. Leaks, warped flanges and holes not lining up. I would not waste my money on this poop product.
    This is probably not a very “stylish” option, but you could look at these:
    https://www.andysautosport.com/products/manzo_usa__tp-115.html
    If I was considering these, I would get some Percy gaskets for the headers and remflex gaskets for the collectors.
