Need help? Abs,brake light speedometer etc.
Discussion in '2nd Gen Tundras (2007-2013)' started by JC303, Jun 28, 2015.
  1. Apr 4, 2018 at 8:31 AM
    JC303
    JC303 [OP] Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    Yes. This is exactly what happened to me. I'm not sure of the order as I noticed everything went down at once. Do you have the Hypertech Speedometer calibrator?
  2. Apr 4, 2018 at 10:22 AM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    No I don’t. What does it do?
    Also what was your fix? I don’t think I noticed what that was.
  3. Apr 4, 2018 at 10:39 AM
    Calibrates odometer for over-sized tires
    JC303[OP] likes this.
  4. Apr 4, 2018 at 11:28 AM
    DalTee
    DalTee New Member
    Dal
    Thanks - I don’t have those..... yet
  5. Apr 4, 2018 at 2:27 PM
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    I purchased a new Hypertech and that fixed all my issues.
  6. Apr 22, 2018 at 9:09 AM
    Punisherthunder
    Punisherthunder New Member
    I am having the same issues:
    VSC Off light on
    Trac light on
    ABS light on
    Airbag light sometimes on
    Emergency BRAKE light on
    No tachometer working
    No speedometer working
    Does not go in limp mode
    No Check Engine light
    I have a 2007 with no mods, or huge tires or anything. Just going down the road when suddenly this happened.
    Anyone found a solution?
  7. Apr 22, 2018 at 1:35 PM
    DalTee
    DalTee New Member
    Dal
    Dealer didn’t find anything - then the weather changed and oddly - no lights
  8. Sep 1, 2019 at 11:21 AM
    Harleygirl883
    Harleygirl883 New Member
    KELLY
    2008 tundra
    None
    Having the same problem now. Disconnected battery and cleaned. Started up. Not shutting it off until we get home.
  9. Apr 21, 2020 at 2:37 AM
    Tundramountain
    Tundramountain New Member
    I am having similar problems.
    No speedometer
    Flashing hi low 4wheel drive
    All dash lights on
    A/c flashes and doesnt work
    Driving me crazy! What is going on!!
  10. Sep 20, 2020 at 11:38 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    I installed a Genesis dual battery kit and encountered this same exact problem after starting it up after the install.
    No RPMs
    No cruise control
    No outside temperature gauge
    Lights that were on:
    Brake
    Traction control
    ABS
    Airbag
    Checked all fuses - all were good.
    I took off the positive battery clamp (for primary, cranking battery), and with wire brush cleaned up the clamp ring real well. Then disconnected the factory wiring to the clamp (12 mm bolt on top of clamp) and cleaned off all flat connection points real well with wire brush.
    Fired it up, and all is back to normal.
    If anyone else runs into this - try cleaning off those batt connections.
