Need a couple testers for heavy duty coil springs
Discussion in '3rd Gen Tundras (2022+)' started by GeneralSpring, Aug 19, 2022.
  1. Dec 16, 2022 at 6:26 PM
    porterbc
    porterbc New Member
    Brandon
    2022 Tundra Crewmax Limited TRD OFF-ROAD
    Thanks! Where ya from?
  2. Dec 17, 2022 at 11:32 AM
    porterbc
    porterbc New Member
    Brandon
    I was speaking to the gentleman that actually designed and made the springs for me, we had a great conversation and as per our discussion he’s going to create another version of the rear springs, the current ones I have installed are 2” taller then stock and 35% higher weight/payload capacity which in turn will be perfect for those who have permanent weight added such as truck campers or work space caps etc, however mine in empty unless the trailer is on and is causing some slight issue with maintaining contact with the ground and the back end dancing around on bumps.
    So after some great discussions He decided he’s going to create a second version of these springs which will be 1” ride height increase and only 20% weight increase over stock. He said that he’ll have a set made up and shipped out for me to swap out and see how they preform in a week or 2.
    I will add to this post when I receive them and post install and ride height changes and ride quality, as they only take about 30- 45 mins to swap out.
    so @t300 and @Kap1 I will quote you when I have an update!
    Stay tuned…
  3. Dec 17, 2022 at 11:38 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Porterbc, thank you very very much for letting us know and doing the hard work of testing!
    porterbc[QUOTED] likes this.
  4. Dec 17, 2022 at 11:50 AM
    porterbc
    porterbc New Member
    Brandon
    Haha well not much are work driving around in a bran new truck. But I am very grateful for getting free springs to try out, and work them to improve my business. I was debating adding air bags but I like the thought of this as it has less maintenance.
    I’m sure the second set will be perfect for my situation, with slightly better ride quality and little less rake when empty.
  5. Dec 17, 2022 at 11:53 AM
    porterbc
    porterbc New Member
    Brandon
    was looking at your setup and rough weigh load on your truck, I dare say the current spring I have installed will prob work out fantastic for your truck..
    PapaDave418[QUOTED] likes this.
  6. Jan 23, 2023 at 6:47 AM
    porterbc
    porterbc New Member
    Brandon
    Adding ~ 850lbs on those new front spring..
    and haven’t recieved the new rear + 20% spring rate yet so took the 35% one out and cut 1” of height out of them for now. Much more satisfied with empty ride height, and not quite as harsh ride now. Will still keep updating when the new model becomes available. As for now though the fronts are taking the added weight beautifully, and still need to add some counter weight to the rear. (Prob 4-500lb)
    Jowett, =JSG=, wing-2 and 1 other person like this.
  7. Jan 23, 2023 at 7:01 AM
    Outbound
    Aaron
    Northern Alberta
    How does the empty ride compare to the stock springs?
    I'm thinking about eventually putting the general springs in to handle the occasional load and towing better but also to give a slight lift instead of going with a full on lift kit, since I don't want to go more than an inch or two up.
  8. Jan 23, 2023 at 7:19 AM
    porterbc
    porterbc New Member
    Brandon
    Heavy rate springs and 10ply tires, ride is a little rugged. Definitely noticeable over stock quality. Of front air pressure stays at 32-35 psi would absorb most of the road, and @GeneralSpring is currently making 1” lift and 20% increase for payload in the rear. Which will improve ride quality in the rear for me. Just shortening the 35% in the rear has improved them quite a bit.. but ride quality is that of prob 3/4 ton for me with aired up tires and spring. But once pinned on to trailer feels like stock again and smooth as glass, with less of the roller coaster bouncing in the rear over bumps.
    Outbound likes this.
  9. Feb 16, 2023 at 7:24 AM
    IdahoORTundra
    IdahoORTundra New Member
    Justin
    2023 Tundra SR5 TRD Off Road
    If you’re still looking for beta testers I’d be interested! I have a 23 and it pulls my a toyhauler loaded. Would be great to have a heavier spring in the rear. I don’t mind 1-2” eta height in the rear since I will be putting a 4wheeler in the bed before I hook up the toyhauler so the truck is loaded!
  10. Apr 2, 2023 at 11:56 AM
    pbeaudoin
    pbeaudoin New Member
    Patrick
    2023 army green trd off-road sr5
    Any updates on available rear HD springs? I am getting my 2023 this week and will be carrying around 600-700lbs in the bed at all times. I would really prefer HD springs to airbags or timbrens. Any contact info or website for available options?
    thanks!
  11. Dec 10, 2023 at 8:54 AM
    jvance
    jvance New Member
    Jeff
    2023 Silver Tundra Limited TRD 2wd OFF ROAD Pkg.
    Black Badge kit BK4 Tonnuea Cover with BedRug Future Upgrades: Exhaust Lowering Kit
    currently looking to lower front 2” and rear 4”. SOS has a front kit but rear coil drops are not out there yet. Any help would be appreciated.
  12. Feb 4, 2024 at 7:10 PM
    Burn5860
    Burn5860 New Member
    2022 1794 Tundra TRD
    I have a 22 6.5ft bed 1794 army green and would like to be able to tow my camper with my quad in the bed!! Are these tests still taking place I really don’t want to go to a superduty I love my truck just want less squat!!
  13. Feb 5, 2024 at 5:04 AM
    vorkuta775
    vorkuta775 New Member
    I will be shopping around for some soon, got a four wheel camper coming and it will live in the bed of my tundra. 400ish constant lbs.
  14. Mar 25, 2024 at 1:13 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    @porterbc
    How are the HD springs working out for you?
  15. Mar 26, 2024 at 6:10 AM
    GAMark
    GAMark New Member
    With the 1" lift in the rear would I remove the Timbrens?
  16. Apr 1, 2024 at 5:30 AM
    porterbc
    porterbc New Member
    Brandon
    They are great! Like I said, built for work.. if you want stock ride, prob not the best option. But running 10ply tires and at 60-70 psi and running up to max payload and trailering capacity, works beautifully.
    Leo's first likes this.
  17. Aug 13, 2024 at 2:38 PM
    KAHU
    KAHU New Member
    2023 Tundra Limited TRD 3" TRD Lift
    3" TRD Lift, 285/65R20 Falcon Wildpeak AT3W, Baja Design Light Bars, Fogs, and Reverse lights. Leitner Design Forged Rack, Bush Company AX27 RTT
    I’d be interested if you can accommodate the 3” TRD lift.
  18. Jan 13, 2025 at 4:51 AM
    Spartanfam
    Spartanfam New Member
    West Michigan
    2024 Tundra Limited TRD Off-Road
    No luck finding any HD coil springs for a Tundra without additional lift. A number of solutions for Ram… I get its volume driven but coil springs are very low capital investment to create. I tow a lot and don’t want lift… just less squat to offset with WD hitch.
  19. Jan 13, 2025 at 7:42 AM
    #49
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I did a 1" Westcott spacer in the back. It was enough to take some squat away. The weird bonus was that the rear of the truck seemed to become more compliant. This really made the ride better. Easy install too.
    Spartanfam[QUOTED] likes this.
