My Tundy is a hog
Discussion in '2.5 Gen Tundras (2014-2021)' started by Melikeymy beer, Oct 18, 2019.
  1. Oct 19, 2019 at 2:32 PM
    #61
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Hmm, mine has a tow package so maybe I'm understanding why it's dropped 130 from the original 1440. I still can't figure out where yours is losing another 330 fuel weighs about 7lbs/gal. Let me ask you this? Why are you worried? Do they make you run across scales and check that stuff? Most engineering designs have a 10-20% fudge factor.
    Racingjohndeere55 likes this.
  2. Oct 19, 2019 at 2:45 PM
    #62
    Melikeymy beer
    Melikeymy beer [OP] No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Not really worried. I just want some room for an extra passenger ocassionally (adult daughter), generator (~100 lbs), etc. I'm not concerned about getting weighed. When I weighed my truck with the loaded RV on the hitch, ~250 lbs of cargo in the truck and 3/4 tank of gas, the weight was 7,200 and the GVWR is 7,200. So maybe 50-60 over, and GVWR is what I'm going to watch. I'm a novice at towing so I'm just trying to be safe and do it right.
    Rex Kramer likes this.
  3. Oct 19, 2019 at 2:51 PM
    #63
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I believe a vehicles GVWR includes a full tank of gas
  4. Oct 19, 2019 at 2:52 PM
    #64
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    I understand. I think you are fine as long as you don't get crazy and start ripping stuff off your truck or throwing a lot of fat chixx in the bed. Enhance the rear suspension if you feel the need. I've added a safe, sway bar, Bakflip and the 50 lb Tundra bed mat. I don't even count that any more than the 7lb AR15 under the back seat
  5. Oct 19, 2019 at 3:34 PM
    #65
    Rex Kramer
    Georgia
    4X4 RCSB KUBOTA
  6. Oct 19, 2019 at 4:11 PM
    #66
    LMAO...and hydraulic tilt bed.
    With the snow plow package, lights, etc...cost more than my '12 Tundra CM did.
    Rex Kramer[QUOTED] likes this.
  7. Oct 19, 2019 at 4:20 PM
    #67
    I called up my buddy with two F150 EB, 4x4 crew cab trucks. One is a Lariat that’s nicely loaded and the other is an XT.
    Lariat
    XT
    For comparison purposes only. The Lariat package is like the Limited Tundra. Had he purchased the Platinum, his capacity would be lower.
    pickeledpigsfeet and 1engineer like this.
  8. Oct 19, 2019 at 4:46 PM
    #68
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    Yep. Samesame. An OEM can only do so much and expect it to ride decent empty. It's pretty easy for an OEM to scale it up to a 2K load but... nobody would buy it because it would ride like a horse drawn carriage and... then they would be competing with their 3/4 ton sales. Lose lose.
    OP, you can add capacity but not legally. Only the OEM can set payload.
    Melikeymy beer[OP] likes this.
  9. Oct 19, 2019 at 7:36 PM
    #69
    Melikeymy beer
    Muscogee Nation
    It would be interesting (to me) to know if the Lariat had the big fuel tank.
  10. Oct 19, 2019 at 7:47 PM
    #70
    Melikeymy beer
    Muscogee Nation
    The tundra is a lot heavier. Mine is about 6000 lbs. Here's the Platinum F150
  11. Oct 19, 2019 at 8:31 PM
    #71
    Oh these F-150s are a lot lighter, but still have a lower capacity. Not 1000 lbs low, but it’s also not 1800-2000 lbs like some think it is.
    I towed with another one of my friends 2016 F-150 EB Sport. Power was good, fuel economy was horrible (6-7), and the lighter truck didn’t have a good solid feel. Now we were towing with a U-Haul car hauler, and a 4400 lb rock crawler.
  12. Oct 19, 2019 at 8:33 PM
    #72
    I believe it’s the bigger 36 gallon tank, which sucks considering a 23 gallon is optional.
    This is one thing he really made sure of. His 2016 F350 has the 26 gallon tank and he hates it. When pulling his 40’ toyhauler, he doesn’t pass many fuel stations.
  13. Oct 19, 2019 at 9:21 PM
    #73
    Snowboard Tundra
    Snowboard Tundra New Member
    True that. In 4 years of ownership I carried a pallet of tile once that easily was over 1000 lbs....ass end dragging the ground. Meh, only one time, I usually just haul lighter stuff so no big deal. If my job involved hauling heavy or towing heaving I'd own an F350 / F450.
    Pudge[QUOTED] likes this.
  14. Oct 19, 2019 at 9:22 PM
    #74
    Snowboard Tundra
    My spare is useless as I run 35's. I should really take it off but am too lazy to do so.
    Pudge likes this.
  15. Oct 19, 2019 at 9:36 PM
    #75
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Its actually very easy to do once you figure out that the wrench for it is in the jack lol. 5-10 minute job. But i hear ya on being lazy about this kinda stuff. Lower the chain, unclip the rim and raise the chain, maybe zip tie it up somewhere so it's not swinging around like crazy. I removed mine day 1 so I could flip it over so the valve stem faced down for easier airing up. I also lower it every year and spray that area, chain, both sides of the wheel with fluid film.
    Melikeymy beer[OP] and georgie like this.
  16. Oct 20, 2019 at 4:08 AM
    #76
    georgie
    georgie New Member
    Removed my spare also so the rust proofer could get to all the frame. Never put in back on. I will throw it in the bed if if leaving the city.
    Pudge and Rex Kramer like this.
  17. Oct 20, 2019 at 6:28 AM
    #77
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If toyota could have made it 100 lbs lighter without sacrificing anything they would have
  18. Oct 27, 2019 at 7:25 AM
    #78
    Zum
    Zum New Member
    NS Canada
    Put gear/stuff in the RV, except for the wife that is.
    Gas cans probably not, but a lot can fit inside the trailer,strapped down.
  19. Oct 27, 2019 at 11:21 AM
    #79
    Rider0120
    Rider0120 New Member
    Bucks County, Pa
    2018 White double cab SR 4x4 long bed
    Ranch Hand full replacement bumper
    I think most of us get close to going over the 1,000lb payload when we tow with these trucks. Passenger count as payload. I had a weather guard cross over box and ditch that for a roll up cover to save weight. My curb weight of my truck is 5980. But this was just my case with truck.
  20. Oct 27, 2019 at 11:36 AM
    #80
    Rider0120
    Bucks County, Pa
    When I drive my truck I have less then 1000lb of payload. The curb weight of my truck is 5960. I weigh 235. F7C82E93-71E0-4807-BC47-07B0D30C015C.jpg
  21. Oct 27, 2019 at 11:38 AM
    #81
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The good news is that with a 900lb payload you will be almost perfectly balanced :)
    Rider0120 likes this.
  22. Oct 27, 2019 at 11:58 AM
    #82
    Rider0120
    Bucks County, Pa
    This guy does a decent explanation of GVWR GCWR what options and decrease your max tow weight. The max tow capacity means basically nothing compared to the 7200 GVWR on our doors. Check it out, it a eye opener
    https://m.youtube.com/watch?v=qwFLOBrADBs
  23. Oct 27, 2019 at 1:45 PM
    #83
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    From what I get from their site a 4x4 cremax shortbed has a max payload of 1520. Through options your payload has been decreased to the door sticker spec. 1520 is your max and if it can be reduced by adding weight, it can be increased (up to 1520) through weight reduction. Toyota defines "payload capacity" as a GVWR - curb weight and is for comparison only. The only way to know is get your truck on a scale and subtract that from your Toyota spec'd GVWR. Then start shedding weight until you are at the max listed payload for your config, in my case it is 1520. Reducing weight beyond that would be pointless because you're going above what is spec'd as safe for your vehicle setup. We do the same thing with our work trucks when we strip the chassis and bolt on service beds. You are limited to "MAXIMUM PAYLOAD" for your vehicle setup but can play with the number under that.
  24. Oct 27, 2019 at 2:23 PM
    #84
    Melikeymy beer
    Muscogee Nation
    Makes sense to me. To keep things simple, I'm just focusing on keeping the GVWR under the 7200 lbs maximum per the door sticker. Weighing the loaded truck with trailer attached is easy enough. If I'm at 7200 and want to add 100 lbs then lose 100 lbs somewhere else.
  25. Oct 27, 2019 at 2:26 PM
    #85
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    That bumper must weight 250 pounds.
  26. Oct 27, 2019 at 3:36 PM
    #86
    Rider0120
    Bucks County, Pa
    The full bumper replacement is just south of that. I didn’t really add that much weight by adding the bumper since the stock bumper was like 40-50 lbs.
    It surprised me how heavy my truck’s curb weight (5960) compared to my unladen weight (5600). The only thing I can think of is Toyota doesn’t include fluids for unladen weight.
  27. Oct 27, 2019 at 3:41 PM
    #87
    Rider0120
    Bucks County, Pa
    Loosing 100 on the trailer is like a fly on a horses rear because of having a 9-15% tongue weight
    JimboSlice413 likes this.
  28. Oct 27, 2019 at 4:27 PM
    #88
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Pretty easy to go over 1,000 lbs.. gravel, stones and dirt haul could go over easy. Since they only guess at the yardage. Most require 1/2 yard at least for purchasing.
    I'm glad I'm at 1200 slightly higher than 1000.
  29. Oct 27, 2019 at 4:50 PM
    #89
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    2 jugs of oil- maybe 25lbs?
    Jug of diff oil- 12?
    Trans fluid- 36 lbs?
    Gas tank full maybe 200?
    Battery is 35?
    Guess that adds up fast
  30. Oct 27, 2019 at 5:26 PM
    #90
    Melikeymy beer
    Muscogee Nation
    I was referring to the truck cargo.
    Rider0120[QUOTED] likes this.
