Morimoto XB headlight/foglight problem
Discussion in '2nd Gen Tundras (2007-2013)' started by shannon, Sep 7, 2021.
  1. Sep 26, 2021 at 2:32 PM
    shannon
    shannon [OP] New Member
    shannon
    Asheville, NC
    2010 DC
    Wow, that's way over my head, but thank you for your time. I assume it was written for me. I had stock headlights with plug and play morimoto fog lights. Everything worked as it should. I replaced my stock headlights with Morimoto XB headlights. Whenever I turn the headlights on the foglights go on now, I cannot turn them off with the foglight switch. I have tried resistors on the high beam and the low beam and neither position solves the problem. I have noticed that if I turn the headlights on before I start the truck the fogs don't come on. I can turn them on via the switch. Once they are on the only way to turn them off is to turn the headlights off and sometimes that doesn't work. Confusing huh?
  2. Sep 26, 2021 at 6:43 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Is it possible that a previous owner has done the "fog light all the time" mod?
    Tho that would have been apparent before the headlight swap, so I still dunno.
    Look for something suspect with the fog relay.?
  3. Sep 26, 2021 at 8:09 PM
    shannon
    shannon
    Asheville, NC
    2010 DC
    No foglight mod. Works as it should with stock headlights
  4. Sep 26, 2021 at 8:52 PM
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    So for my fogs, i had to plug it in the way it was reverse polarity. Positive from truck went to black on the fog. This was on both sides too. I installed mine earlier this month. First tested + to + and - to - and no light. Switched them and they work just fine.
