Monitor Trailer Cargo While Driving
Discussion in 'Towing & Hauling' started by Jota21, Feb 18, 2022.
  1. Feb 18, 2022 at 8:09 AM
    Jota21
    Jota21 [OP] New Member
    Anybody have any products for monitoring their trailer cargo while driving? I mainly use a small utility trailer, and it'd be nice to have a monitor in the truck to see if things have shifted, etc. Something even as simple as a baby monitor/phone app or something??
  2. Feb 18, 2022 at 8:12 AM
    Taco-Spike
    Two Trucks
    Mount a go pro or similar device and control with your phone.
    I've seen remote trailer back up cameras also, could mount them at different locations to view where you want?
    I'm sure there are better options, just spit balling off the top of my head.
  3. Feb 18, 2022 at 9:20 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Look into RV cameras. Make them for any budget and sounds like what you are looking for. Can get a wireless set up for under a couple bills.
  4. Feb 19, 2022 at 3:45 AM
    Retired...finally
    Many, many options out there. I use this on my 2021 with the camera mounted on the rear of my travel trailer
    https://www.amazon.com/Wireless-DoH...8&sr=1-1-ea136695-3596-4534-80e7-1570345d02b9
    It's connected to the running lights for power. The camera could be mounted on a post in the front of your trailer to monitor the load. Dohonest sells many different camera and monitors on Amazon. If your truck is newer with a backuo camera the anytime backup and front camera kit allows one to monitor the existing backup camera with the flip of a switch.
  5. Feb 19, 2022 at 3:48 AM
  6. Feb 19, 2022 at 6:37 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I'm in the process of building up my first set of video switch modules for use with the FRAC harness. (Wire harnesses are built, now building up the circuit boards). This module will connect with the FRAC to add a second camera to the rear camera input. One is the normal tailgate camera and the other can be a trailer rear view, or a trailer internal view like you are discussing, or a bed camera. Hope to have theses available on the website in the next couple of weeks.
    mountainpete and Omohundro like this.
  7. Mar 3, 2022 at 3:19 PM
    102dalz
    102dalz New Member
    Andy
    2017 Tundra CrewMax White
    None
    I appreciate your efforts...but you know I've already added a video switch with the capability for 4 inputs!!
    Will yours have a switch mountable in the cab?
  8. Mar 3, 2022 at 6:14 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes. I have an OEM-style Trailer Mode switch. Pics should be up on the website this weekend.
    HulkSmurf14 likes this.
  9. Mar 4, 2022 at 3:31 PM
    102dalz
    102dalz New Member
    Andy
    None
    Lou,
    Any possibility this will "add-on" to my existing FRAC? Still one of my wife's favorite upgrades, especially with the F/R switch mounted on the console behind the shifter. Too bad you weren't offering the Toyota style switch then. BTW, you need to use a switch which lights when activated for the Navi functions....this way it's easy to see when it's active or inactive (wife occasionally leaves it on & then her Navi misbehaves). ;)
    BEST customer service EVER, for other forum members reading this.
    TundraTex likes this.
  10. Mar 4, 2022 at 3:34 PM
    102dalz
    102dalz New Member
    Andy
    None
    JOTA,
    The FRAC could be your best bet for this. It's pretty EZ to install in your dash...running your camera wires to toughest part...and reasonably inexpensive. Also, TundraTex install instructions & customer service are 2nd to none.
  11. Mar 5, 2022 at 7:01 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @102dalz YES! That's exactly what I designed it for. It will tie into the FRAC harness and allow you to select the "default" rear view that will be displayed whenever you shift into reverse or select the rear FRAC position.
    Also, I am very close to making an OEM VIM Select switch available that will do just what you are requesting.
  12. Mar 30, 2022 at 1:26 PM
    102dalz
    102dalz New Member
    Andy
    None
    Lou,
    How does the "Trailer Video Kit" on the FRAC website install? I'd love to have some install instructions...I'm thinking this might be easier for switching to my "bumper" camera for towing, or MC carrying with tailgate in down position (although I see it's out of stock now)?
    BTW, does the OEM front/rear switch have a "center" position like the rocker...to function in OEM fashion?
    Andy
  13. Mar 31, 2022 at 8:29 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Andy,
    The Trailer Video Kit connects with the FRAC harness and adds an additional switch for trailer mode. I’m on the road this week but I’ll be posting up the instructions on the website this weekend. I received a few more parts so I can hopefully make more kits available this weekend as well. I had only six to start with and they sold out in about an hour. The parts delays are killin me!
  14. Apr 9, 2022 at 12:08 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
  15. Apr 9, 2022 at 12:19 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
  16. Jun 12, 2022 at 7:26 AM
    AJTundy
    AJTundy New Member
    2020 Tundra Crewmax SR5
    Leer 100XR truck cap, 5100's on the middle setting. Ikon Add A leaf, Cooper Discover ATX3 275/70/18, Genuine Cooling Systems transmission cooler, chrome delete.
    Are you planning on making any more of these? I have your FRAC harness, would love to add another camera input.
    Thanks!
  17. Jun 14, 2022 at 4:54 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    That's on my to-do list. I've sold out of my first two batches and my original circuit board supplier is having distribution problems so I'm trying to get an alternate supplier lined up.
  18. Jun 14, 2022 at 5:14 AM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    I haven't bought it yet, however this is what I'm replacing my bluetooth trailer backup camera with. It is wi-fi and uses a smartphone as the monitor. It will be like a rearview mirror once I install it.
    https://www.amazon.com/dp/B07DW368JG
    edit:
    I must have done this wrong regarding the link. This is an Amazon link for a Last bus backup camera.
