Misfiring
Discussion in '2.5 Gen Tundras (2014-2021)' started by gundyguyaustralia, Jun 6, 2021.
  1. Jun 6, 2021 at 11:54 PM
    gundyguyaustralia
    gundyguyaustralia [OP] New Member
    Guy
    Ran through some salt lakes while our shooting on the weekend so pressure cleaned the undercarriage the following day but not the engine bay just around the wheel arches and chassis/running gear now the engine light has come on and it’s running rough. Took it to the local mechanic who put the auto logic computer and it’s giving a cylinder 3 misfire code. Any ideas on if this is coincidence or water related as there is no evidence of water on any coils or engine parts in the engine bay?
  2. Jun 7, 2021 at 4:22 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  3. Jun 7, 2021 at 4:31 AM
    gundyguyaustralia
    Guy
    Thanks mate I’ll check through them hoping it’s just the coil on 3
  4. Jun 7, 2021 at 4:41 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    One easy thing you could do is just swap coils and plugs - move #3 to another good cylinder and see if the problem stays on #3 or moves with the coil/plug.
  5. Jun 7, 2021 at 5:22 AM
    gundyguyaustralia
    Guy
    Thanks that’s a good idea will try tomorrow.
  6. Jun 7, 2021 at 5:41 AM
    glowblue
    VA
    :thumbsup: You could just start with a coil swap before swapping plugs and see if that does anything.
  7. Jul 7, 2021 at 4:26 PM
    Giskk
    Giskk New Member
    Mississippi
    2021 Cement Tundra TSS Off-road
    My 2017 was misfiring on cylinder 4 and turns out the spark plug was loose. I could turn it with my hand.
