Mgm16trdpro build
Discussion in '2.5 Gen Builds (2014-2021)' started by mgm16trdpro, Oct 5, 2017.
  1. May 16, 2020 at 9:42 AM
    #661
    mgm16trdpro
    mgm16trdpro [OP] Certified Modoholic
    Northern NJ
    2016 mgm trd pro crewmax
    Finally broke down and got the newer OEM pro leds installed.
  2. May 16, 2020 at 12:32 PM
    #662
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    My goal is to mimic your rig, good thing I'm in MD or we'd be twinnzies
    aperezsh and mgm16trdpro[OP] like this.
  3. May 16, 2020 at 12:32 PM
    #663
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    I effin love your rig
  4. May 16, 2020 at 12:38 PM
    #664
    mgm16trdpro
    Northern NJ
    It's all good brother
    Thanks
  5. May 16, 2020 at 12:55 PM
    #665
    Ted4311
    SOMD
    A LOT... NEVER ENDS
    Everytime I think big lift I look at your build and it makes me want to embrace mid travel
    mgm16trdpro[OP] likes this.
  6. May 16, 2020 at 2:04 PM
    #666
    mgm16trdpro
    Northern NJ
    For me its perfect. I'm also not trying anything too crazy with the truck. It gets the job done for me, I can count on 1 hand the times I could've used an extra couple inches of clearance, even without, still not a problem.
    GODZILLA and Ted4311[QUOTED] like this.
  7. May 19, 2020 at 8:24 PM
    #667
    Borgs
    Borgs New Member
    PA
    Looking good as always Mike. How you liking those lights so far?
  8. May 20, 2020 at 2:16 AM
    #668
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Once Again brother, Your rig is a shining example of why MGM'S drop bombs on all other colors.:headbang:
    mgm16trdpro[OP] and Ted4311 like this.
  9. May 20, 2020 at 6:26 AM
    #669
    mgm16trdpro
    Northern NJ
    Tnx brother I love them.
    Borgs[QUOTED] likes this.
  10. May 20, 2020 at 6:27 AM
    #670
    mgm16trdpro
    Northern NJ
    Haha tnx Ali
  11. Feb 11, 2021 at 7:03 AM
    #671
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    @mgm16trdpro Hey Mike. I installed an SSO slimline last summer, and had to replace these frame bolts as well, in order to be able to shim it out 1.5" so my 37s didn't rub. I cut out the old ones and replaced them with 2.5" 3/8 grade 8 bolts.
    The more I think about it, the more uneasy I am about installing a winch on smaller diameter frame bolts. I haven't had to use my winch yet. How has yours held up? Have you used it much under heavy load?
    I did read through this entire thread, but it was over the summer & I don't remember much. The folks at SSO recommended the 3/8" grade 8 replacement, right? They were sure the smaller bolts were strong enough to handle the load of a 12k winch?
  12. Feb 11, 2021 at 9:25 AM
    #672
    mgm16trdpro
    Northern NJ
    Hey Dave. I ended up not spacing the bumper out further to fit my large 35" Rockers. Instead I decided to trim a little off the front inside to get the clearance I needed. I opted for the faster and easier route. With a touch of trimming I was able to fit these 35s. I'm very confident if these 35s fit, any 35 will fit. I remember I spoke quite a bit with Dave Elkstrom aka coach builder. He was very helpful helping explain what I'd need to do to go that route. I think I relayed it in my thread but can't speak from experience since I just trimmed a bit off the back of front bumper lower section plastic and did a bmc. Wish I could help you more. If it comes down to what you need to trim I can help. It's quite possible if you go with a regular 35" tire or less offset and have the same lift you wont even need to trim anything.
    Oops my bad just reread you went 37s, never mind my last comment lol. To answer your other question I have winched other trucks and logs of firewood without problem, but again I didn't end up changing bolts. Your best bet is talk to Dave Elkstrom he's a wealth of knowledge and great guy.
    Uhhhh....[QUOTED] likes this.
  13. Feb 11, 2021 at 9:31 AM
    #673
    Uhhhh....
    Dave
    7” BDS, 37s
    Awesome sounds good thanks!
  14. Feb 11, 2021 at 9:39 AM
    #674
    mgm16trdpro
    Northern NJ
    Welcome.
  15. Dec 26, 2021 at 3:00 PM
    #675
    mgm16trdpro
    Northern NJ
    Damn I just realized I've neglected the hell out this thread.
    Here's how it sits today.
    Tires I've replaced with Toyo open country MTs in 35x12.5r17.
    I've also replaced the stock leaf spring with a set of Alcans stock +500. The rake is back and they're all around better in every aspect.
    I'm just about positive I've forgotten other stuff, but off the cuff, I can easily remember that.
  16. Dec 26, 2021 at 3:10 PM
    #676
    mgm16trdpro
    Northern NJ
    Sdhq sliders too.
    Ryuu and RainMan_PNW like this.
  17. Dec 26, 2021 at 3:40 PM
    #677
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    Looking good, neighbor.
    OEM leaf springs are joke.
  18. Dec 26, 2021 at 4:24 PM
    #678
    mgm16trdpro
    Northern NJ
    Thank u sir. Yeah especially with all the extra weight I have in and around the bed. I got my rake back, it handles better, and there's nowhere near as much squat when I'm towing. I definitely noticed a big improvement.
    So I'm guessing you're not my local buyer for some cheap oem leafs then lol.
  19. Dec 26, 2021 at 4:32 PM
    #679
    Piki
    Piki New Member
    Haha, I have one pair resting behind my house
  20. Dec 26, 2021 at 4:38 PM
    #680
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    How did you end up liking the pitbulls?
  21. Dec 26, 2021 at 5:14 PM
    #681
    mgm16trdpro
    Northern NJ
    Hey Frank. I loved them. Problem was I couldn't get them, even tried ordering directly from Pitbull. Told me they were out of stock and had no idea if and when would be getting them again. The traction on them was insane. You definitely heard them, but I've actually heard louder on other trucks. They road great too. I definitely planned on getting another set but was forced to look elsewhere.
    Berdine[QUOTED] likes this.
  22. Jan 5, 2022 at 2:56 PM
    #682
    klarmer
    klarmer Yotagirl
    VA
    2014 Tundra SR5 Crewmax
    @mgm16trdpro Question, where did that bed cover come from...I NEED THAT IN MY LIFE :spending:
  23. Jan 5, 2022 at 2:59 PM
    #683
  24. Jan 5, 2022 at 3:02 PM
    #684
    RobertD
    Robert
    DFW, Texas
    @klarmer
  25. Jan 5, 2022 at 3:56 PM
    #685
    mgm16trdpro
    Northern NJ
    You can find them occasionally secondhand. There's a fb group for them too. I wouldn't hesitate to buy from someone if it don't look beat up. They're pretty bullet proof. Don't ask me how I know since I backed out my garage with it up in the air, stopped me dead, no damage lol.
    I bought mine from manufacturer and they're one of the best companies out there to deal with. They've given me some free stuff and I'm not a sponsor or nothing, ie black out kit on hardware I still have sitting around.
    RobertD likes this.
