Medic's 2011 Platinum build
Discussion in '2nd Gen Builds (2007-2013)' started by Medic, Sep 3, 2014.
  1. Oct 10, 2014 at 5:27 PM
    #61
    Medic
    Medic [OP] New Member
    Ontario, Canada
    2014 Limited Crew Max
    Got this in the mail today.
    Thanks @Bob.
    Trying to figure out which side is better, any suggestions?
    T-Rex266 likes this.
  2. Oct 11, 2014 at 8:10 PM
    #62
    zac808
    zac808 New Member
    Zac
    2011 Crewmax 4x4 5.7L
    Bullbar, side steps, twenties, Corsa exhaust, K&N intake, Katskin interior.
    I personally like the drivers side.
    Kiddnapped Tundra likes this.
  3. Oct 11, 2014 at 10:00 PM
    #63
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Passenger side
  4. Oct 12, 2014 at 8:32 AM
    #64
    ODSteve
    ODSteve New Member
    Steven
    2012 Thundra SR5 TRD CrewMax
    K&N Filter, Low Profile tool box.
    Driver side passenger...what!
  5. Oct 13, 2014 at 4:52 PM
    #65
    Medic
    Ontario, Canada
    Update on next mod. Item has been shipped but is stuck in LA at the USPS sort facility. I couldn't wait for something to do so I tried some dipping.
    Finished product
    Super happy with results. I used one full can for all badges and mirror caps. Also kept the can of PlastiDip in a bowl of very warm water between coats. Made it very easy to keep even coats.
    Next on the list is the bumpers and maybe the rims.
    tat2ude39 and T-Rex266 like this.
  6. Oct 13, 2014 at 6:09 PM
    #66
    csuviper
    Broomfield, CO
    Looks much better
  7. Oct 17, 2014 at 7:34 PM
    #67
    Medic
    Ontario, Canada
    Last piece arrived early.
  8. Oct 18, 2014 at 6:09 PM
    #68
    csuviper
    Broomfield, CO
    What's the last piece?
  9. Oct 18, 2014 at 9:40 PM
    #69
    Medic
    Ontario, Canada
    Led light bar finally installed. Things you will need:
    Fused relay, wire, wire stripers, butt connectors, electrical tape, female crimp connectors, 3 amp in line fuse, 20 amp inline fuse, light bar and switch of your choice.
    I first mounted the light to make it easier to run the wire to where I was going to mount the relay. I ran the wire between the upper and lower bumper and then zip tied the covered wire to existing wiring harness and followed to battery and fuse panel.
    I used colored tape to keep wires identified.
    Connected ground and attached female connectors to wire end to connect to relay.
    Ran wire into cab via rubber boot with main wiring harness below steering wheel.
    I wanted to mount the switch beside the tow/ haul switch so the center console had to be taken apart:
    Step 1 Remove the long filler piece and cup holders.
    Step 2 Open center console and pull straight up at the front of the console. It does take alittle force but it lifts straight up.
    Step 3 Shift vehicle in neutral and remove gear shift knob. Remove small black screw and then lift up and back which removes the silver gear shift console with tow/ haul switch.
    Step 4 I used a wire tap to gain 12 volt power from the tow/ haul switch for both light activation and back light illumination of the switch. FYI the power on the tow/ haul switch is the green wire, second from top.
    Step 5 Push switch into removed blank space, connect the plug and play adaptor and reassemble the console.
    I used a switch from Aironboard.com. It was worth the price. Fit perfectly and the backlight works with the rest of the cabin lights.
    Finished product.
  10. Oct 18, 2014 at 9:41 PM
    #70
    Medic
    Ontario, Canada
    Got my Tundras sticker on too
  11. Jun 26, 2015 at 4:37 PM
    #71
    Medic
    Ontario, Canada
    Got dinged in the parking lot.
    Replacement taillight already installed so bulbs don't pop in the rain. Was given the go ahead to order the bumper.:D
    Hopefully it is here in a week according to Amazon.
    Black Wolf and T-Rex266 like this.
  12. Jun 26, 2015 at 4:41 PM
    #72
    Everyone is getting dinged! Glad I got mine over with last year.
  13. Jun 26, 2015 at 5:07 PM
    #73
    Sorry that happened. do you know how it got dinged? Are you going stock bumper?
  14. Jun 26, 2015 at 5:12 PM
    #74
    Medic
    Ontario, Canada
    Talked with other driver, young guy, going through insurance as it was parked. Going aftermarket bumper.
    T-Rex266, tat2ude39 and Black Wolf like this.
  15. Jun 26, 2015 at 7:42 PM
    #75
    Looks like a good positive end to a negative beginning.
  16. Jun 26, 2015 at 9:31 PM
    #76
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    What's your choice on rear bumper?
  17. Jun 27, 2015 at 4:02 AM
    #77
    Medic
    Ontario, Canada
    Smittybilt M1. It has two additional back up lights and holes are predrilled for the sonar sensors.
  18. Jun 27, 2015 at 9:13 AM
    #78
    Mike Tread lightly.
    south carolina
    Holy crap what is up with all the rear bumpers getting nailed in this short time.
    Black Wolf likes this.
  19. Jun 27, 2015 at 9:18 AM
    #79
    I wonder if I should just back up into a tree and get it over with. I have a low deductible. :devil:
  20. Jun 27, 2015 at 9:22 AM
    #80
    Mike Tread lightly.
    south carolina
    Not worth the expense and downtime and accident on the carfax report for the truck.
  21. Jun 27, 2015 at 9:25 AM
    #81
    Additionally:::It would be hard to explain having a back up camera and still stupid enough to hit a tree. :frusty:
  22. Jun 27, 2015 at 9:27 AM
    #82
    Mike Tread lightly.
    south carolina
    Back up camera is not working(broken). Problem solved.
    zcarpenter92 likes this.
  23. Jun 27, 2015 at 10:17 AM
    #83
    Medic
    Ontario, Canada
    I have another oops in tailgate that is getting fixed at same time from a tree. I also have a backup camera but truck was being driven by my mother. "I forgot about the camera."
  24. Jun 27, 2015 at 10:22 AM
    #84
    If your cameras contrast is not adjustable like mine, you can't see shit anyways unless you put your face right up to it. Looking for a decent replacement. I think they changed it after 07 because it sucked so much.
  25. Jul 2, 2015 at 8:18 PM
    #85
    Medic
    Ontario, Canada
    Need some assistance. I have a line on some very nice rims that are 20 x 10. My current tire size is 275/65r20 with factory platinum rims ( 20 x 8) and I understand that i will need a wider tire for the rims. That being said, I am wondering how much do rims drop in price once they are used? Estimated price for new is $1100. They are asking $850. Still waiting for estimated kilometer count on rims as well as all season use or just summers. Any and all comments welcome.
  26. Jul 5, 2015 at 6:42 PM
    #86
    Medic
    Ontario, Canada
    Got the truck ready for the body shop in the morning. Bumper came 2 days early too.
  27. Jul 5, 2015 at 7:17 PM
    #87
    csuviper
    Broomfield, CO
    All you members and your new rear bumpers
  28. Jul 7, 2015 at 9:38 AM
    #88
    Medic
    Ontario, Canada
    I miss my truck. The rental company gave me a Kia while mine at body shop. Not impressed.
  29. Jul 7, 2015 at 2:46 PM
    #89
    Mike Tread lightly.
    south carolina
    This board is starting to scare me off.
  30. Jul 7, 2015 at 9:00 PM
    #90
    csuviper
    Broomfield, CO
