Mark's 2015 Pro Build
Discussion in '2.5 Gen Builds (2014-2021)' started by dcsleeper408, May 9, 2016.
  1. Mar 8, 2018 at 4:50 PM
    #481
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    What spare? I don't have a spare.:anonymous:
  2. Mar 8, 2018 at 6:12 PM
    #482
    dcsleeper408
    dcsleeper408 [OP] BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    joonbug and GodlessPro[QUOTED] like this.
  3. Mar 8, 2018 at 6:12 PM
    #483
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Yeah. Right! WE have a spare ;)
    joonbug and 831Tun[QUOTED] like this.
  4. Mar 10, 2018 at 3:33 PM
    #484
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Putting in some tie downs on the bed
    Thanks @joonbug !
    Stupid factory bedliner.
    Best way to take it off clean is to score the bolt head around and a few on top of the head.
    Use a heat gun to soften it up.
    then just use some Needle nose pliers to pull off the liner.
    Also put on the total chaos bed stiffs.
  5. Mar 10, 2018 at 3:43 PM
    #485
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    @dcsleeper408 sucks some techs are just way too lazy to remove the fasteners when they spray the liner. Luckily my factory liner didn’t spray the screws. But they didn’t take off my bed rail so when I remove my bed rail there is mgm paint under it lol. Fail.
  6. Mar 10, 2018 at 4:13 PM
    #486
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Lol ya they masked off patches under my rail.
    joonbug, 831Tun and GodlessPro like this.
  7. Mar 10, 2018 at 4:20 PM
    #487
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Not expecting people like us to F with it
  8. Mar 10, 2018 at 4:27 PM
    #488
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Heat gun is a good idea. I'm having trouble getting the bolt out. It starts coming out and then I get a loud popping sound. Should I just keep going? I got scared and screwed it back in.
  9. Mar 10, 2018 at 4:43 PM
    #489
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah, you’ll get a few popping sounds. Don’t worry about it. Oh, and that washer doesn’t separate from the bolt. Might be good to know that has to come out too.
  10. Mar 10, 2018 at 4:46 PM
    #490
    GodlessPro
    Matthew
    NorCal
    Thanks I'll give it another shot.
  11. Mar 10, 2018 at 4:46 PM
    #491
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Heat just makes it soft for scoring and prettyness.
    You’ll be fine though mine did pop. Just some bed creak, I though the bed might shift bc I took all 4 out the same time..
    You using the T55 right?
  12. Mar 10, 2018 at 4:47 PM
    #492
    GodlessPro
    Matthew
    NorCal
    Yes T55
  13. Mar 10, 2018 at 4:48 PM
    #493
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Yeah u good! Get er done!
  14. Mar 10, 2018 at 6:07 PM
    #494
    BlueBottle
    '16 Platinum 4x4
    See fine print
    dcsleeper408[OP] likes this.
  15. Mar 10, 2018 at 6:18 PM
    #495
    Tundra9831
    Tundra9831 New Member
    When I got my Tundra LineX done in San Jose they said they remove the bed bolts on many trucks, but for whatever reason Tundras occasionally have a bolt that has stripped threads and it won't go back in correctly. I think they said maybe 1 in 10 Tundras has that happen so they like to warn people ahead of time. No difference in cost, but it is obviously easier for them to spray over the bolts. Based on that info I decided to have them spray over the bolts. I'm just the messenger....not sure if it's accurate.
  16. Mar 10, 2018 at 6:28 PM
    #496
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Yeah I’m sure they just shoot em in at the factory.
    Taking it off is not that hard. Doing it nice just takes a little time.
  17. Mar 10, 2018 at 7:25 PM
    #497
    TheBeast The Beach
    looking good. damn you BASTRDS guys getting ready.. :spy: :spending::spending:
  18. Mar 11, 2018 at 12:43 PM
    #498
    GodlessPro
    Matthew
    NorCal
    I read this multiple times, saw what you did in your build thread, read the d-ring DIY thread, and still couldn't get the bolts out. I just reread this again and it clicked "that washer doesn't separate from the bolt." I am so dense.
    I wanted to put the d-ring between the washer and bolt, oh well I guess I'll have to do it the same way as everyone else. Except that I don't have a way to notch the washer, so this is back on hold like everything else.
    joonbug[QUOTED] likes this.
  19. Mar 11, 2018 at 2:45 PM
    #499
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah I knew the washer was your problem. Screw it, just score around the washer like Mark did.
    GodlessPro[QUOTED] likes this.
  20. Mar 11, 2018 at 8:06 PM
    #500
    Eclipsed & Floating
    Voluptuous Whitey
    @dcsleeper408
    WhAt did you use to mount your Rotopak inside the bed? Bed rails? What was used to drop it from the rail?
    dcsleeper408[OP] and zackbremer like this.
  21. Mar 14, 2018 at 8:22 AM
    #501
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    joonbug and GodlessPro like this.
  22. Mar 14, 2018 at 8:27 AM
    #502
    GodlessPro
    Matthew
    NorCal
  23. Mar 14, 2018 at 8:31 AM
    #503
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    lol shit.
    Zip ties will hold it in place.
    Thanks Matt! :cheers:
  24. Mar 14, 2018 at 8:43 AM
    #504
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    It’s gonna be pretty funny if it never falls off on Mark’s truck. :p
    GodlessPro and dcsleeper408[OP] like this.
  25. Mar 14, 2018 at 8:46 AM
    #505
    GodlessPro
    Matthew
    NorCal
    Funny isn't the word I would have chosen :mad:
  26. Mar 14, 2018 at 8:47 AM
    #506
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    :rolleyes:
    On a good note DV is 2 weeks away! :yes:
  27. Mar 14, 2018 at 8:50 AM
    #507
    GodlessPro
    Matthew
    NorCal
    :bananadance::dancingbacon::broccoli::kona::yes:
    And also :censored: I'm not ready yet.
  28. Mar 14, 2018 at 8:52 AM
    #508
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    what else is on the list?
    joonbug likes this.
  29. Mar 14, 2018 at 8:54 AM
    #509
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I can’t believe it’s only 2 weeks away and it’s still snowing there. And they’re getting some rain. We’re going to encounter some washouts.
    TheBeast likes this.
  30. Mar 14, 2018 at 8:54 AM
    #510
    GodlessPro
    Matthew
    NorCal
    I'm going to trade in my truck and start over. Is 2 weeks enough time to order new sliders?
