Mark's 2015 Pro Build
Discussion in '2.5 Gen Builds (2014-2021)' started by dcsleeper408, May 9, 2016.
  1. Feb 16, 2018 at 1:36 PM
    #331
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    or you could have @dcsleeper408 swap the shocks again so it will take care of the yota lean :stirthepot: :spy: :rofl:
  2. Feb 16, 2018 at 1:40 PM
    #332
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
  3. Feb 16, 2018 at 1:48 PM
    #333
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    No
  4. Feb 16, 2018 at 1:53 PM
    #334
    dcsleeper408
    dcsleeper408 [OP] BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Ew... Kansas owner...:puke:
    joonbug likes this.
  5. Feb 16, 2018 at 2:29 PM
    #335
    BlueBottle
    '16 Platinum 4x4
    See fine print
    psshhhh.... you want a Castro owner instead??/
  6. Feb 16, 2018 at 9:36 PM
    #336
    Eclipsed & Floating
    Voluptuous Whitey
    Zackbremmer is over on PLC721’s thread talking intelligently with massive amounts of experience about the differences in leaf packs. He’s comparing the RXT to the Deavers and the physics of why they handle differently
  7. Feb 17, 2018 at 5:57 AM
    #337
    XPTUNDRA
    XPTUNDRA New Member
    North MS
    2016 Tundra Limited
    4" Pro Comp Lift 35x12.50x20 Toyo RT's 20x9 +20 Fuel Mavericks Rough Country soft tri-fold bed cover LED headlight and Fogs with LEDs throughout the cab as well
    Absolutely awesome build from day 1. Everything is fit form and functioned perfectly.....
    Love it. Great job, and love the pictures of the travels and family. Nicely done
    dcsleeper408[OP] likes this.
  8. Feb 18, 2018 at 9:26 PM
    #338
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Appreciate the kind words brotha!!
    joonbug and XPTUNDRA[QUOTED] like this.
  9. Feb 18, 2018 at 9:33 PM
    #339
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Wired up the bajas earlier today went to beam them. This is with the wide corners amber.
    Just the bajas
    Bajas,retros, and halogen fogs
    Baja,led bar, retros, halogen fogs on
    Thanks @BlueBottle for hooking it up! :hattip:
    joonbug and BlueBottle like this.
  10. Feb 18, 2018 at 9:35 PM
    #340
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Dang the bajas overpower the retros. Good to know they don’t reflect back on the hood. Big difference from the bwahas? Should have done a before/after!
  11. Feb 18, 2018 at 10:45 PM
    #341
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Ya pretty big difference. I’m thinking of trying the clearance out sometime this week.
    I gave my side shooters away. Would’ve been nice to see he difference
    joonbug and BlueBottle[QUOTED] like this.
  12. Feb 18, 2018 at 11:04 PM
    #342
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    someone on the other side of that fence is waiting for the SWAT team to come crashing through the door.:rofl::rofl:
  13. Feb 19, 2018 at 1:49 AM
    #343
    zackbremer
    zackbremer New Member
    Da Z
    read all 12 pages...awesome build so clean and has all the lil things done just right to make it super clean and capable...love the white, youre killing it
    dcsleeper408[OP] and XPTUNDRA like this.
  14. Feb 19, 2018 at 7:44 AM
    #344
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Thanks man! I've been itching to to that camburg rear like yours.
    joonbug likes this.
  15. Feb 19, 2018 at 7:13 PM
    #345
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Antenna mount welded in!
  16. Feb 19, 2018 at 7:18 PM
    #346
    BlueBottle
    '16 Platinum 4x4
    See fine print
  17. Feb 19, 2018 at 7:24 PM
    #347
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    That is a great spot. I thought your tent was too big.
  18. Feb 19, 2018 at 7:53 PM
    #348
    zackbremer
    Da Z
    lol careful its a slippery slope once u go down that rabbit hole
    that kit requires a lot of fabrication hours since both upper and lower shock mounts are relocated....people running deaver springs or the new ICON RXT springs is personally what i would go with and the ADS triple bypass see a huuuuuuge peformance improvement and its all bolt on..i just didnt want a franken truck so in order to keep it all king i had todo something else with the rear.
    either way bypassess = go fast
  19. Feb 19, 2018 at 8:12 PM
    #349
    zackbremer
    Da Z
    A leaf pack(deaver icon alcan etc) + ads bypass = about half the cost of my rear end simply cus there is no fabrication or cycling of the suspenion required unless u add hydro bumps...you can do it in the driveway without a welder or a couple grand cash to pay a fab guy lol
    dcsleeper408[OP] and TheBeast like this.
  20. Feb 19, 2018 at 9:26 PM
    #350
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Definitely feel you on the Frankentruck part. Some parts work well with each other and some just don’t.
    RXT’s is choice option just because I can up weight load on the fly. I’m not so much go fast all day, this is now my daily as I sold my taco, and still need it to be my main workhorse.
    Hydro is a must especially if I go all out and LT the truck, I’ve experienced some nasty buck- I’ve been on this buck be gone phase. Or just drive slow..
  21. Feb 19, 2018 at 9:28 PM
    #351
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    The tent clears this area. I just have to be careful if I am drunk packing it or unpacking it.
    joonbug and GodlessPro[QUOTED] like this.
  22. Feb 20, 2018 at 7:34 AM
    #352
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    What are you running up front?
    joonbug likes this.
  23. Feb 20, 2018 at 7:07 PM
    #353
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Painted the nmo antenna mount routed the the cable. Almost short but just enough with a little bit slack left.
    Radio finally wired up to the switch pro and programmed.
    Also put in the OME abs/brake line extenders.
    Before
    After
    831Tun, joonbug, BlueBottle and 2 others like this.
  24. Feb 20, 2018 at 9:00 PM
    #354
    zackbremer
    Da Z
    things and stuff
  25. Feb 20, 2018 at 9:07 PM
    #355
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    That's BA! Gusseted spindles and all.
  26. Feb 20, 2018 at 9:08 PM
    #356
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Nice! That is MT right. I don’t see and tie rod extension.
    joonbug and zackbremer[QUOTED] like this.
  27. Feb 20, 2018 at 9:10 PM
    #357
    zackbremer
    Da Z
    its stock LCA no need for extended axles or tie rods, although the stock tie rod is def a limiting factor, i need to upgrade to the coach builder tie roads and maybe get a lil more droop since his are good to 27 degrees and stock are 19degrees
  28. Feb 20, 2018 at 9:12 PM
    #358
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I've got the CBs. They can limit caster since they're fat and straight and can hit the spring perch. But, you probably knew that already.
    joonbug likes this.
  29. Feb 20, 2018 at 9:14 PM
    #359
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Nice! I couldn’t tell. Why not do full LT? I would like to pick your brain on this if you don’t mind.
    joonbug likes this.
  30. Feb 20, 2018 at 9:15 PM
    #360
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Are your factory length Warren? They are really beefy like his shackles
    joonbug and 831Tun[QUOTED] like this.
