Marker lights on tow mirrors won't work
Discussion in '3rd Gen Tundras (2014+)' started by Spoony1, Feb 14, 2017.
  1. Feb 21, 2017 at 2:13 PM
    Cat3ILS
    Cat3ILS The cheese goes on the bottom bun
    2014 platinum CrewMax 4x4 5.7L - white
    2.5 level, 285 Toyo OC, Or-Fab trans/cat skid, X2 Revolver, ESP storage, Husky's, Lock'er Down safe, OCD organizer, Interior LED's (red drivers), Glove and safe motion LED's, Rhino lined
    Thanks, IIRC they don't offer auto dim which I also wanted.
    Jsena likes this.
  2. Feb 21, 2017 at 2:53 PM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    I don't think any of the tow mirrors, aftermarket or OEM have auto dim. I too was disappointed about that.
    Cat3ILS likes this.
  3. Feb 23, 2017 at 10:13 PM
    Paulskie
    Paulskie New Member
    Paul
    2014 Attitude Black 1794
    SABM, TRD sway bar, interior LED swap, Husky's in front and WeatherTech in the back, TRD Pro Grill, Rigid Fod lights, Rigid 40" E-series, Rigid 32" hood light, BLHM with RX350/STI projectors, 4% tint, 50% windshield.
    Same here, but to gain the additional spot mirrors that look factory is a huge plus
    Jsena likes this.
  4. Mar 20, 2017 at 11:32 AM
    canadiancrewmax
    canadiancrewmax New Member
    Morgan
    2014 CREWMAX Platinum
    3/2 ready lift, 285/65R20 KO2, Tow Mirrors, TRD Dual Exhaust, tint
    Hey guys, new to this forum. I have a 2014 platinum Crewmax that i just installed 1Aauto mirrors, BSM, heat, power, power fold, memory, and turn signals all work. As everyone else mentioned, the running lights/marker lights do not work. It came with an extra wire to wire into an existing circuit to make those lights work. Does anyone know where i can find the wires to tap into so they work with my marker lights?
  5. Mar 23, 2017 at 3:35 PM
    Flobrandx
    Flobrandx New Member
    Brandon
    2015 TRD PRO
    Working on them now...
    I was just going to order these as the price is great but the shipping cost is unbelievable! $104 to ship to WA! I'm gonna have to look elsewhere...
  6. Mar 23, 2017 at 4:01 PM
    MotoTundra
    MotoTundra The Ocho
    I did not know this. I have an SR5 so I did gain the running lights and blinker. That is so odd that the higher trim levels are different.
    Jsena and RowdyRon like this.
  7. Mar 24, 2017 at 7:04 AM
    sawzalot
    sawzalot New Member
    14' Tundra D Cab 4x4 4.6 L
    Tonneau Cover
    Can one of you fine upstanding members tell us the overall dimension of the tow mirror as in how much further does the unit extend from the truck than the original mirror , I have seen some tow mirror mods around here on Dodge Rams and they look stupid as they are just too far out from truck , Thanks , sawz.
  8. Mar 24, 2017 at 9:47 AM
    SOB
    SOB Big Member
    Ohio
    Measured from the truck to the bottom of the tow mirror mine measure 7.5" retracted and 11.5" extended. However, these are the 1AAuto aftermarket mirrors. I do not know what the original mirror distance was but these def sit further out when retracted. I would imaging they sit out a good 2-3" further. I too hate the look of the Ram mirrors when they are flipped out (vertical). Just saw another one today and thought it looked like stupid ears sticking out.
    sawzalot and RowdyRon like this.
  9. May 30, 2017 at 1:05 PM
    Badmanrick
    Badmanrick New Member
    Rick
    2017 Tundra Platinum 4x4
    Well guys it appears that Toyota has screwed us again. You would think that when you buy a Platinum Tundra with a towing package as standard equipment they would have the correct towing mirrors to match.
    I purchased a Platinum and now I am pissed. The only after market tow mirrors I found that May fit the Platinum mirrors look like crap. It appears that the Platinum mirrors are larger than the standard tundra mirrors. No custom slip on mirrors will fit the Platinum. Bummer.
    What will it take for Toyota to comply with the towing standards and offer the correct towing mirrors for the Platinum.
    Here is what needs to be done
    Make the new towing mirrors for the Platinum, chrome, BSM, auto dim, heated, turn signal, clearance lights, puddle lamps, power mirrors with memory, and power fold. HOW HARD CAN THIS BE?
  10. May 30, 2017 at 1:13 PM
    Badmanrick
    Rick
    Another thing I've been advised about the factory tow mirrors is The wiring on the 2017, 1794 and Platinum are different because of the puddle lights and other functions. You lose the clearance lights on the factory tow mirrors and you lose the BSM, AUTO DIM and power fold functions. You keep the turn signal.
  11. May 30, 2017 at 1:13 PM
    Jsena
    Jsena The 1 who cares the least has the Power
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I heard OEM doesn't have BSM with their tow mirrors
  12. May 30, 2017 at 1:17 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    What did that cost for mirrors ans paint ??
  13. May 30, 2017 at 1:31 PM
    Spoony1
    Spoony1 [OP] New Member
    2016 tundra platinum crewmax
    Trd pro grill color match door handles and mirror. 4 1/2 bds lift
    I think they were right around $1,000.00
    Jsena likes this.
  14. May 30, 2017 at 1:44 PM
    16tunterd
    16tunterd Got wood?
    Warren
    Santa Cruz
    '16 CM limited
    ADS C/O w/clickers, Camburg UCA,Fox 2.5 w/dsc rear, Toytech shackles, chrome delete, Pro grille, TRD dual exhaust, de-badged, black LED tail lights. BHLM w/projectors, 295 70 18 Cooper STT pro on stock rims w/1.25" Spider Tracks. Morimoto fogs, 13" antenna x, RCI skid,
    I believe you're correct and I was mistaken. BSM, I believe, is not available on OEM tow mirrors.
    Jsena likes this.
  15. May 30, 2017 at 2:29 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Pricey, they look good tho
