Marker lights on tow mirrors won't work
Discussion in '2.5 Gen Tundras (2014-2021)' started by Spoony1, Feb 14, 2017.
  1. Feb 14, 2017 at 7:56 PM
    Spoony1
    Spoony1 [OP] New Member
    2016 tundra platinum crewmax
    Trd pro grill color match door handles and mirror. 4 1/2 bds lift
    So I just installed my painted to match tow mirrors I think they look great but I can't get the marker lights to work. Any ideas what I could be doing wrong?image.jpg
  2. Feb 14, 2017 at 7:58 PM
    Wire connector plugged in?
  3. Feb 14, 2017 at 8:04 PM
    chphilo
    chphilo Tundra addict
    Western PA
    My understanding is with SR5, you gain marker light and signal light. With upper trims, you lose functions, including marker light, at least without some more wiring. Doesn't make sense, I know.
    Jsena likes this.
  4. Feb 14, 2017 at 8:07 PM
    U really lose the marker n turning lights on tow mirrors with higher trim models???
    Jsena likes this.
  5. Feb 14, 2017 at 8:12 PM
    chphilo
    Western PA
    From what I understand, you lose the marker light. You still get the signal light, heat, etc. No BSM function either.
    Krezz likes this.
  6. Feb 14, 2017 at 8:15 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'm pretty sure you can get the tow mirrors with BSM both OEM and at autoanything or whatever they're called.
    Jsena likes this.
  7. Feb 14, 2017 at 8:17 PM
    supermotobobby
    supermotobobby New Member
    Bobby
    2022 Tundra Platinum 4x4
    Take a picture of the connector plugged into the mirror. I have a 2010 Limited and everything works except the marker lights. Well actually the right marker light, because I just finished the left side. Take a few close ups of the plug and post them.
  8. Feb 14, 2017 at 8:21 PM
    chphilo
    Western PA
    I did read about after-market non-Toyota tow mirrors that claimed to work with BSM function. I saw that for the first time quite recently. I have no idea how well they work (I haven't seen any review). I was talking about Toyota tow mirrors. I should've made that clear.
    Krezz likes this.
  9. Feb 14, 2017 at 8:26 PM
    Spoony1
    I think I will call the dealership tommorow I knew the BSM wouldn't work but it is hard to believe with oem mirrors that the marker lights wouldn't work when everything else does. They come on when I start truck but go off right away,seems like there should be some kind of setting change that would correct this but who knows.
  10. Feb 14, 2017 at 8:27 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I read about them very recently too. But, Toyota doesn't offer tow mirrors with BSM? I thought they did but I could be wrong. I've been thinking of changing to tow mirrors and I have the BSM. I definitely would not switch if it would negate that feature, too easy for little cars to hide in that blind spot on the right rear quarter.
    757TUNDRA likes this.
  11. Feb 14, 2017 at 8:29 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I'm interested in what you find out about this. Thanks for posting.:popcorn:
  12. Feb 14, 2017 at 8:35 PM
    Spoony1
    I knew the BSM wouldn't work that dosen't matter to me with the big split mirrors on the tow mirrors I really don't think it will be a problem but the marker lights are there I would think they should work.
  13. Feb 15, 2017 at 5:25 AM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
  14. Feb 15, 2017 at 9:27 AM
    sk8142
    sk8142 New Member
    Shawn
    WA
    2014 Black Tundra TRD
    Bilstein 5100 F&R - Front middle setting w/2 CB shims Toytec rear shackles @ 1" setting Method NV 18x9 +25 Bronze 295/70/18 Nitto Ridge Grappler Retrofit headlights with Morimoto DS2 4.0, Apollo 3.0 shrouds, switchbacks Prodigy P3 brake controller
    I'm not sure about the marker lights functionality on upper trim levels but my OEM tow mirrors do have running lights on my SR5. That's pretty crazy if they truly don't work on the upper trim levels...
  15. Feb 15, 2017 at 9:41 AM
    duerj70
    duerj70 New Member
    2017 Tundra 1794 Super White
    I have the tow mirrors from 1aauto on my 17 1794 and the BSM and the turn signal works but you have to wire up and accessory wire to get the clearance light to work.
    Billytx likes this.
  16. Feb 15, 2017 at 9:52 AM
    geno0506
    geno0506 New Member
    Michael
    So you mean with my SR5 CM, I actually gain a luxury that I lost from not getting a Platinum or other tiger model! If so where would I get one of these awesome tow mirrors and are they hard to swap out with my SR5 meaning PNP easy install!
  17. Feb 15, 2017 at 11:02 AM
    chphilo
    Western PA
    Yes. It is a simple swap. I love those running lights and signal lights.
    You could either get Toyota oem mirrors or an after-market ones, such as 1A Auto. Toyota mirrors are about the twice the price, but I opted to go with Toyota tow mirrors because of some reports of vibration of non-Toyota mirrors. Toyota mirrors are rock solid (worth the money, IMO).
    geno0506[QUOTED] likes this.
  18. Feb 15, 2017 at 11:12 AM
    geno0506
    geno0506 New Member
    Michael
    Thanks
    Do you have a link where you got yours!
  19. Feb 15, 2017 at 11:21 AM
    chphilo
    Western PA
  20. Feb 15, 2017 at 4:16 PM
    Spoony1
    Talked to the dealer today apparently it is true with the oem Toyota tow mirrors when they are installed on a platinum or 1794 edition the marker lights will not work with the existing wiring. The good news is I don't think it is going to be hard to rewire. By the way I got my mirrors from Rowman he had them painted to match for me and did a great job we are definitely lucky to have him on this forum .
    Jsena and MotoTundra like this.
  21. Feb 15, 2017 at 4:30 PM
    geno0506
    geno0506 New Member
    Michael
  22. Feb 15, 2017 at 4:37 PM
    geno0506
    geno0506 New Member
    Michael
    So if I get these, I would get the signal and running lights to work on my 2017 SR5 CM, I would loose the power mirror function though, correct!
  23. Feb 15, 2017 at 4:52 PM
    chphilo
    Western PA
    Power mirror adjust still works with tow mirrors. If you have mirror heater (cold weather package), heater works also. For SR5, you don't lose any functions. You just gain signal lights and running lights.
  24. Feb 15, 2017 at 4:53 PM
    geno0506
    geno0506 New Member
    Michael
    way too awesome, thanks bro!
  25. Feb 17, 2017 at 4:39 AM
    SOB
    SOB Big Member
    Ohio
    Does anyone know what wiring needs added to the upper trim levels to gain the running lights? Installed mine this week from 1AAuto and everything works (signal, heat, power fold) except the side running light.
  26. Feb 20, 2017 at 8:21 AM
    MrBill757
    MrBill757 New Member
    MrBill
    2015 Tundra
    A1Auto told me Friday that when replacing stock mirrors with towing mirrors, it must be apples to apples. I had inquired about any of their towing mirrors being compatible with my Platinum. I was told no, they will not "work". At this point I'm wondering if you can't even make any electrical connections, or perhaps you will lose a few features with the replacements. Do you have a platinum? I noticed your mirrors are chromed. I haven't been able to find any chrome mirrors either. They're all black and incompatible as well.
  27. Feb 20, 2017 at 9:01 AM
    Spoony1
    I have a platinum and bought oem Toyota mirrors I knew I would lose my BSM but my marker lights don't work either. Spoke to Toyota and apparently there is none available that everything will work on the platinum or 1794 edition. I am 90% sure when I get time I will be able to wire the marker light so that they will work. I am not sure about A1auto but from Toyota I believe the mirrors only come in black. I ordered mine from Rowman and had them painted to match.
  28. Feb 20, 2017 at 2:56 PM
    Cat3ILS
    Cat3ILS The cheese goes on the bottom bun
    2014 platinum CrewMax 4x4 5.7L - white
    2.5 level, 285 Toyo OC, Or-Fab trans/cat skid, X2 Revolver, ESP storage, Husky's, Lock'er Down safe, OCD organizer, Interior LED's (red drivers), Glove and safe motion LED's, Rhino lined
    I want tow mirrors but won't give up the BSM. It's crazy that Toyota didn't make this compatible. Regardless, I've been looking for a way to add a BSM warning light to the inside of the cabin, maybe on the plastic mirror panel, so that it's easier to view. If anyone knows a way to do this those of us wanting BSM and tow mirrors (or just a more obvious BSM alert) would be indebted.
    Jsena likes this.
  29. Feb 21, 2017 at 4:43 AM
    SOB
    SOB Big Member
    Ohio
    Yes, I have a platinum. My pic hasn't been updated since the addition of the tow mirrors - still shows the factory chrome. I personally like that the tow mirrors are black as I thought the factory chrome mirrors was too much chrome.
  30. Feb 21, 2017 at 4:44 AM
    SOB
    SOB Big Member
    Ohio
    1AAuto has tow mirrors with BSM.
