Magnuson 2650 ordered 9/14
Discussion in 'Performance and Tuning' started by carn_dogg, Sep 15, 2023.
  1. Sep 20, 2023 at 11:46 AM
    #61
    carn_dogg
    carn_dogg [OP] i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    Sounds like the difference between a cheap wheel spacer and a hubcentric wheel spacer.
  2. Sep 23, 2023 at 10:15 AM
    #62
    carn_dogg
    Pat
    Eastern Shore MD
  3. Sep 23, 2023 at 5:45 PM
    #63
    carn_dogg
    Pat
    Eastern Shore MD
    Thinking about this pillar pod and two gauges for monitoring boost and afr.
    Ginsterkev likes this.
  4. Sep 23, 2023 at 5:50 PM
    #64
    carn_dogg
    Pat
    Eastern Shore MD
    Contemplating this as well. Was never a huge fan of these devices but feel it might be nice addition with the SC install. I’ve read through the pedal monster thread and it sounds like most banks (if not, all) users are very satisfied- regardless if using from stock upgrade vs moving over from a competitors product.
  5. Sep 23, 2023 at 6:55 PM
    #65
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    No need for the pedal monster if you get a tune done. The pedal feel can be adjusted in the tune. The color on the pillar pod didn’t match when we ordered it but maybe you’ll have better luck
  6. Sep 23, 2023 at 7:01 PM
    #66
    carn_dogg
    Pat
    Eastern Shore MD
    Good to know about the pedal feel. Thanks
    you ordered a pillar pod from them and the color didn’t match stock? That’s a bummer… for 300$ I’d expect a nice color match.
  7. Sep 23, 2023 at 7:09 PM
    #67
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Correct.
  8. Sep 23, 2023 at 7:12 PM
    #68
    carn_dogg
    Pat
    Eastern Shore MD
    Any pics?
    Did you keep and install or return?
  9. Sep 23, 2023 at 8:13 PM
    #69
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    It’s on the old man’s rig he kept it. Pics attached. You may need to drill out or enlarge the hole in the back to feed the wiring. The paint is also fragile and chips easily
  10. Sep 24, 2023 at 5:38 AM
    #70
    carn_dogg
    Pat
    Eastern Shore MD
    That's not too bad.
    I'm more concerned with if the 2nd gen versions retain the handle on the pillar. Looks like there is a 1 pod and 2 pod version. I reached out to the manu and will report back so others know. I ordered the analog innovate boost gauge - thinking I can get away with monitoring afr via torque app on my HU
  11. Sep 24, 2023 at 6:23 AM
    #71
    carn_dogg
    Pat
    Eastern Shore MD
    ViktorG and reywcms like this.
  12. Sep 24, 2023 at 6:59 AM
    #72
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    Is the pillar mount not a concern as far as making the gauge pods projectiles if the curtain airbags deploy?
    Saltyhero13 likes this.
  13. Sep 24, 2023 at 7:06 AM
    #73
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
  14. Sep 24, 2023 at 7:14 AM
    #74
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Damn it
    I went to the cravenspeed site and they have nice scanguage 3 mount
    Thanks a lot!
    it never ends
    Saltyhero13 and reywcms like this.
  15. Sep 24, 2023 at 7:20 AM
    #75
    carn_dogg
    Pat
    Eastern Shore MD
    My understand of the side curtain airbag deployment is that it’s designed to let the plastic go forward towards the windshield so the airbag can be deployed toward the driver. That being said, I get that any object flying around during an accident in any manor is not ideal.
    I’m certainly not sold on it, but toying with the ‘options’
    Silver17[QUOTED] likes this.
  16. Sep 24, 2023 at 7:23 AM
    #76
    carn_dogg
    Pat
    Eastern Shore MD
    To each their own, but I’m not a huge fan of them. I had a similar style mount on my e46 and thought it was ok- simply for lack of a better solution.
    On the truck, I think I’m only going to run 1 gauge for boost, so def don’t want a single ear sticking up. Just not my cup of tea.
    May have to hold the gauge in different places in the truck once it arrives to see what I like and what is easily visible while driving without taking my eyes off the road.
  17. Sep 24, 2023 at 7:32 AM
    #77
    nobodyintexas
    nobodyintexas What?
    South of Houston
    agreed
    I have the driver side handle. so....I can't mount it there. Craven was 2nd best.
    a while back, someone posted a doo-dad that mounted to the lower screw of the handle. looked nice, but I think it was just for the Tacoma.
  18. Sep 24, 2023 at 7:33 AM
    #78
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Unless you're talking about tying in an aftermarket AFR gauge to the torque app (which sounds hard to do but I'm not an electrical engineer), then that option doesn't buy you much. If you're using the stock afr sensors they have a limit of how rich they can read, and even at max rich it's too lean so you'll only vaguely know the truck richened out but not if it was enough.
  19. Sep 24, 2023 at 9:39 AM
    #79
    carn_dogg
    Pat
    Eastern Shore MD
    Water pump and thermostat ordered cause why not when my existing has 162k on it and I’ll have the access when doing the SC Install. Seems like good housekeeping.
  20. Sep 24, 2023 at 9:41 AM
    #80
    carn_dogg
    Pat
    Eastern Shore MD
    Any idea what the full range of the oe pre cat o2 will read?
    edit: quick searches tell me the stock pre cat o2 can show between 11:1 rich and 18:1 lean. I’m ok with that range as that will tell me the most important piece, whether the truck is running too lean at wot (or anytime really)
  21. Sep 24, 2023 at 10:07 AM
    #81
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    I don’t think it reads richer than 11.9. That’s the lowest I’ve seen displayed on my Scangauge 2.
  22. Sep 24, 2023 at 10:24 AM
    #82
    Silver17
    Northeast
    Yup 11.9 is the richest it will read, which is not rich enough for a boosted 3UR.
    reywcms likes this.
  23. Sep 24, 2023 at 10:37 AM
    #83
    carn_dogg
    Pat
    Eastern Shore MD
    Ordered
    snivilous likes this.
  24. Sep 24, 2023 at 12:02 PM
    #84
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
  25. Sep 24, 2023 at 12:05 PM
    #85
    ViktorG
    Viktor
    Calgary, Canada
    The A-pillar trim is bolted to the A-pillar with 2x10mm bolts, it does not fly off when the curtain shield airbag deploys, so I think it’s pretty safe to put gauges there.
  26. Sep 24, 2023 at 12:05 PM
    #86
    carn_dogg
    Pat
    Eastern Shore MD
    Oh yea I think the autometer gauges are garbage. Went with innovate gauges. Was torn between them and aem, but ended up liking the analog innovate gauge the best and wanted them both to be the same brand
  27. Sep 25, 2023 at 3:23 AM
    #87
    carn_dogg
    Pat
    Eastern Shore MD
    Does anyone know what size this connector needs to be?
    image uploader
  28. Sep 25, 2023 at 4:30 AM
    #88
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    You won't need this with a SC, IMO. I had the Pedal Commander before I SCd. Got rid of it after.
  29. Sep 25, 2023 at 5:33 AM
    #89
    nobodyintexas
    nobodyintexas What?
    South of Houston
    agree.
    the pedal commander & similar devices are for those poor souls without a S/C.
    it is blasphemy to use it with a blower.
    Tow/Haul does whatever you may need in times of boredom.
  30. Sep 25, 2023 at 6:23 AM
    #90
    carn_dogg
    Pat
    Eastern Shore MD
    Haha - good to know.
    I won't be buying it.
    Going to spend the $300 on ortiz custom a pillar dual pod instead.
    nobodyintexas likes this.
