Magnuson 2650 ordered 9/14
Discussion in 'Performance and Tuning' started by carn_dogg, Sep 15, 2023.
  1. Sep 20, 2023 at 5:45 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Oh, another thing to mention. When going with an aluminum radiator, be careful when you're under the hood if the engine has been running. I don't know how many time my forearm has touched the radiator when it's hot. I've been meaning to come up with a plastic guard or something to prevent it.
    Saltyhero13 likes this.
  2. Sep 20, 2023 at 5:49 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    RE: Upgrades - Depends on how you want to use your truck and where you live.
    I think @reywcms is running a relocation kit since he bajas. If you run through water/dust probably a good idea.
    Radiator upgrade if your engine runs hot. I've not seen significant heat but I don't track/tow. Stock is overbuilt and more than enough IMO for my use case. I've seen people run the upgraded thermostat (lowers op temps to 180) and external oil coolers (more complexity).
    Coolant tank if you are doing back to back runs to delay high IATs, catch is it will take longer to cool down once it is saturated. There is also killerchiller or the interchiller (think that is the correct name)
    reywcms likes this.
  3. Sep 20, 2023 at 6:50 AM
    carn_dogg
    carn_dogg [OP] i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    OK Thanks. So 440 (approx) for this radiator. Mishimoto just seems appealing for their lifetime warranty but I don't like their plastic mounting brackets... while CSF is all aluminum through and through with similar pricing to the Koy. Thanks.
    I live in MD. Summers are 90-100 F highs with winters being 20ish F lows. Truck is used for hauling the family, dump runs, towing, trails in the area and camping, family vacations if we don't take our X5. Looking to buy a TT next year too - nothing huge, maybe 20-25ft LOA and no more than 7k gross weight.
    My interpretations of your response (for my application)
    - SAI relocation kit, not needed
    - Aluminum Radiator, play by ear. Run stock and monitor temps. Replace/Upgrade if needed. No use spending money just to spend money.
    - Billet Coolant Tank, stock tank with kit should be fine. Take action to replace/upgrade if needed.
    - External oil cooler, not needed. I have OE tow pkg with my 13 and see no need for another external (or upgraded/larger) oil cooler
    Thanks!
  4. Sep 20, 2023 at 6:51 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    No need for your use case to run the secondary intake relocation kit from SDHQ. Only reason to do it is if you’re really offroading and have no fender liners. Save the money there.
    As far as radiators I would also leave the stock unit in. The aftermarket ones break ALL THE TIME. Tabs, leaks at the welds etc. Everyone who’s had one I know has gone back to oem.
  5. Sep 20, 2023 at 6:53 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    You can also order the radium single catch can plenty of areas to mount it. I found a few mounting points with my setup. You can see the bracket in the pic.
  6. Sep 20, 2023 at 6:59 AM
    carn_dogg
    Pat
    Eastern Shore MD
    Roger that. I will retain the OEM Radiator and maybe replace the rubber hoses w silicone ones as the only upgrade there.
    I plan to order the single radium can for the PCV side of things. Price isn't too bad and seems like a good preventative measure to keep oil out of the intake where it shouldn't be.
    reywcms[QUOTED] likes this.
  7. Sep 20, 2023 at 7:16 AM
    carn_dogg
    Pat
    Eastern Shore MD
    Prospeed just confirmed that they do not know if their catch can will fit anything other than the maggie 1900.
  8. Sep 20, 2023 at 7:19 AM
    Saltyhero13
    Cool. Thanks for the follow up.
    If it is just a mounting issue I imagine it would as long as the hoses where the correct length I don't see why anything else wouldn't fit correctly.
  9. Sep 20, 2023 at 7:22 AM
    carn_dogg
    Pat
    Eastern Shore MD
    Yeah I agree. But I think their hoses are probably tailor fit for the maggie 1900 mounting location. I'm sure if you bought longer hoses then you could make it work... but kinda makes the 'kit' less of a 'kit'
    I'm going to stick with radium's single catch can for now. Seems like a nice install spot with no fitment concerns.
  10. Sep 20, 2023 at 7:25 AM
    Saltyhero13
    Only concern with Radium is for folks running a Stillen intake; those folks need a bracket or way to shift over a few inches.
  11. Sep 20, 2023 at 7:27 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Same radium single bracket works just move it over is all. There's mounting holes there. The prospeed also vents to the atmosphere introducing moisture in the system which I didn't like.
    Saltyhero13[QUOTED] likes this.
  12. Sep 20, 2023 at 7:36 AM
    carn_dogg
    Pat
    Eastern Shore MD
    Do people run stillen with the magnuson airbox that comes with their kits? I wasn't planning on changing the intake side of things that comes with their kit... but I do love me some cooler intake temps.
  13. Sep 20, 2023 at 7:42 AM
    Saltyhero13
    Folks have had fitment issues trying to adapt it to the Maggie box. You are probably better off with a SABM. I suspect you can pull off the Stillen with a cobrahead coupler but will probably be janky AF.
  14. Sep 20, 2023 at 7:53 AM
    carn_dogg
    Pat
    Eastern Shore MD
    Good to know.
    Mod seems easy enough to perform. Will see how things come with the maggie kit and take it from there.
  15. Sep 20, 2023 at 7:58 AM
    Saltyhero13
    @e30cabrio and @M3Tundra-JK were trying to adapt the snout/airbox.
  16. Sep 20, 2023 at 8:09 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    SABM with the maggy box but while you're in the intake side why not throw in a RCF throttle body lol. Just sayin @snivilous could whip up an adapter plate
    snivilous likes this.
  17. Sep 20, 2023 at 8:28 AM
    carn_dogg
    Pat
    Eastern Shore MD
    you guys are killing me lol
    how much more whp, realistically, can be expected by upgrading the TB to RCF?
    if nominal then not worth it, IMO - for the price.
  18. Sep 20, 2023 at 8:37 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    From the research prospeed said 30tq I believe. But many who test these positive displacement blowers say you want the biggest inlet possible no matter what Gale banks, Richard holdner etc.
  19. Sep 20, 2023 at 8:41 AM
    #49
    carn_dogg
    Pat
    Eastern Shore MD
    Damn... that is more than I thought you were going to say!
    I guess I will research that more over the next few weeks to see if it's worth doing. RCF TB appears (from quick searches) not to fit any 2650 blowers so an adapter would be required... and I guess this is why you said Snivilous can whip up an adapter plate for this.
    Decisions Decisions.
    Saltyhero13, snivilous and reywcms like this.
  20. Sep 20, 2023 at 9:56 AM
    #50
    carn_dogg
    Pat
    Eastern Shore MD
    Are you running stock TB? Or RC F TB?
  21. Sep 20, 2023 at 10:03 AM
    #51
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    The adapters aren't cheap though. The last ones I did (Harrop to RCF and Magnuson to LS) were like ~$200 and that was ordering 2x of them. Or if you have a local machinist I can just send you a CAD file if you send me dimensions.
  22. Sep 20, 2023 at 10:11 AM
    #52
    carn_dogg
    Pat
    Eastern Shore MD
    That’s reasonable compared to any price I can find for the TB itself!
  23. Sep 20, 2023 at 10:35 AM
    #53
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    URD and Prospeed already makes adapters that should work for RCF to Maggie. Not that Sniv isn't the man, but they're shelf items.
  24. Sep 20, 2023 at 10:43 AM
    #54
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    That would be good if we know the new maggy is the same pattern etc..
  25. Sep 20, 2023 at 10:44 AM
    #55
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    RCF with a custom @snivilous adapter. Waiting on confirmation if we can get an LS 103mm to work since the whipple inlet is 102
  26. Sep 20, 2023 at 10:49 AM
    #56
    VWTim
    Corvallis, OR
    If a stock TB bolts to it, I'd bet money an off the shelf adapter will work.
    reywcms[QUOTED] and snivilous like this.
  27. Sep 20, 2023 at 10:50 AM
    #57
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Do we know the inlet size of the new maggy? Just curious
  28. Sep 20, 2023 at 10:53 AM
    #58
    VWTim
    Corvallis, OR
    The off the shelf adapters don't care about inlet size, they're made to bolt an RCF TB to a stock plastic intake manifold.
    If A=B and B=C, then A should equal C...
  29. Sep 20, 2023 at 11:06 AM
    #59
    carn_dogg
    Pat
    Eastern Shore MD
    The logic is there.
    I can measure once I have it in hand... in a short 5 weeks, but right now we can only assume it will be the same as the tvs1900 and have the oe bolt pattern to accommodate the stock tb.
  30. Sep 20, 2023 at 11:44 AM
    #60
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Well the off the shelf adapter should have a smooth transition in my opinion. @snivilous did an awesome job on that to flow into the larger 102mm inlet of my blower from the rcf... The whipple adapter has also a bell transition for smooth flow. Yes the adapter may bolt on but why just stop there lol. I was just curious if the inlet size has gone up on the maggy from the 1.9 to the new version.
