"Lunched" Needle bearing
Discussion in '1st Gen Tundras (2000-2006)' started by dannykarnage, Apr 26, 2021.
  1. Apr 26, 2021 at 5:53 PM
    dannykarnage
    dannykarnage [OP] New Member
    06 Tundra SR5
    First post on here. I'm not a Tundra enthusiast, nor even a truck enthusiast - just a DIYer when it comes to automotive repair.
    I have a 06 Tundra that had the driver's side CV axle break shortly after I bought it. I've since replaced the CV axle, but I had some vibration at the front. I drained the differential and found a few pieces of the needle bearing were stuck to the drain plug (magnetic plug I assume?). So it would appear that either the bearing failed and caused the shaft to fail or the reverse happened. Either way, the retaining clip on the bad CV axle was also missing, so I'm assuming it also got torn apart and is probably inside the diff. somwhere.
    I want to replace the needle bearing but can't find any anywhere. I've read about the bushing from ECGS (https://eastcoastgearsupply.com/c-1207130-toyota-clamshell-bushings-99-06-tundra.html) but everything I've read seems to say that it's for lifted trucks.
    I'm wondering:
    • Can I use the ECGS part on my not-lifted truck?
    • This is the first differential I've worked on other than for my 65 Rambler - anything else I should watch out for while putting this all back together?
    Thanks for the help.
  2. Apr 26, 2021 at 6:13 PM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Absolutely throw it in a stock truck! The wapped out bearing doesn't care whst size tires you can fit. I put the ecgs bushing in my stock 2nd gen and it fixed my front diff grumble.
    KarmaKannon likes this.
  3. Apr 26, 2021 at 8:49 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  4. Apr 26, 2021 at 10:16 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Honestly if you’ve got chunks of needle bearing in the diff it may be worth looking into a different diff... but the ECGS may fix your issues for now. It’s just concerning if there’s damage to the ring or pinion due to the debris
  5. Apr 27, 2021 at 3:42 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Mine was campbell's extra chunky too. So far I think it's alright. It's still pretty concerning when you have hard metal prices floating in with mating gears and bearings.
    @dannykarnage sounds like you need the ecgs bushing, a couple differential flushes, and a rabbits foot.
    empty_lord[QUOTED] and blackoutt like this.
  6. May 1, 2021 at 3:55 PM
    dannykarnage
    06 Tundra SR5
    Thanks for the help, guys.
    I ordered the replacement pieces and the tools. I've watched the ECGS help videos for doing the job along with several other ones, but for the life of me I cannot get the puller in place. Using a magnet I can get it past the bearing but can't pull it back up into position and using the threaded rod to hold the puller I can't get it past the end of the bearing.
    Any advice?
    Danny
  7. May 1, 2021 at 4:13 PM
    Professional Hand Model
    Hand Protectors
    I have a Hand Yoga Video on my Build Page. Give that a 30 minute watch and warm up and you’ll be good to go.
    NWPirate likes this.
  8. May 1, 2021 at 5:40 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @KarmaKannon didn't you have the same issue and that's ultimately why you modified the removal tool? Whatever you did to it made it easy for me when I used it.
    FrenchToasty likes this.
  9. May 2, 2021 at 6:30 AM
    KarmaKannon
    Utah
    Some junk
    I put a slight chamfer on the backside of the tool that goes ok the side that's inserted into the differential. I could not get the tool inserted without this modification.
  10. May 2, 2021 at 10:25 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    I made my own for my 3rd gen Tacoma. It took a lot of shaping to make it work. Plan on having to clearance it a little. I stuffed a rag behind it to help it stay in place.
  11. May 2, 2021 at 10:27 AM
    Hand Protectors
    I love this Custom Ingenuity on making things happen. Nice ideas guys.
    WVI likes this.
  12. May 2, 2021 at 1:21 PM
    KarmaKannon
    Utah
    Some junk
    @FrenchToasty was nice enough to save me the time. I asked him for dimensions so I could make my own and the rest is history. I never did make one.
