Love deliveries...Morimoto XB Headlights (now w/night shots)
Discussion in '2.5 Gen Tundras (2014-2021)' started by buckrub71, Aug 8, 2019.
  1. Aug 9, 2019 at 8:40 PM
    buckrub71
    buckrub71 [OP] Like Father, Like Son--Semper Fi
    2016 Bronze 1794 CM
    Just read your post. Great write up. Damn, those fogs really do light up the sides! I also noticed you're a fellow Keystoner. The salt sucks!
    MotoTundra[QUOTED] likes this.
  2. Aug 9, 2019 at 8:47 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Thanks. Yeah they do, like the "Red Dragon" in the movie Old School, they aren't exactly street legal, and I refuse to be that guy blinding people.
    It does, I would like to buy a beater and I can't help but want to travel down south to get something old with miles that isn't covered in rust.
  3. Aug 9, 2019 at 9:14 PM
    buckrub71
    2016 Bronze 1794 CM
    I think it's important to mention that the install was relatively painless. This is not meant to be a tutorial but rather a highlight of the aforementioned additional step. By now most forum goers know how to remove the headlights. If not, it's easy to find. Once you get to that point, with exception of an added step (running a harness into the fuse box) it's like putting your headlights back in. This was the first time I have had to do this. They fit of the lights is like oem.
    Swap this fuse with the harness plug in
    Run the harness inside of this "thingamabob". It disconnects from the fuse box. Then remove the tape and look at it. You'll be able to figure out the plastic clips to separate it.
    Harness plugged in
    Ensure harness is nested in with other wiring and snap it back together. Reseat it back into the box.
    Taped back up
    Harness secured in housing and connected to fuse box. The lid the goes on and you then route your harness. I ran mine between the fuse box and battery. It then fishes down to the driver's side and across the front of the truck near radiator and behind the grill to the passenger side. Unlike so many other harnesses out there, this one does not contain an over abundance of length. It's just the right length. I recommend "dry fitting" before zip tying it. I had to make a couple of adjustments.
  4. Aug 9, 2019 at 11:16 PM
    TheBeast The Beach
    looks great. hope they come out with gen 2 version.
  5. Aug 10, 2019 at 2:27 PM
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    2016 Magnetic Grey Tundra TSS
    Toytec 2.5” Coilover boss suspension 3/1 lift w/camburg uca’s Morimoto xb headlights Morimoto fog Rough country grill 2 RC blacked light bars Volant air intake system Rear air bags (for towing) I’m sure there’s more but I’m lazy
    The in cab adjust for the headlights still function right?
  6. Aug 10, 2019 at 2:43 PM
    buckrub71
    2016 Bronze 1794 CM
    Yes they do. There are motors and a connection. They work perfectly!
    fundratss and 831Tun like this.
  7. Aug 10, 2019 at 4:24 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    I wonder if this is what's needed for the 18'+ harness to clear the fault? Interesting, there is 2 pigtails on the back of mine that can switch sequential to flash turn signals
  8. Aug 10, 2019 at 5:16 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    The fault code is appearing because pin#3 on your original 8 pin headlight harness is looking for a input "status" signal from the headlamp. I'm guessing the Morimoto headlamps don't have a wire pinned for that function.
  9. Aug 10, 2019 at 5:18 PM
    YotaMan
    Colorado Springs
    2021 Platinum
    Are you talking about this?
    ryanwgregg likes this.
  10. Aug 10, 2019 at 5:19 PM
    thomasbus337
    2020 TRD Sport DC
    Yes
  11. Aug 11, 2019 at 6:11 AM
    NCTundra1980
    NCTundra1980 New Member
    Stephen
    2019 SR5
    So the warning is still coming up on the screen?
  12. Aug 11, 2019 at 6:51 AM
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    Did you figure out sequential yet? I haven’t received mine in the mail yet and looking though install directions from Morimoto online and it’s not clear how to connect it. Maybe it seems like you just connect the two “sequential” connections together to toggle it on? That’s all I can think of without actually having them here with me
  13. Aug 11, 2019 at 7:04 AM
    buckrub71
    2016 Bronze 1794 CM
    Ignore the green wire pics about sequential signals. Our model year will not use it. If you go to pages 6 and 7 of the install guide, the plugs labeled "sequential turn signal connectors" which are orange and purple wires, is where the magic happens. Mine came connected. When disconnected, the sequential signal fires up. If you do not have LED turn signal tails, the sequential will work for you. I hooked up my stock bulb and they worked perfectly. Still waiting on a work around for mine (LED tails).
    fundratss likes this.
  14. Aug 11, 2019 at 7:05 AM
    buckrub71
    2016 Bronze 1794 CM
    BTW, you're gonna love these!
  15. Aug 11, 2019 at 12:16 PM
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    Awesome!!! I can’t wait until they get here lol. I haven’t done aftermarket tears so glad I didn’t yet. Ima follow your thread and see if find a fix for it. I’m sure Morimoto will prob have some kind of harness to add to correct it since they are so new
  16. Aug 11, 2019 at 1:37 PM
    toyoboyo
    toyoboyo New Member
    Anyone have a video clip of the sequential signal?
  17. Aug 14, 2019 at 8:59 AM
    MMichaelJJ
    MMichaelJJ New Member
    14 Platinum CM
    @buckrub71
    Get a load resister. I installed one when I was using my VLED triton V3s. I also have led taillights. When I installled the Morimoto XBs I left the load resister installed. My sequential turns work like they’re supposed to.
  18. Aug 14, 2019 at 9:04 AM
    buckrub71
    2016 Bronze 1794 CM
    Thanks. I actually ordered the resistors from VLED earlier this morning. I have Amazon cheaper coming today but second guessed using them since they get so hot. Not worth it. Can't wait to get the sequentials working. Even without, these headlights are amazing! Thanks again.
  19. Aug 14, 2019 at 2:37 PM
    #49
    gruntyota
    gruntyota New Member
    Mason
    2015 MGM Crewmax
    How much adjusting did you have to do vertically? Mine are ridiculously low, just seeing if anyone else ran into this.
  20. Aug 14, 2019 at 3:56 PM
    #50
    buckrub71
    2016 Bronze 1794 CM
    Right was about 4 inches and the left about 6.5
    gruntyota likes this.
  21. Aug 19, 2019 at 6:38 AM
    #51
    buckrub71
    2016 Bronze 1794 CM
    The VLEDS resistors added to my Recon taillights' turn signal wires fixed the sequential hyper flash issues. They are working as intended!
    AZTundra, YotaMan and MMichaelJJ like this.
  22. Aug 20, 2019 at 11:43 PM
    #52
    WVrackaholic
    WVrackaholic New Member
    2016 Platinum
    @buckrub71 can you post a link to the resistors you have and maybe some install help. Same issue I have winjet LED tails and they have factory resistors. In turn my sequential turns don’t work.
  23. Aug 21, 2019 at 11:54 AM
    #53
    buckrub71
    2016 Bronze 1794 CM
    Here ya go...https://www.vleds.com/shop-products/vlr-resistors/turn-signal-resistors/vlr-6-duotap.html
    You will need two--one for each side. Shipping was fast and easy. The install was just about as easy. They come with pigtails (duotap harness). The connections are non-polarity specific. So, just locate the two turn signal wires and connect the harness to them. I also ordered dielectric grease but it wasn't needed since they came with a packet. I now have some extra should I ever need it. I filled the connectors with some grease and then used pliers to gently close the connection. Easy peasy. As for the mounting of the resistors, they come with auto grade adhesive. I cleaned the back of each resistor with isopropyl as well as the mounting location I selected within the tailight opening. Take a look at @MMichaelJJ post above for a good location. Anywhere in that area keeps them away from plastic. You just need a flat spot. Make sense?
  24. Aug 21, 2019 at 2:36 PM
    #54
    WVrackaholic
    2016 Platinum
    You happen to remember the turn signal wire colors?
  25. Aug 21, 2019 at 3:43 PM
    #55
    buckrub71
    2016 Bronze 1794 CM
    On the Recons they are black and red. For your brand I cannot say but likely the same. Just confirm which wires are running into the turn signal portion of your tails. Another way is to use a volt meter.
  26. Aug 21, 2019 at 4:17 PM
    #56
    WVrackaholic
    2016 Platinum
    Will do thanks
