Looking for brake line kit for 2000 tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Swoboda, Jul 17, 2023.
  1. Jul 17, 2023 at 11:30 AM
    Swoboda
    Swoboda [OP] New Member
    Jonathan
    2000 toyota tundra
    Hello,
    Recently took my tundra to the shop. They said the brake lines were rusting out and some of the junctions are bad. It's not leaking yet, but would like to fix it. They said they couldnt find the parts anywhere. Anyone have any recommendations on where to get brake lines (preferably stainless steel) and junctions for a 2000 toyota tundra?
  2. Jul 17, 2023 at 11:34 AM
    CCE525
    CCE525 New Member
    Chad
    2000 SR5
    None
    You’ll need to buy a roll, fittings, flare kit and tubing bender. Remove/cut the old ones and use them as a template.
    bfunke likes this.
  3. Jul 17, 2023 at 1:37 PM
    If you're looking to get pre-bent and pre-flared ready-to-install lines we need more than "2000 Toyota Tundra". What cab type? How many cylinders? RWD or 4WD? This info often makes a huge difference! Part numbers can change significantly depending on those variables. (more Tundra info)
  4. Jul 17, 2023 at 1:47 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I was able to get the hard lines and "junctions" I needed at my local stealer. But first, @Shifty' is right...let us know the all the relevant details and we can point you in the right direction.
  5. Jul 17, 2023 at 2:01 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Wrecking yard may be a good source for hard lines unless you’re up north
  6. Jul 17, 2023 at 3:45 PM
    Swoboda
    Jonathan
    2000 toyota tundra
    It is a 2000 toyota tundra, extended cab, v8, 4wd. I live up north so a junkyard isn't a valid option..unfortunately. thanks for the replies.
  7. Jul 17, 2023 at 4:07 PM
    I can try to run the OEM p/n for you after dinner.
    There is some info on how to run the p/n yourself over here if you wanted to give it a shot and save it as a reference.
  8. Jul 17, 2023 at 5:53 PM
    Bmktw2
    Bmktw2 Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    I saw a full stainless steel brake line kit I at either rockauto or amazonie
  9. Jul 17, 2023 at 6:18 PM
    Look - I may be wrong here, so I'd prefer you go to this site, plug your VIN into the search box, then tell me the "complectation" number it spits out and I'll dig up the charts so you can click on the lines you need.
  10. Jul 17, 2023 at 7:19 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Is your truck not eligible for the frame recall? It's the right year and you live in the north.
    https://www.tundras.com/threads/early-1st-gen-2000-2003-tundra-frame-replacement-faq.54331/
    Here are the part numbers for my 01 access cab from my frame replacement. See the brake tube part numbers listed.
