Longtravel: Banner/HulkSmash Build- PapaSmurf & Sunnier Build a First Gen
Discussion in '1st Gen Tundras (2000-2006)' started by Sunnier, Apr 16, 2019.
  1. Jun 9, 2020 at 6:52 PM
    #241
    Cfincke
    San Antonio
    bmf4069 and Rica25 like this.
  2. Jun 9, 2020 at 7:33 PM
    #242
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  3. Jun 9, 2020 at 7:35 PM
    #243
    Sunnier
    Sunnier [OP] Pity the warrior that slays all his foes
    Sunny
    San Diego, CA
    Thanks!
    I got the cantilever from Matt at MCM, as well as extended brake lines and, I’m pretty sure, the shackles as well. Pretty much, everything we used was from King, Total Chaos, and MCM. Yeah, I think we were able to use stock hangers, but I’ll look back through my purchase orders to verify.
    @papasmurf spec’d, installed, and built everything to this point in the thread, so he may chime here if he remembers details I don’t.
    He cycled the suspension and we put 17” limiting straps on the back, so right around there. As for bump stops, I was short on money at this point so we started with Wheeler’s Super Bumps.
    Hulk and I have definitely grown out of them so Real bump stops are now on my short list. Bruce already picked what I’ll likely get but I’ll be interested to know what you pick.
    Track width in front is 88” aired down, and 84 1/4 aired down in back. To get even this width on back, I added BORA spacers.
    I’ll admit, I don’t know what you mean by “gear Selene”, even did an internet search to figure it out and am still lost. Maybe help me by explaining a different way, and I’ll answer up.
    Man, protests up in here too! :bananadead:
    I know I’m behind, guys. I promised it’d be this weekend, then worked 8 long days in a row, and am separated from my laptop with pics. I swear, I’m working on catching up. Probably gotta let go of the chic romantical theme though. :rolleyes:Anyway, I figure a parts list and some pics should do.
  4. Jun 9, 2020 at 7:55 PM
    #244
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    No way, the diary style is fun. We just get anxious.
  5. Jun 9, 2020 at 8:11 PM
    #245
    Sunnier
    Sunny
    San Diego, CA
    I know it. I’m waaaaay overdue. So I promised I’d get some caught up this last weekend then I got pulled into a big project at work, so now I’m pretty much owning the cone of shame ‘til I can square this away.
  6. Jun 9, 2020 at 8:39 PM
    #246
    Rica25
    Ricardo
    Tulare
    Not acceptable :crapstorm:
  7. Jun 9, 2020 at 9:35 PM
    #247
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    You have until next Monday then I'm putting you in the first gen corner of shame.
    Tundyfundy and Darkness like this.
  8. Jun 9, 2020 at 9:46 PM
    #248
    Sunnier
    Sunny
    San Diego, CA
    Dump on me if you want, but it’s not helping. I’ll update because I’m proud of the truck and grateful to Bruce for the amazing work he did building it. But :censored: everyone else, I’m busy and tired. I’ll do it when I can. See you when I see you.
  9. Jun 9, 2020 at 9:47 PM
    #249
    18" TRD Off Road Wheels
    Aren't all first gens just in the Tundra corner of shame? :duel::crapstorm:
    I'm kidding, but I couldn't pass up the opportunity.
  10. Jun 9, 2020 at 10:05 PM
    #250
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Rica25, FrenchToasty, bmf4069 and 2 others like this.
  11. Jun 9, 2020 at 10:06 PM
    #251
    Just cuz I don't own one doesn't mean I can't admire one. Especially when it's being turned into a monster like this one is.
    In other words:
    :p:p:p
  12. Jun 9, 2020 at 10:09 PM
    #252
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've had the same problem, work is absorbing life and the projects are piling up. Since I've been working at home my days don't seem to end. Sometimes it gets overwhelming, there's not much you can do other than put those work projects aside and update your thread.
    :wink:
  13. Jun 9, 2020 at 10:09 PM
    #253
    Blueranger501
    Blueranger501 New Member
    Gear Selene....whoops.
    Meant gear setup. Want to plan ahead for what I will have back there too. 700lbs sounds like a lot but maybe I am missing something.
    For me it’s 2 spares, extra fuel, water, food. Tools. Long term a mid rack and RTT. Who knows maybe that does get me to 700.
    Bruce did beautiful work. My supercharger install is almost done then I need to get back in the dirt for some action. In San Diego - would be cool to tag along and see yours in action.
    Sunnier[OP] and Rica25 like this.
  14. Jun 9, 2020 at 10:16 PM
    #254
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Just knowing you are doing ok and still working is all the update I need Sunni! The truck is an added bonus! I spoke with bruce over the phone a while back and hes seems like a really cool dude and he is obviously stokes about trucks!
  15. Jun 9, 2020 at 11:26 PM
    #255
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Really nice build sunny! And Great work bruce! @papasmurf
    you still have the 85’ sunny?
    GodlessPro, Rica25 and Tundyfundy like this.
  16. Jun 10, 2020 at 5:42 AM
    #256
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm just pokin fun at ya, as I'm sure everyone else is. Take care of you first. Hell, I've been needing to do basic maintenance on mine forever, but I've been busy and tired as well. At least you're actually doing something cool.
    Rica25 and GODZILLA like this.
  17. Jun 10, 2020 at 6:07 AM
    #257
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @Sunnier I was just about to say this. We're just messing with you. Don't think we're trying to add any stress to your plate. It's an internet forum. I don't think any of us take it that seriously. We're just here to have a good time and laugh at BMF's terrible drawings.
  18. Jun 10, 2020 at 6:47 AM
    #258
    Rica25
    Ricardo
    Tulare
    :angrygirl:@Sunnier
    Sunnier[OP] likes this.
  19. Jun 10, 2020 at 10:34 AM
    #259
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Yeah we're not the Tacoma forum:laugh::laughing:
  20. Feb 13, 2021 at 11:15 AM
    #260
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    eccracer104 likes this.
  21. Feb 13, 2021 at 11:36 AM
    #261
    Sunnier
    Sunny
    San Diego, CA
    I knew I shouldn’ta sent that guy over here. :anonymous:
    But checking back in got me kinda inspired. So I started organizing photo files....
    I know me though: if I start feeling pushed, I’ll just give up again.
    Anyway, @fisherman951 Tony, how’s your build thread coming?! ;)
    eccracer104 and fisherman951 like this.
  22. Feb 13, 2021 at 4:01 PM
    #262
    fisherman951
    Tony
    2017 crewmax 4x4
    My build is coming along nicely. I’m officially part of the #kinggang!! Hahah:anonymous:
  23. Feb 13, 2021 at 4:27 PM
    #263
    Sunnier
    Sunny
    San Diego, CA
    Well, alright!!!
    Darkness likes this.
  24. Feb 14, 2021 at 5:47 AM
    #264
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
  25. Feb 14, 2021 at 9:01 AM
    #265
    Sunnier
    Sunny
    San Diego, CA
  26. Feb 14, 2021 at 9:48 AM
    #266
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    This pic needs to be on top of post #1.
    alb1k, papasmurf, Darkness and 14 others like this.
  27. Feb 14, 2021 at 11:47 AM
    #267
    fisherman951
    Tony
    2017 crewmax 4x4
    papasmurf, eccracer104, jc153 and 2 others like this.
  28. Feb 15, 2021 at 7:00 AM
    #268
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    :bananadance: :burnrubber: :yes: :bowdown:
    papasmurf and Sunnier[OP] like this.
  29. Feb 15, 2021 at 7:44 AM
    #269
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Random question. I understand the fenders being white because they are aftermarket. What's up with the bed though? Did you have to replace it for some reason?
    Amazing picture BTW.
  30. Feb 15, 2021 at 8:11 AM
    #270
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    I was shotgun for this one! :headbang:
    @Sunnier your truck is too smooth :thumbsup::fistbump:
