Long-travel kits list
Discussion in 'Long Travel Suspension' started by Spvrtan, Mar 5, 2018.
  1. May 9, 2019 at 10:57 AM
    #181
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    That would make the problem worse
  2. May 9, 2019 at 8:56 PM
    #182
    zackbremer
    zackbremer New Member
    Da Z
    i guess i meant run a longer spring and less preload , but yes leaving the preload ring in the same spot would make it worse
  3. May 10, 2019 at 5:30 AM
    #183
    osidepunker
    Alex
    2013 Tundra DC 4x4
    No I meant going with a longer spring that is the same weight is just going to compress the same amount, but now you've added more coils so it will bind sooner.
    There is a calculation for the correct spring length. I think its based on width, stroke length, and leverage. There is only one correct length for a given application. Then you choose different coil weights based on the corner weight of the truck in order to get the correct ride height. You want the minimum amount of coil weight that will keep the suspension at ride height without binding the coils at full compression.
  4. Jun 21, 2019 at 1:10 PM
    #184
    Southdesertprerunner
    Southdesertprerunner New Member
    08 tundra
    Camburg lt kit, king coilovers, bypasses, and bumps, deaver i96 in rear, fab work by solo motorsports, super charger, rigid light bars, bfg 37s total chaos bed stiffners, gorrila whips, dasaita head unit polk audio subs and amps.
    Hi there,
    I just bought a 08 tundra with camburg lt kit. I am going to be pulling apart the front of truck suspension to fix a leaking seal on CV input to transfer case. The person I bought it from said that the ball joints had came loose (bottom) and shredded the inside of tire has anyone had this problem with there lt kit? The ball joint issue has been fixed new bolts and stuff just seeing if it a problem or just a freak accident.
    831Tun likes this.
  5. Jun 21, 2019 at 2:51 PM
    #185
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I think it's due to deferred maintenance. Heavily modifying, and I consider LT a heavy mod, necessitates more time spent inspecting/wrenching on truck. At least that's been my experience.
    KevinK likes this.
  6. Jun 21, 2019 at 2:54 PM
    #186
    08 tundra
    Ya I think (hope so) too I am taking to a friend who builds trucks, shop and having it gone thru just to be sure there are no issues. Dont want to be out in the desert and gave it come apart.
  7. Jun 24, 2019 at 8:04 PM
    #187
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I love how it has become so standard for everyone to refer to long travel suspension in any form as a "kit". I get that it's a carry over from lift kits, but seriously it's a system of suspension components designed or purposes to work together. The whole "what kit do ya have bro?" Thing just makes it sound like the Duke boys redheaded cousin grabbed the rebar and extended his control arms. No worries I'll go back to my barley/hops intoxicant KIT now.
    Sunnier likes this.
  8. Jun 24, 2019 at 10:02 PM
    #188
    Sunnier
    Sunny
    San Diego, CA
    :thumbsup:
  9. Jun 25, 2019 at 7:24 AM
    #189
    TXTundra2722
    2015 Black Tundra
    :drunk::cheers::puke:
    KarmaKannon[QUOTED] likes this.
  10. Jun 25, 2019 at 9:51 AM
    #190
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Might be the fact that LSK, Camburg and Total Chaos list and sell them labeled as kits.
  11. Jun 25, 2019 at 10:03 AM
    #191
    KarmaKannon
    Utah
    Some junk
    After they are installed are they still considered to be in "kit" form? Sounds like branding following common usage of silly terms.
    831Tun[QUOTED] likes this.
  12. Jun 25, 2019 at 10:41 AM
    #192
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I dunno. I've got the TC "kit" up front but have felt it necessary to change out a lot of the "kit" parts as well as modifying the install and the truck to make things work properly. Seems like the "kit" is for street use and the "look". Example: the spec King shocks come with 600 lb coils and that spring rate doesn't work for me. Might work for an unloaded 2nd gen RCSB but not a CM loaded with fuel, water 2 37" spares and camping gear. Recommended location of the limit straps leaves the straps dragging on the axles so have to relocate those. Coil bucket double sheer should also be added if you really wanna off road. You create a lot more leverage by moving the wheels 5" farther apart and then add a ton of weight to that..... lots needs to be reinforced. I'm hoping a coil bucket brace (bucket to bucket over the top of the engine) solution will be available in the near future.
    So, I started with a kit. I dunno what it is now....... Fun AF!
    joonbug, zackbremer, KevinK and 3 others like this.
  13. Jun 26, 2019 at 9:46 AM
    #193
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    And EVERYBODY is calling uprights/knuckles spindles too... soooo... It's no longer an upright/knuckle, it's now a spindle. Nevermind that Tundras have unit bearings.
  14. Jun 26, 2019 at 10:19 AM
    #194
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Haha.... Truth is, I don't even know the difference.:anonymous:
    However, I won't ever talk about the "struts" on my Tundra. There at least I know the difference.
    joonbug and Sunnier like this.
  15. Jul 3, 2020 at 11:56 PM
    #195
    Viliamu808
    Viliamu808 New Member
  16. Jul 9, 2020 at 8:13 AM
    #196
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I saw a mazzula kit in person and it was pretty badass. Looks like 4" over, definitely longer than camburg or TC. but they dont list it on their website so idk
    joonbug and Challenger1 like this.
  17. Jul 9, 2020 at 8:27 AM
    #197
    GravityGear
    Aurora, CO
    The Chevy king...
    Was it pewdypew's (i think that's his handle?) truck?
  18. Jul 9, 2020 at 8:37 AM
    #198
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Not sure. It was a truck on a used car lot in OC. crewmax with a shitty bed cage and spring over rear. but the front was pretty awesome. Kings and mazzula. I didnt realize mazzula made a kit for us and its not advertised, but this kit has been on there for a few years, there was a little rust on the uniballs
    joonbug likes this.
  19. Jul 9, 2020 at 8:39 AM
    #199
    GravityGear
    Aurora, CO
    Was it black? The truck I'm referring to got the kit installed like 4 or 5 years ago, so it might be that one.
  20. Jul 9, 2020 at 8:55 AM
    #200
    osidepunker
    Alex
    2013 Tundra DC 4x4
    yes, I believe it was black so that might be the one
    @Challenger1 might remember more details
    Challenger1 likes this.
  21. Jul 9, 2020 at 11:58 AM
    #201
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    It was more of a dark gray color..
    2014 SR base model with bench seats.
    The front had an SSbuilt bumper welded on.
    joonbug likes this.
  22. Jul 24, 2020 at 10:30 AM
    #202
    liltrok
    liltrok New Member
    Anaheim, CA
    2nd Gen DC RW
    Any opinions out there on Camburg’s Kit? I have the opportunity to pick one up for a good price but don’t know. Truck needs a sway bar so I was set on a TC Boxed kit but I do know Camburg has their sway bar they sell for their LT kits. Everyone knows what I mean when I say “do I really want to run something from Camburg...” but the price is there.
    831Tun likes this.
  23. Jul 24, 2020 at 10:38 AM
    #203
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    There’s nothing wrong with Camburg’s LT kit. I have a couple friends that run it.
    Challenger1 and 831Tun like this.
  24. Jul 25, 2020 at 1:37 PM
    #204
    TXTundra2722
    2015 Black Tundra
    Well.... if it's a good price and you don't end up going with it..... maybe you should share!!!
    831Tun and Sunnier like this.
  25. Jul 25, 2020 at 1:49 PM
    #205
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    share it
    TXTundra2722[QUOTED] likes this.
  26. Jul 27, 2020 at 6:36 PM
    #206
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Anyone running LSK bolt on?
    joonbug and fisherman951 like this.
  27. Jul 27, 2020 at 9:13 PM
    #207
    liltrok
    liltrok New Member
    Anaheim, CA
    2nd Gen DC RW
    Anyone know anything about this kit from Total Chaos? How long of a shock can u run? Nothing really specific here.
  28. Jul 27, 2020 at 9:14 PM
    #208
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    @joonbug what kit are u running?
    joonbug likes this.
  29. Jul 27, 2020 at 10:07 PM
    #209
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Joon's running the Race not bolt on.
    joonbug and dcsleeper408 like this.
  30. Jul 28, 2020 at 11:10 AM
    #210
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Camburg has terrible ground clearance. Almost 2" lower than a TC tube kit
    Why do you want to run a sway bar? Thats going to make it handle like crap off road
