Long-travel kits list
Discussion in 'Long Travel Suspension' started by Spvrtan, Mar 5, 2018.
  1. Apr 30, 2019 at 10:03 AM
    #151
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Yeah 800 lbs made a big difference for me
    But I lost a little bit of articulation
    SoCal619 and joonbug like this.
  2. Apr 30, 2019 at 10:42 AM
    #152
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    Looks good Craig! Looking forward to your feedback about performance.
    joonbug and papasmurf like this.
  3. May 7, 2019 at 3:05 PM
    #153
    n2deep
    n2deep Pavement Princess
    I love being able to keep the bed and still get the travel. Did well last weekend but the extra up-travel smashed the rear fenders up a bit. Hopefully the rear bedsides will be here soon and can push it a bit more with some weight. Only had about 200lbs in the bed so far. Was able to do a little crawling and a few high speed sections bit no real whoops.
    Here is a video but nothing of the high speed areas. https://youtu.be/VgPO55rcVGw
  4. May 7, 2019 at 3:28 PM
    #154
    n2deep
    Cooper SST Pro 305/70/18 35.08 71lb
    SoCal619 likes this.
  5. May 7, 2019 at 3:42 PM
    #155
    n2deep
    No I heard they dont work - but also heard its the same as helper spring or keeper spring. I am confused.
    KevinK, papasmurf and SoCal619 like this.
  6. May 7, 2019 at 9:27 PM
    #156
    M C M
    M C M New Member
    Eibach wouldn't even quote them, and PAC wanted 7k$ for 2 springs, even though it was a part number they listed. Hyperco stepped up and is making the springs for our 3.0 LT shock as well as springs for the 3.0 bolt in coilover we are working on for the Tacoma/4Runner.
    Some pics of the 3.0s with the LT kit.
    cavalry bear, Sunnier, 831Tun and 6 others like this.
  7. May 7, 2019 at 11:21 PM
    #157
    n2deep
    What spring rate? 800lb for the LT
  8. May 8, 2019 at 4:48 AM
    #158
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I had to switch to 800# coils also. I was binding on the 700# ones (Foxs). I also know a dude with Kings and he's binding at 700# also. These big trucks need larger coils.
    Eibach had 3.0 (for 2.5 coilover) 800# coils for me
  9. May 8, 2019 at 5:06 AM
    #159
    Vizsla
    Vizsla 2 = 2.5
    Do you know if the dude with the 700# Kings did a retrofit coil/perch/adjuster ring, or used the bigger TC spec coil(bigger diameter)?
    joonbug, papasmurf and 831Tun like this.
  10. May 8, 2019 at 5:17 AM
    #160
    osidepunker
    Alex
    2013 Tundra DC 4x4
    @papasmurf can you answer? :rofl:
    Sunnier, joonbug, papasmurf and 2 others like this.
  11. May 8, 2019 at 5:29 AM
    #161
    Vizsla
    Vizsla 2 = 2.5
    :facepalm:
  12. May 8, 2019 at 7:33 AM
    #162
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Oh you had to see that one coming. LOL
    Sunnier, joonbug, KevinK and 2 others like this.
  13. May 8, 2019 at 9:21 AM
    #163
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    :anonymous:
  14. May 8, 2019 at 9:42 AM
    #164
    M C M
    M C M New Member
    Ive always preferred 800lb coils on these trucks.
    The coils that come on the TC spec kings are a 5" OD spring, they are an odd size and only 600lb spring, options are extremely limited for those as well.
    Most of the 3.75" ID springs are really long in the heavier rates.
    Then there is that one company who runs a dual rate on a 8" shock for some stupid reason. These trucks already need as much spring travel as possible without wasting it on a useless tender spring.
    osidepunker, Vizsla and 831Tun like this.
  15. May 8, 2019 at 9:52 AM
    #165
    Vizsla
    Vizsla 2 = 2.5
    They have the King coil in 700# now. Pretty sure he said they are from an overseas LC 200 application. Told me I needed the bigger coil.
    joonbug likes this.
  16. May 8, 2019 at 9:53 AM
    #166
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Well if you add bumper slider skids etc then 700# isn't an option because they bind.
    The 800# handles the big stuff really well, but its a little harsh on the chop.
    Buuut my truck doesn't feel like a boat anymore in the turns. Feels like I installed some sway bars or something LOL
    Sunnier, joonbug and SoCal619 like this.
  17. May 8, 2019 at 10:41 AM
    #167
    M C M
    M C M New Member
    Depends on the kit. The downside to trying to have ground clearance is you end up with a really short shock. Camburg uses a longer shock (still an 8") which allows for a longer spring which will have more spring travel. You just bounce the lower arm off every pebble on the trail.
    osidepunker[QUOTED] likes this.
  18. May 8, 2019 at 10:57 AM
    #168
    n2deep
    Wasn't a pebble but it did leave a mark.
    KarmaKannon and osidepunker like this.
  19. May 8, 2019 at 2:37 PM
    #169
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    This may be a dumb question but do you need to get longer shocks up front for the LT kits or can you just use the existing ones that you buy already 2.5-3” longer leveling?
  20. May 8, 2019 at 2:39 PM
    #170
    Spvrtan
    Spvrtan [OP] Amateur fabricator
    Kris
    San Diego, CA
    In theory you could but you won't be realizing the full travel potential of the kit.
  21. May 8, 2019 at 2:40 PM
    #171
    canadianguy
    Kevin
    Ok cool. Thanks
  22. May 8, 2019 at 3:17 PM
    #172
    M C M
    M C M New Member
    They wont work in general, most kits are 8" travel shocks, most OEM replacements are 6-7" of travel with a really long lower rod end
  23. May 8, 2019 at 4:57 PM
    #173
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    My mid travel shocks are actually longer than my LT shocks.
    Vizsla likes this.
  24. May 8, 2019 at 8:10 PM
    #174
    canadianguy
    Kevin
    What shocks you running?
    831Tun[QUOTED] likes this.
  25. May 8, 2019 at 8:40 PM
    #175
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Currently, TC spec'd Kings for the TC LT front. I had ADS MT and still have, for the moment, ADS bypass rears.
  26. May 8, 2019 at 8:42 PM
    #176
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I think it has to do with where the shock mounts on the LCA? Matt didn't seem surprised when I mentioned it to him and he said, "No, you can't run those in the LT kit."
  27. May 8, 2019 at 8:45 PM
    #177
    canadianguy
    Kevin
    Does it just depend the LT kit then?
  28. May 8, 2019 at 8:49 PM
    #178
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I believe it does. All the kits are different and spec slightly different shocks, Camburg I'm pretty sure uses a longer shock. Mostly, to my understanding, the travel comes from moving the wheel out so that it's traveling in a larger arc.
    cavalry bear and Sunnier like this.
  29. May 9, 2019 at 5:13 AM
    #179
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Yeah I agree about the coil length. But in my case the extra ground clearance is mandatory. It still rides very well, it just got a little stiff over the chop when I switched to 800#
    Currently in the bypasses I have low flow pistons with a 120 stack with the top off removed. I'm going back to a single flutter 120 and put the top off back in and see how that works.
    haha craig! I already bent the sht out of the bottom of one of my arms too #drivebetter
    When you say longer do you mean overall length or stroke length? because its the stroke that matters. You can always change the rod end to get different overall length.
    joonbug likes this.
  30. May 9, 2019 at 10:57 AM
    #180
    zackbremer
    zackbremer New Member
    Da Z
    couldnt you just get a longer 700# spring so you dont need as much preload, but it will still ride better than the 800# spring?
    831Tun likes this.
