Long-travel kits list
Discussion in 'Long Travel Suspension' started by Spvrtan, Mar 5, 2018.
  1. May 3, 2021 at 1:45 PM
    #271
    CrunchTimeHD
    CrunchTimeHD New Member
    Louis
    Easton Pa
    2011 tundra limited CrewMax
    Starting to save for the jump to lt looking for opinions between the tc boxed kit, camburg, or lsk
  2. Aug 7, 2021 at 8:35 AM
    #272
    rickypanecatyl
    rickypanecatyl New Member
    2011 TRD Off-Road
    For comparison sake, how much travel does the stock 4x4 and TRD Off-Road have?
  3. Aug 23, 2021 at 10:46 PM
    #273
    liltrok
    liltrok New Member
    Anaheim, CA
    2nd Gen DC RW
    not enough
    Sunnier likes this.
  4. Oct 5, 2021 at 7:50 AM
    #274
    YotaPower
    YotaPower New Member
    Belgrade Montana
    2018 Long Travel SR5 Crewmax and 2014 Tundra SR5 Crewmax
    2018 — LSK Race kit up front LSK Cantilever out back. 37’s on raceline beadlocks. Dirty Deeds dual budget dump. 2014 — leveling kit 35’s and a magnaflow muffler.
    Lsk =
    SnowToy, RJVA, dhalsey and 10 others like this.
  5. Oct 7, 2021 at 10:26 AM
    #275
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    That is wicked looking, how much travel is in the back with the cantilever?
  6. Oct 7, 2021 at 12:39 PM
    #276
    YotaPower
    Belgrade Montana
    its 17” up front and 16” out back.
    jc153 likes this.
  7. Oct 8, 2021 at 6:49 AM
    #277
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    Very nice!!!
    I’m curious how the rear works. I’ve always liked the idea of a cantilever setup for the bed space savings but hear they can be difficult to tune.
    Let us know what you think when you get some dirt time on it.
    YotaPower[QUOTED] likes this.
  8. Oct 8, 2021 at 7:58 AM
    #278
    Sunnier
    Sunny
    San Diego, CA
    @Cruzer yep, it’s available for later gen
    Cruzer likes this.
  9. Oct 8, 2021 at 12:40 PM
    #279
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    :drool::drool::drool::drool:
    Sunnier[QUOTED] likes this.
  10. Oct 8, 2021 at 1:03 PM
    #280
    YotaPower
    Belgrade Montana
    Yeah I’ve mashed it pretty good (tires off the ground a few times ) and seemed to do fine I may need some tuning have to get in contact with some of the other ppl I know with this set up and ask them how their shocks and bypasses are set up. May need some more dampening and maybe stiffen the rear bump stops.
    Bypass shocks make a lot of noise clicking and clacking.
    jc153[QUOTED] likes this.
  11. Oct 9, 2021 at 12:19 PM
    #281
    jc153
    San Diego
    I have the MCM Fab rear under bed setup so no bedcage for me either. At full bump my bypasses are at a pretty steep angle. I do need to revalve them but just haven’t put the effort in required to do it right. I think my biggest issue is the Deaver I96HD leaf springs, they don’t hold weight. Just filling up with gas and there is a significant lean and it gets worse with time. I need to have them serviced but will probably do the 3” wide leaf spring conversion at some point.
    Yeah man, bypasses are loud! Sounds like there’s a metal can half full of rocks in the bed of my truck.
    831Tun likes this.
  12. Oct 9, 2021 at 11:18 PM
    #282
    liltrok
    liltrok New Member
    Anaheim, CA
    2nd Gen DC RW
    how does it ride with that setup in the rear?
  13. Oct 10, 2021 at 8:22 AM
    #283
    jc153
    San Diego
    For the most part it’s really good. I just need to do some fine tuning to the bypasses so I keep a compliant ride on the small stuff and don’t blow through the stroke on the bigger hits.
    831Tun likes this.
  14. Jan 24, 2022 at 9:11 AM
    #284
    cavalry bear
    cavalry bear New Member
    Cavalry
    2019 Limited Tundra
    None Yet
    amazing, so it is possible to run one LT shock with LT LCAs
    If you don’t mind my asking, how does one get hands on just those camburg LCAs? their website only sells the kit with a lot of stuff i don’t need
  15. Jan 24, 2022 at 10:43 AM
    #285
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Bro what. You need the whole long travel package to run long travel shocks. That post you quoted is a MCM long travel kit. You do need all the stuff, you can't just slap LT LCAs and bigger shocks on, you need the upper arm and all the other shit to widen the suspension and allow you to fit the longer shock. You can buy beefed up stock length LCAs and run 3.0 shocks, but that's different than long travel.
    831Tun and Sunnier like this.
  16. Jun 3, 2022 at 11:17 AM
    #286
    tokolosh
    tokolosh Serial procrastinator
    J
    SF Bay Area
    05 AC V8 SR5 Phantom Grey
    new driver
    Question for you guys - 1st gen Total Chaos +3.5 kit... when adding secondary bypasses do you have to cut off the OEM bump mounts and if so all 4 or just the rears? Trying to figure out bump stop options
    831Tun likes this.
  17. Jun 3, 2022 at 12:32 PM
    #287
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    :notsure: Gotta have some sort of bump stop. The only way you'd cut all 4 out is if you're installing hydros.
    des2mtn likes this.
  18. Jun 3, 2022 at 1:50 PM
    #288
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    The OEM bumps screw directly into the frame, so there's no mount to remove.
    Here's Total Chaos' 1st gen double cab with a secondary shock. You can't see the rear bump because the spindle is in the way, but I'm sure it's in there. Not sure what it would interfere with.
    Aaaand, here's @Sunnier 's TC setup. No secondary shock in there, but the rear bump is in there.
    The Solo XLT kit comes setup to run a secondary bypass AND hydro bump but it is pricier than the Total Chaos kit. Note how it's mounted to the outside of the frame, towards the front of the truck.
  19. Jun 3, 2022 at 2:03 PM
    #289
    tokolosh
    J
    SF Bay Area
    new driver
    I'm planning on Durobumps just wasn't sure if just the front two or all four. They actually have two different bumps with different dims for front and rear of the arm, I figured the fronts might stay but wasn't sure on rear
    des2mtn likes this.
  20. Jun 3, 2022 at 2:04 PM
    #290
    Sunnier
    Sunny
    San Diego, CA
    Used to be so shiny and clean!
    Peeeheeuuu and des2mtn[QUOTED] like this.
  21. Jun 3, 2022 at 2:05 PM
    #291
    Sunnier
    Sunny
    San Diego, CA
    Mine are Wheelers Super Bumps. But if you can do it, get hydrobumps.
    831Tun likes this.
  22. Jun 3, 2022 at 2:13 PM
    #292
    tokolosh
    J
    SF Bay Area
    new driver
    I have hydros for the rear but don't think they're that necessary for the front if you have bypasses, as those can be valved with a bump zone. And I'm over Superbumps, they work decently but longevity.... not so much. Went through 3 sets on my Tacoma lol
    Thanks for the input all!
    831Tun likes this.
  23. Jun 7, 2022 at 11:28 AM
    #293
    tokolosh
    J
    SF Bay Area
    new driver
    Just following up - according to TC OEM bump mounts remain untouched, thanks again for input y'all!
    reywcms likes this.
  24. Feb 7, 2023 at 1:56 PM
    #294
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Don’t look at my build thread lol
    FrenchToasty likes this.
  25. Feb 27, 2023 at 2:54 PM
    #295
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    What fox shocks did you add? And most likely only an 1” if anything.
    You should watch this YouTube channel. Lots of good info.
    https://youtu.be/ATmyTbMJL3o
    831Tun likes this.
