Lifted 2020 with tss issues.
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Sgasp90, Nov 14, 2020.
  1. Nov 14, 2020 at 1:21 AM
    Sgasp90
    Sgasp90 [OP] New Member
    2020 trd pro tundra
    Just lifted my 2020 tundra trd pro with the ready lift plus 4, once aligned the speedometer, precollision, trailer brake, traction control, abs, and gas gauge fluctuates. Anyone else lift theirs and have similar issues?
    ackthresher and Blueknights75 like this.
  2. Nov 14, 2020 at 3:03 AM
    GarTX526
    GarTX526 New Member
    2016 QuickSand TRD-Pro
    Many pending.....
    I don’t know about all other stuff.......
    But damnnnnnnn! That truck looks siiiiiiiiick!
    The ProPlus 4 is the way to go. I’ve got the Plus 2 on mine and wish I’d gone Plus 4 on the daily.
    Hope you figure the other stuff out though!
    Best of luck.
    4x4_Angel likes this.
  3. Nov 14, 2020 at 3:45 AM
    Sgasp90
    2020 trd pro tundra
    Yeah I’m hoping I don’t regret it with all these problems.
  4. Nov 14, 2020 at 4:35 AM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Have any rake? I kept 1 1/2 inches higher in the back for this reason....
  5. Nov 14, 2020 at 5:53 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Looks like your front may be higher? You need some rake to have TSS function. Dealer can try to re-calibrate.
    AggiePhil likes this.
  6. Nov 14, 2020 at 6:34 AM
    I have Toytec Alumas up front and shackles and shims in the back for 2 inches in the rear. I am level and I don't have any issues with mine.
  7. Nov 14, 2020 at 6:39 AM
    PM
  8. Nov 14, 2020 at 6:57 AM
    Kanobi13
    Kanobi13 New Member
    Did they disconnect abs sensor?
  9. Nov 14, 2020 at 7:41 AM
    Looks great, hopefully you can figure this out.
  10. Nov 14, 2020 at 9:51 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
  11. Nov 14, 2020 at 11:56 PM
    Sgasp90
    2020 trd pro tundra
    Has anyone else had issues with dealerships refusing to recalibrate their sensors. I’m reading some do and some don’t. Trying to find out if anyone has done this recently
  12. Nov 15, 2020 at 3:49 AM
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    You either need rake or you can adjust the TSS sensor angle with washers to angle it about 15 degrees downward. I have a custom grille and lift and it was causing similar issues. Stacked some washers on the bottom TSS mounting threads to angle it downward and it fixed the issues. TSS uses road geometry for its BSM, lane correction, and some radar functions. It is naturally calibrated at a downward angle to pickup these cues. Once you lift or level, it will sometimes level out that calibrated angle and throws it off.
    AggiePhil and Vin63 like this.
  13. Nov 15, 2020 at 3:58 AM
    Sgasp90
    2020 trd pro tundra
    Do you mind taking a picture and posting it on here so I can see exactly what you did and give it a shot.
  14. Nov 15, 2020 at 4:26 AM
    Ckatz53
    Ckatz53 Newish
    MD
    So I have a DB Customz grille so the bracket will look different and I honestly forget what the stock looks like, but this was my fix to your issues upon installation. Stacked extra nuts between the faceplate and the grille glass on the bottom threads (original post said top, sorry its early half asleep). This angled the TSS similar to factory mounting spec. If you look at the stock mounting angle, it should be roughly 15 degrees downward. Raising the truck, and especially if it is leveled or has a rear rake, throws this angle off.
    Hopefully this helps some. Shouldn't be hard to do something similar with stock.
  15. Nov 15, 2020 at 4:28 AM
    Ckatz53
    Ckatz53 Newish
    MD
    TSS mounted when it was going apeshit. Hard to tell from these pics because the angle of the shot is bad, but it was pointing at a level plane with the roadway throwing it off. Reinstalled with the nuts, it retained the natural rake from factory. No issues since (been about a year).
    AggiePhil and Terndrerrr like this.
  16. Nov 15, 2020 at 1:25 PM
    MGM2020
    MGM2020 New Member
    Sacramento CA
    2020 MGM Tundra SR5
    6" Rough Country Lift 37" on 22" V2 Monotube Rear L3 Lifted Struts Front
    Lifting my truck didn't set my sensor off but as soon as I switched my grille then the sensor stopped working properly. I tried using different sensor covers and no luck and tried positioning the sensor differently and still didn't work. It doesn't need to be recalibrate through the dealership as just driving the truck normally will fix the problem when its in the correct position. The only thing that worked for me was a relocation bracket from AJT Deisgns. After I installed it, the sensor when off after 5 minutes of driving.
  17. Nov 15, 2020 at 1:43 PM
    Piney
    Piney New Member
    South Jersey Pine Barrens
    2020 MGM TRD Pro
    I hope you can get this fixed. That is one BADASS looking truck!
  18. Nov 15, 2020 at 4:50 PM
    Vin63
    Vin63 New Member
    2022 Tundra SR5 DC
    Had exactly the same issue, chinese trd pro grill disabled my TSS. It was causing me such a big headache cause I like the TSS system. 3 washers did the trick, haven’t had an issue since. It’s extremely sensitive
  19. Nov 15, 2020 at 6:27 PM
    Ckatz53
    Ckatz53 Newish
    MD
    Yup. Everyone overthinks it. Its a simple radar function that just needs to mimic stock angling.
  20. Nov 15, 2020 at 6:43 PM
    Sgasp90
    2020 trd pro tundra
    Where did you install the washers? Behind the radar sensor or on the grill?
  21. Nov 15, 2020 at 6:59 PM
    Vin63
    Vin63 New Member
    2022 Tundra SR5 DC
    Behind the sensor, on the bottom mounting points. Try 1-3 washers and drive and see if it goes away. Mine worked with 3 washers, but I had TRD Pro replica grill.
  22. Nov 15, 2020 at 7:00 PM
    Sgasp90
    2020 trd pro tundra
    Thanks for al the help
  23. Nov 19, 2020 at 6:46 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    Just pay them to zero calibrate your truck. It's like 100 or so. Why bother shimming the yaw sensor when you can do it right. They will have to calbirate your PCS as well.
  24. Nov 19, 2020 at 6:47 PM
    netranger6
    Jeremy
    Your YAW sensor is off as well bro. YOu can shim it, or let Yota zero calibrate.
  25. Nov 19, 2020 at 7:00 PM
    Ckatz53
    Ckatz53 Newish
    MD
    A $0.25 fix versus $100? Oof.
    AggiePhil and Kevfran99 like this.
  26. Nov 21, 2020 at 10:14 PM
    the ER kid
    the ER kid New Member
    2020 Platinum Crewmax
    What did you decide to do? Still having problems?
  27. Nov 26, 2020 at 5:46 AM
    Sgasp90
    2020 trd pro tundra
    Zero calibration and everything working the way it should
    the ER kid likes this.
