Lift / Wheels / Tires - What to do.
Discussion in 'Wheels & Tires' started by TTU19, Jan 26, 2017.
  1. May 3, 2017 at 7:45 AM
    #121
    TTU19
    TTU19 [OP] Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    So I'm at Toyota and they highly recommended the procomp level which uses spacers, blah. Hell of a lot cheaper but not sure it will ride as smooth as they say.
    So frustrated with all this lift stuff, no one seems to know what the hell to do and too many options. I sure as hell don't know. Think I may just scrap the whole idea.
  2. May 3, 2017 at 8:00 AM
    #122
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    It's not that complicated Wes. Here's what I would do. It doesn't seem like you want to spend for Kings or Icons, etc. So depending on budget, I'd go for Radflo, Boss, OME, Bilsteins, spacer lift, in that order. Find the wheels you want in +12 to +18. Throw some STT Pros or Ridge Grapplers on in 295/70/18. Trim some plastic and you're done.
    :transformer:
  3. May 3, 2017 at 8:07 AM
    #123
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Yeah I just called another local place to get a quote on everything. So we'll see what they come up with. They recommended a readylift spacer lift, some st option and replace the UCAs.
  4. May 3, 2017 at 8:17 AM
    #124
    Newm
    Newm New Member
    KC
    I'm waiting patiently for those myself...but the struggle is real.
  5. May 3, 2017 at 9:38 AM
    #125
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    These shops will likely push the spacer lifts because the parts cost is low and the labor will probably be about the same as a coilover lift, but at a much smaller overall cost.
  6. May 3, 2017 at 9:39 AM
    #126
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    IMO: Radflo, Bilstein 6112/5160, Boss, OME, Bilsteins 5100, spacer lift
  7. May 3, 2017 at 9:42 AM
    #127
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    For real - I am like this waiting for them: :bowdown::drunk::cheers:
    Newm[QUOTED] likes this.
  8. May 3, 2017 at 10:55 AM
    #128
    TTU19
    Wes
    Tx
    2021 TRD Sport
    So if I do go with the Boss kit, do I really need to replace the UCA right away? What would be the biggest added benefit for doing that? I'm not going to be offroading, so would it really benefit me anyway?
  9. May 3, 2017 at 11:39 AM
    #129
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    It pretty much comes down to how much you want to spend and what type of driving do you plan on doing with your new lift. Honestly, I know nearly all here say don't do a spacer lift and I and probably wouldn't have but I did. For me I really haven't notice any issues but then again I really haven't even taken her off roading (not even to the snow which would be the main reason I bought a 4x4). So if your just going for a look and don't plan on doing any decent off roading or want to throw away the money you spend on your off road package, get spacers and be happy. Understand some might tease you about doing so (heck one off road shop claimed my Toytec TU3 leveling kit was just an over priced/over engineered kit and compared to some kits it might be) but I'm satisfied with it for now. I plan on staying with my current set up until I wear out my Bilstein 4600 shocks and then replace my set up with something nicer.
    If your thinking about doing some decent off roading then you're better off upgrading now.
  10. May 3, 2017 at 11:54 AM
    #130
    TTU19
    Wes
    Tx
    2021 TRD Sport
    That's the thing. I wont be doing any offroading what so ever, my truck isn't a 4x4. Maybe the occasional drive through the pasture, but I've done that stock. All I want is a smooth ride like it is now. My problem is I see everyone talk bad about spacers so in my head, I dont want that. Everyone says BOSS or better, so I'm leaning towards that. I know it will be good, but do I really need it. $300 vs $1800. Or maybe i can still replace the shocks with the Bilstein setup, at least then it should be better than stock and not be as much as the BOSS.
    Did you replace the UCAs?
  11. May 3, 2017 at 12:00 PM
    #131
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Wes, I still have my stock UCA's. You'll be fine especially since you won't wheel it. My alignment is all in spec except the caster. Which doesn't wear tires.
    PermaFrostTRD likes this.
  12. May 3, 2017 at 12:07 PM
    #132
    r4z0r51o
    Dave
    Wow, I always thought the TSS package was a 4x4 off road package. Just my opinion, but since you're not planning on off roaring but would like to just upgrade your ride. Why not just go with the 5100's? Honestly, most of the guys on here will off road much harder than I plan too so I can see why they upgrade to the higher end stuff but for the 95% street driving I do, my Toytec spacer works for me. No, I haven't replaced my UCA's ...
  13. May 3, 2017 at 12:13 PM
    #133
    TTU19
    Wes
    Tx
    2021 TRD Sport
    No the TSS says "Off Road", but doesn't mean it's 4x4. I think it's because they add the bigger more aggressive wheels.
    Yeah, I'm someone that always wants the best, but that's where I'm now trying to convince myself if I need to spend that much on something I won't use tonits max or need.
    Sorry for the back and forth, ha
  14. May 3, 2017 at 1:30 PM
    #134
    r4z0r51o
    Dave
    I went ahead and reinstalled my flares Here's a close up of what my +20's w/ 295's look like.
    CM-LENNY and TTU19[QUOTED][OP] like this.
  15. May 3, 2017 at 1:31 PM
    #135
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Cool, thx. So if I go +1, I should stick out just a touch more.
  16. May 3, 2017 at 1:36 PM
    #136
    r4z0r51o
    Dave
    Roughly 3/4" more ...
    Since I don't really off road I'm tempted to go with some 1 to 1.25" spacers again until I buy new tires.
    Biggest issue I have is that would put me squarely back in line with having to do the CMC mod.
    TTU19[QUOTED][OP] likes this.
  17. May 3, 2017 at 1:36 PM
    #137
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
  18. May 3, 2017 at 1:38 PM
    #138
    TTU19
    Wes
    Tx
    2021 TRD Sport
    That may be perfect then for what I'm going for.
    r4z0r51o[QUOTED] likes this.
  19. May 3, 2017 at 1:39 PM
    #139
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I spoke to a guy at 4 wheel parts yesterday about my lift options and coilovers.. he told me if I wasn't going to do much off-road and since my truck has brand new struts on it, that a spacers would be just fine.. when I put about 40-50k miles on it and about to need some new struts or whatever. Then I should look into spending that $ and putting on coilovers at that point.. no sense in wasting brand new strut that's good for the next 3-4 years
    r4z0r51o likes this.
  20. May 3, 2017 at 1:44 PM
    #140
    r4z0r51o
    Dave
    Exactly my point, that's why I went with spacers ... For now.
  21. May 3, 2017 at 1:52 PM
    #141
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I just realized I might have been talking about different spacer.. not tire spacer :facepalm:
  22. May 3, 2017 at 1:56 PM
    #142
    TTU19
    Wes
    Tx
    2021 TRD Sport
    No, I think we are all on the same page. 40-50K miles? I'm already at 17K, so it wont be long before I'm up there, ha. But that does make a lot of sense. All I care about is that it rides smooth.
  23. May 3, 2017 at 1:57 PM
    #143
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    No, Dave is talking about both spacers. And the same one you're talking about.
    r4z0r51o and Jsena[QUOTED] like this.
  24. May 3, 2017 at 2:07 PM
    #144
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Oh good.. just thought I'd share the words of wisdom I received yesterday by a " Professional " #NoteTheQuotationMarksOnProfessional :argue:
    joonbug[QUOTED] likes this.
  25. May 3, 2017 at 2:12 PM
    #145
    TTU19
    Wes
    Tx
    2021 TRD Sport
    I hear you. I've called there before and talked to some guy who I think knew less than I did. Ha..
    Jsena likes this.
  26. May 3, 2017 at 2:20 PM
    #146
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I ran without UCAs for a year on ~2.5 - 3" front lift. No issues. Was able to get in alignments specs. When i added the TC UCA you could tell a difference in the easy movement and added travel. Made for a better ride.
  27. May 3, 2017 at 2:21 PM
    #147
    PMG
    PMG New Member
    I think you should go 5100s all around at top setting with a shim and toytec or CB shackle to raise the back about an inch. This would basically give you a 2.75/1 lift level. Some have had tougher times with alignment and some haven't.
    If you want level and a nice ride then go 2nd notch up front with a shim and 5100 at back w/o shackles.. I just did this with some 295/70r18 Ridge grapplers and am very happy with the look and ride.
  28. May 3, 2017 at 5:16 PM
    #148
    r4z0r51o
    Dave
    Lol ... No, we're talking about the same thing and then I spoke about wheels spacers (Spidertrax, Bora) regarding how Wes is also trying to figure out what size and offset he wants his wheels in. Sorry if I threw you off ...
    Jsena[QUOTED] likes this.
  29. May 3, 2017 at 5:51 PM
    #149
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Good.. I've been dropping the ball all day today.. minds been busy in my Lift chit.. found some killer deals.. about to pull the trigger asap...
  30. May 3, 2017 at 5:52 PM
    #150
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Deals on..?
