Leveling kit vs lift
Discussion in 'Suspension' started by Cpa757va, Oct 8, 2019.
  1. Oct 19, 2019 at 6:44 AM
    HazMatt
    HazMatt Go go gadget thingamajigger
    2025 MGM Tundra Crewmax 4x4
    Former 2019 MGM Tundra TRD Sport 4x4: Toytec Boss Coilover suspension, JBAOffroad UCAs, Black Rhino Fury Gunmetal 18x9.5, Nitto Ridge Grappler 295/70R18, Access Vanish bed cover, spray-in liner, running boards, wind deflectors, Borla exhaust, Bedrug liner, rear floor storage, LED front turn signal bulbs, LED interior lights, TOGUARD dash cam, Yaesu FTM-400XDR HAM radio, Victory 4x4 18” modular bed rack, Tepui Autana 3 RTT
    That's good to hear. Definitely helps! I ended up buying the bumper spacer (1/2 inch) from Boss 4x4s and put those on to extend the bumper out for clearance. It appears my issue is going to be slightly more exaggerated than your setup because I have 18x9.5s and 12mm offset. Boss 4x4s included a pre-cut BMC plate with the bumper spacer. They even included detailed instructions for completing the BMC. I know a guy who welds and he offered to let me bring the truck by and help complete it for free. Saves me $400 that the local shop wants to charge to complete it.
  2. Oct 19, 2019 at 6:59 AM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    Yea I’ve got a bumper spacer kit from Coachbuilder it’s pushed out 1” and I was still rubbing the front. I see your set up is more aggressive and might have more issues. But heck if you’ve got the part and have help, I’d say get that bmc done for piece of mind. Eventually I’m aiming to get a higher clearance front bumper because one day id like to run a 35x12.5. It’s surprising how the 35x12.5 looks so much bigger than my 295.
  3. Oct 19, 2019 at 7:08 AM
    HazMatt
    Yeah, I agree the 35s look bigger than the 295/70s, but I think I'm going to stick with them for the foreseeable future. I'm really focusing on longevity with this truck and I'm comfortable with the compromise on the 295/70s being about 3/4-1" narrower and easier on the wheel bearings. With the 12mm offset and 9.5 inch wide rim, I feel I'm already pushing it lol.
  4. Oct 19, 2019 at 7:10 AM
    HazMatt
    Oh, and what air pressure you running on yours?
  5. Oct 19, 2019 at 7:16 AM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    I know what you mean about longevity, mine is for travel and fun wherever we go. Around home I’ll run 38psi but usually when we load up and travel I’ll do 40-42psi. Even at 38 it’s very firm ride.
    HazMatt[QUOTED] likes this.
  6. Jan 4, 2023 at 10:11 AM
    KTR
    KTR New Member
    Hello All - Similar question to some above. Want to level off 2017 4wd double cab w/TRD odd road package. If i go with Bilstein 5100's front & rear & change tires to DISCOVERER® AT3 XLT™Tire Size:LT295/70R18/E will i have any rubbing issues etc?
  7. Jan 4, 2023 at 4:16 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    You may have a bit of rubbing on the mud flaps and fog light cover.
  8. Jan 4, 2023 at 8:06 PM
    KTR
    KTR New Member
    TY. Got tire size from same truck as mine I saw in parking lot at work, liked the way it looked. Having said that, what is largest tire size can i go with that I wont have any rubbing/clearance issues?
  9. Jan 8, 2023 at 9:28 PM
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
  10. Jan 9, 2023 at 8:19 AM
    KTR
    KTR New Member
    TY. Reviewed that, talked to local tire shop/garage I use. Going with 275-70/18's, Falken Wildpeak. Will post Before/After pics when done.
  11. Jan 9, 2023 at 8:21 AM
    GWill
    Willis
    2020 MGM TRD Pro
    Nice, theyre gonna look good
