Leveling 22 Platinum with AVS/Air
Discussion in 'Suspension' started by 2bak, Dec 22, 2021.
  1. Sep 7, 2022 at 12:28 PM
    #151
    22platitundy
    22platitundy New Member
    2022 White Tundra Hybrid Limited TRD Off-Road
    Looks great. Did you have to use wheel spacers?
  2. Sep 7, 2022 at 3:34 PM
    #152
    99ways2die
    99ways2die New Member
    NJ
    2022 Tundra Platinum
    Didn't need spacers and ran w/o them for a week once I had these tires installed (more than enough clearance from upper CA/etc).
    But, I didn't like how "tucked in" the OEM wheels are so I got a set 1" BORA spacers regardless, to achieve this:
  3. Sep 9, 2022 at 5:04 AM
    #153
    mike350z
    mike350z New Member
    2015 Tundra CrewMax Limited 4x4
    Looks great! Just a question, I've never used spacers before; many years ago I heard these spacers were problemetic as they weren't as strong as a wheel with offset and could cause damage; have they gotten better?
  4. Sep 9, 2022 at 5:34 AM
    #154
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    I'm running them on my 2014 for the last 3 years now without issues. I'm not sure I would run aluminum spacers on 3500 but so far so good in this 1/2 ton. I tow a trailer with a Kubota compact utility tractor every other week or so without issues.
  5. Sep 9, 2022 at 9:00 AM
    #155
    99ways2die
    NJ
    I've been towing a 4000lbs trailer/boat package on spacers for over a decade now-no issues....and I don't drive slow with it.
    -99
  6. Sep 15, 2022 at 12:04 PM
    #156
    Skinny1371
    Skinny1371 New Member
    2022 TRD 4x4
    were they able to fix it at the dealership? I’m having a heck of a time adjusting mine.
  7. Sep 15, 2022 at 12:06 PM
    #157
    Skinny1371
    2022 TRD 4x4
    I’ve made all kinds of manual adjustments to the ride height, and somehow the Neutral settings are all out of whack. Anyone know how to factory reset this system and put it back to where it was at factory so I can make the adjustments from there?
  8. Sep 15, 2022 at 12:07 PM
    #158
    eddiefromcali
    eddiefromcali New Member
    Eddie
    100% Stock
    call westcott
    Skinny1371 likes this.
  9. Sep 15, 2022 at 7:19 PM
    #159
    WPTundra1794
    WPTundra1794 New Member
    Scott
    2022 Tundra 1794
    Someone uploaded a pdf document of the process to reset your rear air system. I think it came from a dealer.
    https://www.tundras.com/threads/2022-1794-with-air-suspension.112786/
  10. Sep 16, 2022 at 3:34 AM
    #160
    Skinny1371
    2022 TRD 4x4
    Spent a while on the phone with Jeff yesterday from Westcott. Evidently the potentiometers that control the height can get out of sync and have to be clocked in the exact same position to work properly. Somewhere along the way, mine have become out of sync and is going to take the dealership hooking up software to the system to put them back in the correct position. I’m taking it to the dealer today.
    eddiefromcali[QUOTED] likes this.
  11. Sep 16, 2022 at 8:32 AM
    #161
    eddiefromcali
    Eddie
    100% Stock
    sounds like you moved the sensor while installing the new arms. Shouldnt take long at the dealer
  12. Sep 16, 2022 at 8:41 AM
    #162
    bigblue14
    Craig
    Are different arms needed? I thought there was room with the existing arms to slightly raise the rear.
  13. Sep 16, 2022 at 8:51 AM
    #163
    eddiefromcali
    Eddie
    100% Stock
    no need for new arms, really. Most of us just adjust the oem arms and go with that.
    bigblue14[QUOTED] and 22PlatWCP like this.
  14. Sep 16, 2022 at 9:21 AM
    #164
    Skinny1371
    2022 TRD 4x4
    It’s proving to be a chore at this point. 3.5 hours later and still here.
  15. Sep 16, 2022 at 10:11 AM
    #165
    bigblue14
    Craig
    Cool thanks for the confirmation. I'm planning for the TRD lift in the front and raising the rear through this method.
  16. Sep 16, 2022 at 10:28 AM
    #166
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Odd that the airbag is not in constant contact with the axle. Even with adjustments it's still floating on what looks like a plastic puck rubbing on a metal plate.
  17. Sep 16, 2022 at 11:58 AM
    #167
    TheSS712
    TheSS712 New Member
    Shayne
    2022 Army Green Tundra Limited
    I think that is the airbag cover. At least that is what I noticed when I was under my truck the other day. The airbags are actually attached to the axle.
  18. Sep 16, 2022 at 12:38 PM
    #168
    eddiefromcali
    Eddie
    100% Stock
    correct, its just a cover. the bag is attached to the axle and frame
  19. Sep 16, 2022 at 1:40 PM
    #169
    TheSS712
    TheSS712 New Member
    Shayne
    That's what I figured. I was just under it again to put the levers all the way up since I would still hit the bump stops. The rear now sits about 2" higher than the front which I would think is how it should sit stock. It never really had a rake to it until now. Should make for a much better ride over bumps and the many potholes these days. lol
  20. Sep 16, 2022 at 3:46 PM
    #170
    eddiefromcali
    Eddie
    100% Stock
    Throw it in Comfort and enjoy the ride
  21. Sep 17, 2022 at 11:17 AM
    #171
    TheSS712
    TheSS712 New Member
    Shayne
    I don’t have the comfort mode but, it definitely improved the ride. No slamming down on the bump stops anymore. This is probably how the truck should have come from the factory.
  22. Sep 18, 2022 at 6:53 AM
    #172
    ICTUNDR
    ICTUNDR New Member
    Kyle
    2022 Toyota Tundra Platinum WCP
    So I’m in a bit of a jam as well. Installed my kit yesterday and the passenger side sensor was spun around and I’ve spent two hours last night trying to sync it back with the driver side but no luck. Does anybody know what what to do at this point?
    Forest likes this.
  23. Sep 18, 2022 at 1:34 PM
    #173
    Jkwolfe09
    Jkwolfe09 New Member
    Jerren
    What do you mean by sensor is spun around??
  24. Sep 18, 2022 at 1:44 PM
    #174
    ICTUNDR
    ICTUNDR New Member
    Kyle
    The height sensor that the bracket connects to is now out of sync with the system because when I was loosening the nut holding the OEM bracket to put on the bracket that comes with the Westcott AVS kit, the positioning of the sensor turned as well. As a result it’s out of sync with the driver side sensor and the air up/down switch won’t operate properly now. Also, it’s aired all the way down.
  25. Sep 18, 2022 at 1:47 PM
    #175
    eddiefromcali
    Eddie
    100% Stock
    Yep...exactly what Westcott tells you not to do
  26. Sep 18, 2022 at 7:33 PM
    #176
    Jkwolfe09
    Jerren
    I guess I just don’t know how you managed that…
  27. Sep 19, 2022 at 5:02 PM
    #177
    ICTUNDR
    ICTUNDR New Member
    Kyle
    Ok, bonehead move of the day. I initially installed them upside down. So today I installed the brackets correctly and all is well! Wheels and tires go on tomorrow :)
  28. Sep 19, 2022 at 7:12 PM
    #178
    Jkwolfe09
    Jerren
    Lol happens to the best of us! I installed the afe aftermarket levers makes the truck 100% level at the neutral position if you have a front end leveling kit.
  29. Sep 22, 2022 at 7:03 AM
    #179
    Jibber82
    Jibber82 New Member
    I'm getting my Platinum Hybrid with AVS/Air in a couple weeks. I wanted to get the TRD lift kit but the dealer and this forum told me it's not compatible with AVS. I just want to fit 35" tires on the stock rims.
    • Is there an advantage to go with the Westcott collar lift over the Amazon spacers?
    • If I go with Westcott collar lift do I need the FRONT ONLY kit or the front and rear kit?
    • Do the brake lines need to be extended?
    • Do I need wheel spacers?
    • Does a leveling kit void the warranty?
  30. Sep 22, 2022 at 7:05 AM
    #180
    eddiefromcali
    Eddie
    100% Stock
    You can fit 35s with a 1.75in lift and adjusting rear air ride levers. No need for anything else
