2022 1794 with air suspension
Discussion in '3rd Gen Tundras (2022+)' started by Lou1947, Sep 8, 2022.
  1. Sep 8, 2022 at 8:55 PM
    Lou1947
    Lou1947 [OP] New Member
    Tundra 1794
    I am in the process of adjusting the rear height of my truck to stop the bottoming out. I understand the adjustment part of undoing the ten mm nut and moving the lever down to get more height. My question is once I have done it do I need to start the truck to measure the height on each side. My guess is that if I do the measurements without starting the truck the air bellows won’t be full of air and therefore the car won’t be at the correct height. Am I right or wrong. Thanks I’m advanced for your replies
  2. Sep 9, 2022 at 5:01 AM
    devron11
    devron11 New Member
    Ron
    Denver
    Per the OM, the engine must be running.
    22PlatWCP likes this.
  3. Sep 9, 2022 at 8:06 PM
    Jkwolfe09
    Jkwolfe09 New Member
    Jerren
    I had to lower to lowest setting then raise it to highest setting and it set itself in the middle.
  4. Sep 12, 2022 at 10:50 AM
    Touchdown
    Touchdown New Member
    Took mine to the dealer today and they adjusted rear air suspension and leveled the headlights per TSB 0070-22. Ride difference was huge.
    Carolina Peej likes this.
  5. Sep 12, 2022 at 11:19 AM
    Lou1947
    Tundra 1794
    Thanks for the input. If you don’t mind would be kind enough to measure the height of the rear on each side. From ground to lower edge of fender. Thanks in advanced
  6. Sep 12, 2022 at 11:41 AM
    Breathing Borla
    so there was an official TSB for the bump stop issue for the air suspension?
    do you have a copy to post?
  7. Sep 12, 2022 at 12:06 PM
    Lou1947
    Tundra 1794
    I adjusted mine (in the neutral position)to about 37 and 4/16 and my truck now rides very smooth and doesn’t hit the bump stops. I don’t know if I may have to adjust my headlights leveled with this rear height setting? Any thoughts?
  8. Sep 12, 2022 at 1:18 PM
    Touchdown
    Ride height from ground to fender after the adjustment is right at 38 inches. As an FYI I have a platinum, wheel size 265/60/20, but I’m sure the tsb applies to the 1794. I do not have a copy. I gave the number to the dealer and they pulled it up. They said mine was out of spec. The rear always looked real low to the ground and now it looks ‘normal’
    Hella Krusty and truckit like this.
  9. Sep 12, 2022 at 1:32 PM
    Touchdown
    My invoice, covered under warranty, stated ‘adjusted height control Sensor and headlights for new height’.
    truckit and Breathing Borla like this.
  10. Sep 12, 2022 at 1:54 PM
    Lou1947
    Tundra 1794
    Thank you for your quick reply. My Tundra is a 1794 4WD. I will have to wait and see if my headlights need adjustment.
  11. Sep 13, 2022 at 4:15 PM
    sx64
    sx64 New Member
    See attached for TSB-0070-22. Screenshots of the TSB were posted by someone else in a Fb I lurk in. I took their screenshots and made it into a PDF for myself.
    I took my 22 Platinum w/ AVS in recently for this TSB to my local dealer. It smoothed my ride out tremendously. Prior to the adjustment, little bumps were very noticeable and jarring. After the adjustment, that all went away. Apparently my adjustment was minor enough such that it didn't require any headlight adjustment.
  12. Sep 21, 2022 at 6:51 AM
    gowithit13
    gowithit13 New Member
    Ray
    2023 Platinum
    I took my Platinum into the dealership September 1st for this adjustment.
    I have been waiting for this to be addressed since I purchased the Truck on February5th. Between the dealer and Corporate it has been never ending.
    This rides like a different truck, I could not be happier.
  13. Sep 21, 2022 at 6:00 PM
    Lou1947
    Tundra 1794
    Same here. Now they need to fix the noise that I have on the right rear when going over bumps. It seems to be coming from the composite bed near the wheel well. I have checked the tailgate and that’s not the culprit
  14. Sep 21, 2022 at 8:29 PM
    Carolina Peej
    Carolina Peej Hey can you hold the light for me real quick?
    North and South Carolina
    2022 Midnight Black Metallic 4x4 Tundra Platinum 5.5 w/ load leveling + AVS, HUD, and Power Running Boards
    Didn't know this was a TSB until now. I have been consistently surprised how harsh the rear suspension was at times, especially for an air suspension. I noticed the bump stops looked surprisingly low the other day. Went dove hunting and put it in high mode out driving on the farm. It rode incredibly better, and I just figured normal was set up for street performance and that's why they had high mode. Tried to set it to high to go over the speed humps in my neighborhood, but kept resetting to Normal in between humps.
    Man am I glad I stumbled across this post. I cannot wait to get her in there and ask for this TSB. Thanks guys! Great posts. Thanks sx64 for pasting the TSB!!
    truckit likes this.
  15. Oct 10, 2022 at 3:07 PM
    plhinds
    plhinds New Member
    PAUL
    22 Trindra 1794
    Just took my 1794 in. We owned a 2018 Landcruiser and this truck rode and sounded horrible. I was very disappointed. I followed this thread argued and pushed dealer to follow the TSB and set at max spec. The distance btw the bump stop and axle was about 0.5”. The spec is about 1.3-1.7”. This change raised the ground to top of wheel well from 36.5 to 38.25”. Besides better ride it just looks like a truck instead of a loaded down truck. Also had them drop the ESE (fake engine noise). It was huge. Finally feels and sounds more like our Landcruiser (no noise). Pic is at normal height setting.
    truckit likes this.
  16. Oct 10, 2022 at 4:01 PM
    Lou1947
    Tundra 1794
    I just don’t understand why Toyota is shipping the Tundras out with the air suspension maladjusted. When I first got my truck it rode horribly. After the adjustment it made a night get and difference . Now the truck is quiet and I couldn’t be happier. No more hitting the bump stops and no noise coming from the bed when going over bumps.
  17. Oct 10, 2022 at 4:23 PM
    plhinds
    plhinds New Member
    PAUL
    22 Trindra 1794
    I’m confused too and also that I had to source it from ToyotaUSA and basically force it on my dealer. After I got the TSB they could not argue it was in spec. They need to recall to keep customers happy.
  18. Nov 29, 2022 at 6:54 AM
    truckit
    truckit New Member
    Georgia
    2023 1794 MGM, AVS, power running boards, spray in bed
    Anyone know if this problem was corrected by Toyota in the 2023 model year?
    Tmymac likes this.
  19. Nov 29, 2022 at 9:53 AM
    Tmymac
    Tmymac New Member
    Tommy
    1794 Magnetic grey
    None
    It was not. Picked up my 2023 1794 Saturday and it will knock your teeth out. Also left passengers window goes down about 3/4 of the way and stops. Push the button again and after a popping noise goes All the way down
    Kap1 and truckit[QUOTED] like this.
  20. Nov 29, 2022 at 2:35 PM
    truckit
    truckit New Member
    Georgia
    Thank you Tmymac, sorry to hear about your window issue. Also, thanks to sx64 for uploading the technical service bulletin. Off to my dealer with TSB in hand.
  21. Nov 30, 2022 at 12:51 PM
    truckit
    truckit New Member
    Georgia
    For those out there like me who have taken delivery recently. Build of 10/18, took ownership of my 2023 truck on 11/12 and would have expected that Toyota would have fixed this mistake during manufacturing given TSB but confirmed (see pic) that they have not.
  22. Dec 3, 2022 at 11:38 AM
    TundraMJ
    TundraMJ New Member
    2023 Platinum 4x4
    Hi All
    Just bought a 2023 platinum and before I measure the distance from the bump stop bottom to the top of the realm axle housing, I want to make sure that I’m measuring when the trucks air suspension is at the “normal “ setting. Is that correct?
    Or am I supposed to measure at it’s lowest, or highest?
  23. Dec 3, 2022 at 11:40 AM
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    Yup
  24. Dec 3, 2022 at 12:41 PM
    TundraMJ
    TundraMJ New Member
    2023 Platinum 4x4
    Thank you. Mine is at 11.7 mm when I measured. That can’t be good. Build date is November 2022. So they definitely have not remedied this issue yet.
    Tmymac likes this.
  25. Dec 3, 2022 at 2:43 PM
    Tmymac
    Tmymac New Member
    Tommy
    1794 Magnetic grey
    None
    Took my 5 day old built in October truck in for window sticking and harsh ride. They said my truck was a 23 and TSB did not apply. They are idiots
    Hella Krusty likes this.
  26. Dec 3, 2022 at 4:36 PM
    truckit
    truckit New Member
    Georgia
    What!? I would push back, that's BS. The truck design and specs have not changed from 2022 to 2023 so the TSB date is irrelevant. I have my service scheduled for 12/13 and will post how my conversation goes.
    Tmymac[QUOTED] likes this.
  27. Dec 3, 2022 at 4:46 PM
    Tmymac
    Tmymac New Member
    Tommy
    1794 Magnetic grey
    None
    They didn’t even look. Would only had taken a few minutes
  28. Dec 4, 2022 at 7:39 AM
    TundraMJ
    TundraMJ New Member
    2023 Platinum 4x4
    Mine is going in tomorrow. I’ll let you all know how it goes. I’m actually at 21mm in the “normal” position as of now. I’ll measure it after they perform the TSB and report the difference.
  29. Dec 4, 2022 at 3:15 PM
    fastarget
    fastarget New Member
    Thank you, this is great info, at least we can walk in and present something to the service department. Has Toyota resolved this on the current production run?
  30. Dec 4, 2022 at 4:39 PM
    Point Man
    Point Man New Member
    Mark
    Racecity USA Mooresville, NC
    2023 1794 MGM
    Tonneau Cover, Cat Shield, Power Boards, Bed Mat, Rear Light Bar
    Sorry for the noob question but do all 1794's have the air suspension? I am looking at my spec sheet and it does not indicate that it does. Supposed to be arriving around Christmas.
    Tmymac likes this.
