Leveled confusion
Discussion in 'Suspension' started by Blkdmax, Mar 25, 2019.
  1. Mar 26, 2019 at 7:23 AM
    Blkdmax
    Blkdmax [OP] New Member
    Tennessee
    2021 Cement CrewMax 4x4
    That's what I have. It's odd if you select 2017 tundra it says 2.5" on the first notch. If you select 2010 or so it says 2" on first notch. Why the difference? I thought they were all the same as far as suspension went
    Called toytec, he said the 2.5" is approximate and no guarantee and basically I'm on my own now that they are installed. Said he'd ask David though and call me back.
  2. Mar 26, 2019 at 7:59 AM
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    This is helpful. I like things that are helpful. Here is another data point you can add:
    ADS 3.0 no preload & Toytec shackles set at 1"
    FR = 24.75
    FL = 24.75
    RR = 25.5
    RL = 25.5
  3. Apr 8, 2019 at 8:17 AM
    LiftMeUp
    LiftMeUp New Member
    that's the same route I plan on going, Eibach but on the 3" setting without shims. I'm hoping I can get away with stock UCAs and get the tires to fit and a good alignment. My measurements are different. I've got about a 3.25" difference in the rake from rear to front. David at Toytec said the back was a lil higher than norm and the front a lil lower than norm.
