Let's see your first gen - photo thread
Discussion in '1st Gen Tundras (2000-2006)' started by Rkcruza, Jan 6, 2014.
  1. Sep 13, 2023 at 7:23 PM
    #3241
    Ferny001
    Ferny001 New Member
    Fernando
    2006 spectra mica blue Tundra SR5 4wd
    Here’s my first tundra, was an 01 AC SR5 4wd V8. It had 270,000 miles before I sold it to an uncle. Truck was mint on the inside and didn’t show much of its high mileage. Had some scratches here and there on the outside but other than that she was a beaut.FullSizeRender.jpg IMG_0097.jpg42A8C555-4467-447F-A455-12D755127B50.jpg After selling my AC I had already knew I wanted a DC. With the price of them rising at the time I thought I’d never find a decent one for a good price. Lucky my search ended and I picked up an 06 DC 4WD SR5 in probably the best color IMO. Bought it with 132,000 miles and couldn’t ask for a cleaner interior. Truck has grey cloth interior and a sunroof which I thought only came on limited trims. Bought the truck exactly how it sits and the only cosmetic thing I did was throw in Ivan Stewart floor mats that I bought off a guy through the forum. Yes i know they belong in a AC but they don’t look bad and they ultimately fit. It’s been a little over a year and so far I’ve changed lower ball joints, rear main seal(it was leaking bad), fluids, and pinion seals. IMG_0447.jpg 8C8D322A-7753-43ED-85CD-DE7BCAAC2384.jpg
  2. Sep 14, 2023 at 11:37 AM
    #3242
    Tantal
    Tantal New Member
    2006 Tundra 4WD AC
    New here. Pretty vanilla 2006 4WD Access Cab. I see everyone doing some great builds, but I'm probably just going to do wheels, tires, and tint, then call it a day. I'm looking to get into some mild overlanding (not rock crawling) just to see some cool new sights, but not looking to do an actual "overland build". A nice $300 cot tent is plenty for my tastes. The truck appears to already have a leveling kit (bought it this way). If anyone knows the specs, I'm looking to go with SCS Ray10s 17x9 (3.5" backspacing with -38mm offset) with 275/70/R17s. Will this setup fit? Will it require trimming? Would I be better off with the 17x8.5 with 4.3" BS and -10mm offset?
  3. Sep 14, 2023 at 11:47 AM
    #3243
    I take it you've seen this thread already? If not, give it a once-over.
    That offset sounds absolutely nuts to me. They'll stick out waaaaay too far. This is my truck on 17x9 and -12 offset (4.53" BS). I'm at, or maybe just beyond the edge of the fender and rubbing significantly on the front flaps. BS sweet spot for no-rub is supposedly 4.75, Ideal 4.6 - 4.8 if memory serves?
    https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1697#post-3321503
    Create a new thread here on the forum with pics of what you've got - top and bottom of your front strut/shock, tie rods, swaybar links, upper and lower control arms. We can give you advice on where to go. But that wheel choice - I don't even think SCS makes that size in Toyota's bolt pattern?!
  4. Sep 14, 2023 at 11:57 AM
    #3244
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Yeah, that's how it all starts. Then the next thing you know it's a few years later and you've sunk over 5k into her. ;)
    Tantal[QUOTED] likes this.
  5. Sep 14, 2023 at 12:00 PM
    #3245
    Tantal
    Tantal New Member
    2006 Tundra 4WD AC
    Thanks for the reply. Yes, they do make them in 17x9 with 3.5" BS and -38 offset. I get confused as to the relationship between backspacing and offset. I've seen pics of @FirstGenVol 's truck with the Ray10s and that looks about right.
  6. Sep 14, 2023 at 12:05 PM
    #3246
    16x8 at -12 and 17x8.5 at -10 are the most common sizes you're going to find on 1st gens for SCS.
    FGV is running -10 on his. https://www.tundras.com/threads/let-me-see-your-wheels.126855/#post-3240144
    He rubs the frame at full-lock while in reverse running 33's (285/70r17) and I think 2.5" lift up front?
    I'm running 275/70r17 right now on my access cab (which has different geometry from doublecab/sequoia) and I'm rubbing, even with ~2" lift front and rear. And that's not even at full lock. We have at least one doublecab member with a strut spacer up front that gives ~1.5" lift and he's clearing the same 275 tire as me with no rubbing. He's got BFG KO2, I'm running Mickey Baja Legends.
    SCS is out of 17x9 at -10 in Ray10 right now. But anyway, create a new thread with lots of front suspension and a couple rear suspension pics so we can walk through what you need to be at.
  7. Sep 14, 2023 at 12:24 PM
    #3247
    Tantal
    Tantal New Member
    2006 Tundra 4WD AC
    @shifty`
    It looks like I'd probably be GTG with the SCS 17x8.5 with 275/70/R17. That would put me slightly smaller than FGV's, so could possibly eliminate the rubbing. Mine may already have a lift on it (I'm new to 1st Gen Tundras. I've had 3 Tacos, a 2nd Gen Tundra, and a 80-series TLC), but I'm really not up to speed on lift specs just by eyeballing. I'm currently on 265/70/R17s and there seems to be an abundance of space left in the wheel wells.
    shifty` likes this.
  8. Sep 14, 2023 at 12:30 PM
    #3248
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The rubbing really is not an issue. Don't let that stop you if you want 285's. It only rubs a tiny amount at very low speed and isn't causing any damage.
  9. Sep 14, 2023 at 12:46 PM
    #3249
    FTFY, spots in bold italic. I think it's pretty important to express there's definitely a sweet spot at certain heights and alignments to avoid rubbing.
  10. Sep 14, 2023 at 1:03 PM
    #3250
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    My front end is barely lifted 2 inches.
  11. Sep 14, 2023 at 2:15 PM
    #3251
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    If you rub, adjust your caster forward. That's why you got SPC.
    If you rub the front bumper, trim it.
    You can trim the plastic and the pinch weld too, but adjusting the caster might be easier.
    I say this as someone with 295/75r16.
    No I didn't mean 285
  12. Sep 14, 2023 at 2:42 PM
    #3252
    Definitely had a ton of space in mine with the stock 265/65r70, especially after lift. I could've stuffed both my kids in one wheel well.
    There's no way you're not lifted more than me. But maybe I'm wrong. I think a small + caster tweak and the different wheel/tire combo would have me not rubbing flaps at 275/70. But ... we'll see.
    Why bother? No point in cutting when you can let the tire massage it away for you. Not like plastic is gonna wear it down more than asphalt.
  13. Sep 14, 2023 at 4:23 PM
    #3253
    DJenerated
    Dija
    The Lone Star State
    Well the metal pinch weld behind the thin plastic might :D
  14. Sep 14, 2023 at 4:26 PM
    #3254
    DJenerated
    Dija
    The Lone Star State
    @FirstGenVol likely has more caster on his UCAs than you do with the SPCs in the neutral position, @shifty` .
    But I don't know which UCAs he has or what their caster ratings even are. Just speculating. He does have a high clearance front bumper though. So he could, in theory, have some hella UCA caster like I do.
    FirstGenVol and shifty` like this.
  15. Sep 14, 2023 at 4:32 PM
    #3255
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Exactly. I was lifted 2" to start and then I lost a little when I added the steel bumper. My caster is closer to 3.0 which is the sweet spot.
    Fitting 285's on these trucks really isn't that hard. I didn't trim anything but I did remove my mud flaps.
    shifty` likes this.
  16. Sep 14, 2023 at 5:22 PM
    #3256
    DJenerated
    Dija
    The Lone Star State
    I'm at -.75°, if I'm reading the chart correctly. I know I'm one setting away from the front most caster setting on my UCAs.
    I had to trim the pinch weld to fit the 295/75r16's at full stuff on a 3" lift
  17. Sep 15, 2023 at 11:11 AM
    #3257
    veese
    veese New Member
    upload_2023-9-15_13-1-57.jpgupload_2023-9-15_13-1-57.jpgupload_2023-9-15_13-1-57.jpgupload_2023-9-15_13-1-57.jpgupload_2023-9-15_13-1-57.jpg
    I had been long overdue for a makeover. Decided to go subtle. A lot of the clear coat was flaking off and even had a little surface rust on the roof over the pass. side access cab door. The whole truck is Raptor liner in Safety Orange tint from TCP Global.
  18. Sep 15, 2023 at 11:13 AM
    #3258
    Holy cow, that's orange! Orange you glad you did it?! ;)
    Did you pop out the glass to get in those spots too? How does it look with both side doors open?
    artsr2002 likes this.
  19. Sep 15, 2023 at 11:18 AM
    #3259
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  20. Sep 15, 2023 at 12:47 PM
    #3260
    Tantal
    Tantal New Member
    2006 Tundra 4WD AC
    @veese
    That's a bold move, Cotton. It's going to take just the right set of wheels to set it off just right. What do you have in mind?
    DJenerated likes this.
  21. Sep 15, 2023 at 12:54 PM
    #3261
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    shifty` and FrenchToasty like this.
  22. Sep 15, 2023 at 12:59 PM
    #3262
    veese
    veese New Member
    Lol, it is kinda brilliant, looking that is. I am glad. Now when the game warden asks “where’s your hunters orange?” I can say hell I’m driving it! I only did the outside and the front part of the access cab door. I did take off the vent windows so that would be covered well. I got some left over black so I may just sand, prime and spray the stock wheels
  23. Sep 15, 2023 at 1:27 PM
    #3263
    SCS Ray10 in brushed gold. They almost have an yolky-orange quality in normal light. https://www.tacomaworld.com/threads/scs-ray10’s-brushed-gold-pics.585021/#post-19645830
    And SCS staff have suggested they're only for the most discerning, avant garde truck enthusiasts who dare to push the envelope, they're "not for everyone" :D
    They'd really pop with that safety orange, bigtime. Anything else, especially neutrals in the grey/black/brown range, are going to get sorely lost and drown out, make the rest of the truck look bad. You need something aggressive and bright in there to really challenge the orange.
  24. Sep 15, 2023 at 8:07 PM
    #3264
    Tantal
    Tantal New Member
    2006 Tundra 4WD AC
    I think you need true gold beadlocks with the trim rings painted to match the truck.
    bmf4069, shifty` and FrenchToasty like this.
  25. Sep 15, 2023 at 8:27 PM
    #3265
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    bmf4069, shifty` and DJenerated like this.
  26. Sep 15, 2023 at 9:09 PM
    #3266
    2000truckoftheyear
    2000truckoftheyear 2000 motor trend truck of the year
    Sw Colorado
    2000 Tundra ac 4x4
  27. Sep 16, 2023 at 6:08 AM
    #3267
    Tantal
    Tantal New Member
    2006 Tundra 4WD AC
    When you're going full backwoods meth pimp, there can be no half-measures.:D
    bmf4069 and DJenerated like this.
  28. Sep 16, 2023 at 7:14 AM
    #3268
    It's a beaut! Welcome to the forum.
  29. Sep 17, 2023 at 11:34 AM
    #3269
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    my thought is a set of Trailready beadlocks. Just need to dust off the rims...
    8C572957-02BA-4793-B250-7633C8B122E2.jpg 22F1751F-A663-4378-A673-A663713030DA.jpg
    Voss likes this.
  30. Sep 17, 2023 at 12:35 PM
    #3270
    Tantal
    Tantal New Member
    2006 Tundra 4WD AC
    He needs those. Paint the centers gold and do the trim rings the same as the truck. Even black with orange trim would look good.
    Voss and FrenchToasty like this.
