Let’s see your front lawn skills
Discussion in 'Home Improvement' started by Mountun Goat, Jun 25, 2018.
  1. Jun 19, 2019 at 7:03 AM
    #121
    Mountun Goat
    Mountun Goat [OP] She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Nice work!
    OR18TRD[QUOTED] and Pudge like this.
  2. Jun 19, 2019 at 2:41 PM
    #122
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Front and back yard. I'm not as anal about it as I used to be. Just do enough now to keep it looking decent and mostly weed free so I don't lose it.
    As you can see I mow in several different directions. It's better for the grass so it's not pushed down the same direction all the time. It starts to look crappy if you do that, and itll start to leave tire ruts. My mower is 23 years old, bobcat 48" with original Kohler command 15hp. No roller or fancy attachments, Regular maintenance will go a long way. When I was in college I used the mower to pay tuition. I cut about 20 lawns a week with it.
  3. Jun 19, 2019 at 2:48 PM
    #123
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I’ll have my yard back next year, look out!
    I care more about my yard than my truck. 7FAA46A4-F7CB-4DF6-AD43-7B207827A611.jpg
  4. Jun 19, 2019 at 3:27 PM
    #124
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Front lawn
    Back lawn
    rebmo, MS22, Bob_Wiley and 10 others like this.
  5. Jun 19, 2019 at 3:42 PM
    #125
    CCLJ03
    Craig
    Try mowing the same stripes each time! Sometimes it takes time for good stripes to form.
    Try doing the same route for a couple of weeks!
    Stroke250 and Omohundro like this.
  6. Jun 19, 2019 at 3:56 PM
    #126
    Pudge
    CT
    If your mower has a plastic or rubber flap that drags behind it, try adding weight to it. It's the way the grass is laying down that makes the stripes. I've seen some people go as far as using rollers, like they do on pro sports fields
    OR18TRD, Stroke250 and jewsNbrews like this.
  7. Jun 19, 2019 at 4:45 PM
    #127
    Omohundro
    Jody
    McMinnville TN
    I have a striping kit on my mower, it’s just a bunch of rollers (heavy as hell).
    Here is my buddies yard about a year old, same mower and stripe kit. Key is to mow same direction every time, I start in the same spot every time. I also mow very tall 4-5”, it’s all about what kinda look you want. My neighbor is trying to mow his at 1”, he is getting there. This yard is mowed at 4”. 0F50E0E2-FB81-4A83-AC83-8866DCDAE656.jpg
  8. Jun 19, 2019 at 5:10 PM
    #128
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    I am not sure other than I believe it’s due to me bagging the clippings. This adds some weight to it as it goes along and helps “lay” the grass down. At least that’s my theory anyway. Lol
    Looks like @Pudge beat me to it!
    Pudge likes this.
  9. Jun 19, 2019 at 5:23 PM
    #129
    ToyotaTundraMike
    2015 Tundra
    I am a total newb to maintaining a lawn and this is what I have inherited.
    Not sure what type of grass (NW Florida).
    There is a bunch of this thin stuff on one side of the yard and some thicker grass in the back. Any suggestions on how to tackle this to get it nice and thick? The only weeds I really get are the long stems with a peace sign at the top.
  10. Jun 19, 2019 at 5:41 PM
    #130
    Navi
    Navi New Member
    2019 CrewMax Limited
    just finished adding an additional 130 ft.² of Zorro Zosia to my backyard. I started with Geo Zosia and had all kind of problems with it so I ripped it out earlier this week and put this down this evening.
    We just had a bunch of rain come through Atlanta so that worked out.
  11. Jun 19, 2019 at 7:32 PM
    #131
    Looks good Sean!
    Pudge[QUOTED] likes this.
  12. Jun 19, 2019 at 7:42 PM
    #132
    rallypanam
    rallypanam New Member
    2019 Doublecab Limited 4x4
    All 60 square feet of it!
    MS22, OR18TRD, Boosted4runner and 4 others like this.
  13. Jun 19, 2019 at 7:43 PM
    #133
    CCLJ03
    Craig
    That’s a beautiful 60 square feet.
  14. Jun 19, 2019 at 7:45 PM
    #134
    gm125800
    gm125800 New Member
    2018 GMC Sierra Denali
    That mulch border looks nice sir! I was looking at doing this to help keep some moisture in the summer months for the fence posts.
    CCLJ03[QUOTED] likes this.
  15. Jun 19, 2019 at 7:48 PM
    #135
    [​IMG] [​IMG]
    I made a stripper for my tractor.
  16. Jun 19, 2019 at 7:54 PM
    #136
    Pudge
    CT
    That's an incredible plot of land you've got there. How many acres? The corn yours too? What do you grow to the right of your driveway? Alfalfa? I assume you hay that field.
  17. Jun 19, 2019 at 7:58 PM
    #137
    Yes it is Alfalfa. I have around 6 but will be buying another 5 to 14 when he sells it.
    Stroke250 and Pudge like this.
  18. Jun 19, 2019 at 8:01 PM
    #138
    The big plot is a family and I spoke for what is around me. I don't want to have any close neighbors. I don't have anyone near me now and want to keep it that way.
    OR18TRD and Stroke250 like this.
  19. Jun 19, 2019 at 8:02 PM
    #139
    Pudge
    CT
    Alfalfa sells for crazy high prices around here but I guess it's tough to grow because not many farms grow it. I know a guy who keeps trying but has only succeeded in 2 of his fields, kinda weird. He has about 140 acres and has tried to grow it in 4 or 5, about 6 acre plots and only took off in 2 of them.
  20. Jun 19, 2019 at 8:03 PM
    #140
    We let the guy plant it on some of ours to cut down on the mowing time.
    jewsNbrews and Pudge[QUOTED] like this.
  21. Jun 19, 2019 at 8:31 PM
    #141
    CCLJ03
    Craig
    Thank you!
    I’ve always preferred the look of mulch over rocks. More maintenance, but I don’t mind keeping it up.
  22. Jun 19, 2019 at 9:33 PM
    #142
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    That's so weird to hear! Its everywhere around here. Hay and seed alfalfa. Although seed is disappearing due to contracts going to Canada and elsewhere.
    Boosted4runner and Pudge[QUOTED] like this.
  23. Jun 21, 2019 at 1:32 PM
    #143
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    Killer place Bryan!!!
    edited to add - my place looks like shit and I'll just daydream off your guys' pics. LOL
    I need to hook my brush hog back up and mow the field this weekend.
  24. Jun 22, 2019 at 3:21 PM
    #144
    Ps3udonymous
    Ps3udonymous Who is the smart ass that changed the title?
    From the picture, you have some Bermuda and looks like some trace amounts of st Augustine. Choose which one you want to grow more of. If it's Bermuda, mow your grass low (.5-1.5") and if you want the st Augustine, Jack your mower all the way up and mow often for both.
  25. Jul 20, 2019 at 7:34 PM
    #145
    Omohundro
    Jody
    McMinnville TN
    So I finally got some strips to look decent at the new place, it’s still a major work in progress but hey I’m calling it a win for now.
    At least until I kill it all this fall. 552C2437-2EBC-4003-93D0-97AA8C597751.jpg
  26. Jul 20, 2019 at 7:48 PM
    #146
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    B4 I lost it to crabgrass.. need to start using chemicals next year im thinking.. just use lawn restore and corn gluten
  27. Jul 21, 2019 at 1:48 PM
    #147
    Stroke250
    Todd
    Idaho
    2023 Ford F-350
    Another in the same direction with sunlight and still nice lines. I have some dry spots that need addressed with more water or it is some sort of lawn bug they have here Idaho.
  28. Jul 21, 2019 at 1:53 PM
    #148
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Seeing this makes me realize how bad I need to pressure wash my sidewalk lol.
  29. Jul 21, 2019 at 2:03 PM
    #149
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    What flowers do you have growing there and are they all perennials?
  30. Jul 21, 2019 at 2:05 PM
    #150
    Sas
    OKC, OK
    "Lawns so beautiful your dog will want to hump it."
