Let’s see your front lawn skills
Discussion in 'Home Improvement' started by Mountun Goat, Jun 25, 2018.
  1. May 14, 2022 at 10:37 AM
    #331
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    You’re definitely in the zone for it
    Moon Puppy[QUOTED] likes this.
  2. May 14, 2022 at 10:45 AM
    #332
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    Might just pull the trigger and get some and be done. Let it choke out the other stuff.
    Badknees and Omohundro[QUOTED] like this.
  3. May 14, 2022 at 10:45 AM
    #333
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    :jellydance:
  4. May 14, 2022 at 10:55 AM
    #334
    Omohundro
    Jody
    McMinnville TN
    I would wait to plant until the fall no matter what.
    Badknees and Moon Puppy[QUOTED] like this.
  5. May 14, 2022 at 11:06 AM
    #335
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Going to move the pasture in so there is less lawn, if I lived here full time I could keep the lawn pristine, one day though!
    B.Ross, WILLINH, Prostar 190 and 2 others like this.
  6. May 14, 2022 at 11:12 AM
    #336
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
  7. May 14, 2022 at 1:39 PM
    #337
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I’m in Anderson so you’re not far from me. No need to try to establish fescue right now-too much summer heat and the roots will never take. I aerate well each fall and overseed with a fescue blend and then a starter fertilizer. You’ll need to have a good irrigation system to keep fescue green and healthy in our area. I water every other day and starting very early around 3:30AM and when it’s coolest and evap. is low. I cut on my highest mower setting (4”) as fescue doesn’t like to be cut short. Water and sewer costs (if you’re on city) can be a concern. I’m not crazy about Bermuda, but it is more heat and drought resistant than fescue. I use Upstate Turf Professionals and Matt Davis. I think he told me he had a satellite business in Greenwood but I’m not 100%. If so they do a nice job fertilizing and treating for weeds and are very knowledgeable about all lawn care. Also, if you ever come to Anderson talk with Chad at Whitten’s Nursery. He is very good as well.
  8. May 14, 2022 at 8:07 PM
    #338
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    @Badknees
    Thanks for the help, I'm actually in Due West now so a little closer neighbor.
    I got a couple of good stands of Bermuda (I think it is) and would love to get it spreading out and taking over. I battled the moles today, put out a pesticide for grubs, gotta take the moles food source away. I think those buggers are causing more harm to the yard than anything right now. I'm going to give it a couple more weeks to see if I get anything more green going then will call someone in.
    Badknees likes this.
  9. Jul 5, 2022 at 8:20 PM
    #339
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    This is the same image in what a quoted here.
    May 14
    pY51tY8qh474DlFFaHiZ0uJO3xWmhoWquMUw5Rta_1962d2adf40eae192f5df927db5b1796e164abb8.jpg
    I didn't ID the established grass correctly. Just because someone cuts grass for a living doesn't mean he knows the diff types of grass. I got some Pendington Centipede Mulch stuff and put it in my bare spots.
    This was on May 26
    7Xm0x5wcoqKs8txeBCy1H9GMn35IIAZ27Dd47Crm_8e335cf96aeb1cfd3c68250033f8c4f8c4fd5bbf.jpg
    This is today.
    wbjkDLn8QRaiVeMep1AY1vMRTF-YWNaIigIIBwV5_36c0c09e0adbb6fdc75ca3de65778cd7bf82a116.jpg
    I'm going to encourage the centipede to take over the grass. The other side of the yard looks the same, just didn't get a shot of it.
  10. Jul 6, 2022 at 6:21 AM
    #340
    Badknees
    Badknees New Member
    South Carolina
    Nice work! I was under the impression that centipede had to be plugged...guess I was wrong.
  11. Jul 6, 2022 at 6:48 AM
    #341
    Taco-Spike
    Two Trucks
    Wow, looks awesome!
  12. Jul 6, 2022 at 7:02 AM
    #342
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    Isn't that St. Augustine?
    This is the stuff I used
    https://www.pennington.com/all-products/grass-seed/pennington-centipede
    Here's the other side of the yard.
    EkNiP8_Kks8ujdRMxCJ7bu-ST2Lad94dqfaaUtqL_0c81db08e5af97b66a160cac8efc9fe5011e18d8.jpg
    I got about a full acre out back, I sure ain't going to be spreading that stuff out there. I'll keep spraying some weed and feed out there and see what comes up.
  13. Jul 6, 2022 at 7:30 AM
    #343
    Badknees
    Badknees New Member
    South Carolina
    I think centipede can be grown from seeds or plugged. I had a friend who used plugs once and that's why I thought it was the best way.
    Your yard looks great!
    Best - your Anderson neighbor.
  14. Jul 6, 2022 at 7:35 AM
    #344
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Tall fescue, this lawn is 11 years old and needs to be reseeded soon.
  15. Jul 6, 2022 at 7:37 AM
    #345
    Badknees
    Badknees New Member
    South Carolina
    Wish my grass and concrete was as purdy as yours!
  16. Jul 6, 2022 at 8:19 AM
    #346
    georgiey22
    Thank you. Fortunately I bought this place 12 years ago and only owner, done my best to pressure wash the concrete 3-4 times per year and keep the lawn up. Doing my best but I don’t know much about this stuff.
  17. Sep 24, 2022 at 6:23 PM
    #347
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Time to bring this thread back before winter here.
    Had to do something special ‘for the gram’ lol.
  18. Oct 31, 2022 at 11:58 AM
    #348
    georgiey22
    Fall 2022 updates…summer was hot so lawn is bouncing back.
    Prostar 190, WILLINH, B.Ross and 3 others like this.
  19. Oct 31, 2022 at 11:59 AM
    #349
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    :fistbump:
    :jellydance::jellydance:
  20. May 30, 2023 at 12:40 PM
    #350
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Not near as nice as most of y'alls...but a little front and back yard action. i've left out the bad spots since there's plenty of them:oops:
  21. May 30, 2023 at 12:50 PM
    #351
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Love this thread, I'll have to dig up some pics.
    Here in NC everyone has Tall Fescue, so that's been a learning curve for me. My neighbor's yard is dialed and he told me when we moved in that it would take a couple years to get ours right after the last owners neglected the yard. He even came over and cut the grass while the house was listed for sale. A few years ago the crabgrass completely took over and I had to kill the whole yard and start over from dirt. Fast forward five years and I finally have a lawn that looks halfway decent!
    Fotnot likes this.
  22. May 30, 2023 at 12:57 PM
    #352
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I love the look of tall fescue...especially once striped!
    We built on this property that used to be all rice fields. The St. Augustine grows decent, but everywhere i've brought in dirt is a mess with weeds. The yard is too large for my budget to kill off and restart (2.5 acre lot with about 1-1.5 acres of stuff to try to repair). which is also why i'm on "God's watering schedule" as I'm not putting in irrigation for that much land lol.
    i do love seeing others' yards on here!
    WILLINH likes this.
  23. May 30, 2023 at 1:06 PM
    #353
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    I'd get a bunch of wild flower seeds and dedicate some of that land to a pollinator haven. Very little maintenance.
  24. May 30, 2023 at 1:34 PM
    #354
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Ugg...in places I have extremely high winter grass die off (60-85%). The snow in the yard for so long didn't help any.
  25. May 30, 2023 at 1:56 PM
    #355
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Tall fescue is starting to come back around
  26. May 30, 2023 at 4:24 PM
    #356
    Charvonia Design
    Keith
    Huntersville, NC
    What state are you in?
  27. May 30, 2023 at 4:43 PM
    #357
    eddiefromcali
    Eddie
    100% Stock
    California
  28. May 31, 2023 at 11:08 AM
    #358
    Badknees
    Badknees New Member
    South Carolina
    ZPhilip, Prostar 190, B.Ross and 2 others like this.
  29. May 31, 2023 at 11:16 AM
    #359
    Badknees
    Badknees New Member
    South Carolina
    Very nice! You're logging a lot of time on the mower, but if you're like me I enjoy it...but not the weed-eater.
    PermaFrostTRD and Fotnot[QUOTED] like this.
  30. May 31, 2023 at 11:21 AM
    #360
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    looks like it's out of a magazine! :thumbsup:
    Badknees[QUOTED] likes this.
