LED Puddle lights for Platinum & 1794 * DIY
Discussion in 'Lighting' started by BlueBottle, Sep 30, 2016.
  1. Mar 1, 2018 at 10:18 AM
    #121
    MMichaelJJ
    MMichaelJJ New Member
    14 Platinum CM
    The VLEDs are well built; it’s a metal housing.
    The lights are attached using 3M double sided tape. For the picture i just put the lights in the opening. I didn’t peel off any of the backing for the tape and it stayed in place, even for the couple hundred yard drive from where I took the picture and my house.
    There is a very small amount of friction of the light fitting into the housing. That could be a good thing to help keep it in place with the tape. The added weight of the metal housing might offset that benefit though.
    I’ll proably install them today with the tape.
    Let me know if you have any questions or want me to take any more photos.
  2. Mar 1, 2018 at 10:19 AM
    #122
    MMichaelJJ
    14 Platinum CM
  3. Mar 1, 2018 at 12:24 PM
    #123
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    Still sketchy on having them attach upside down with just tape. It’s a lot of investment just hanging in there lol. Do you feel comfortable that it won’t pop out even when off roading?
  4. Mar 2, 2018 at 5:09 PM
    #124
    MMichaelJJ
    14 Platinum CM
    I took some measurements and weights for comparisons.
    Old LED lights = 18grams
    VLEDs = 27grams
    The widest part on the bottom of the VLED light is 6.68mm. The thinest part is 2.38.
    I did my best to measure the lip on the bottom of the mirror where the tape would stick to. The widest part is 4.60mm. The sides are about 2.18mm and the thinest part is 1.60mm. Not a lot of area for the light to stick to.
    I still plan on using them; they are already paid for. By the time I ship them back and pay the restocking fee, I would only get $40ish back.
    We’ll see what happens.
  5. Mar 2, 2018 at 5:14 PM
    #125
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    I ordered a pair of the generic fit VLEDS for my SR5. Is there enough of the back side of the light sticking though that a small bead of JB quickweld could be used on the back to help hold them in?
  6. Mar 2, 2018 at 5:18 PM
    #126
    MMichaelJJ
    14 Platinum CM
    If you’re asking about the ones I have, maybe.
    The universal ones look like they have a wider lip with more 3M tape. They will proably stick better. Downside is they won’t be flush like the OE ones unless your router out a lip.
    If I ever get tow mirrors I’ll buy the universal ones and mount them to the bottom.
  7. Mar 2, 2018 at 6:32 PM
    #127
    PMR
    PMR New Member
    Patrick
    South East Tennessee
    2017 White 1794
    Icon Stage 6 Lift w/ Billet UCAs Icon RXT Leaf Pack Icon Six-Speeds w/ BFGATKO2 285-70-17 TRD Exhaust TRD Sway Bar TRD Skid Plate TRD CAI TDR Shift Knob Weathertech Floor Mats & Window Visors 2018 Tundra LED Headlights Interior and Exterior LED Upgrade
    Drive Brights. Don't think of another puddle light.
  8. Mar 2, 2018 at 6:35 PM
    #128
    PMR
    PMR New Member
    Patrick
    2017 White 1794
  9. Mar 2, 2018 at 7:26 PM
    #129
    MMichaelJJ
    14 Platinum CM
    That’s what I’m comparing the VLEDs to.
  10. Mar 5, 2018 at 9:45 AM
    #130
    MRTUND460
    MRTUND460 New Member
    2010 CrewMax Platinum
    TRD Supercharged, Doug Thorley headers, MBRP cat back exhaust, DAP Tuned, 4.5" BDS lift, Firestone airbags, TRD sway bars, TRD big brakes, Icon CNC upper control arms Fox DSC shocks all 4 corners, Deaver custom rear leaf springs, 2018 Sequoia headlights.
    Not sure why everyone is so concerned about the tape. If properly prepped and applied you'll need a screwdriver to get them back out. MMichaelJJ, have you installed them yet?
    NewImprovedRon likes this.
  11. Mar 6, 2018 at 6:18 PM
    #131
    thomasbus337
    2020 TRD Sport DC
    I installed the generic VLED's this weekend in my SR5. The lights do not protrude very far into the inside of the mirror housing so I didn't apply any JB Weld to the inside. Instead I used some 3M adhesion promoter before attaching them. I'm loving the light output and they fit perfectly
  12. Mar 7, 2018 at 6:47 AM
    #132
    MMichaelJJ
    14 Platinum CM
    Installed them yesterday. Cleaned the surface and applied some heat since it was a little cold out. I think they’ll be fine.
  13. Mar 7, 2018 at 11:45 AM
    #133
    MRTUND460
    @thomasbus337 Looks awesome! Was it hard to run the wires?
    @MMichaelJJ Nice! Good idea adding some heat when it's cold out.
  14. Mar 7, 2018 at 11:59 AM
    #134
    thomasbus337
    2020 TRD Sport DC
    I used a long zip tie to help snake the wiring through the mirror housing, very easy. Then I inserted a large drinking straw through the rubber boot on the door harness and fed the wiring through the straw into the cab of the truck. I already had the OEM LED bed lighting kit installed so I just hooked these new lights into that wiring. With it wired up this way I can turn them on with the cargo light switch with the doors closed, or override them with the same switch
    Skippy, NewImprovedRon and MRTUND460 like this.
  15. Apr 14, 2018 at 7:10 PM
    #135
    eddiesteele
    eddiesteele New Member
    eddie
    Long Beach
    '18 SR5 CM
    I purchased the same set and got them mounted and they look great! I tried tapping into the harness under the driver side(I think same as you, where the oem bed light set would be tapped into, but I don't have the bed light set) but I got nothing. What wires did you tap into?
  16. Apr 15, 2018 at 8:28 AM
    #136
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    I also mounted mine in the cover plate. have been on for years now.
    i installed muth signal mirrors while i was doing the puddle lights, all the same parts and wire paths gettnig worked with.
  17. Apr 15, 2018 at 8:41 AM
    #137
    thomasbus337
    2020 TRD Sport DC
    I tapped into the power and ground wires on the harness that came with the oem style LED bed lights. I didn't want to hack further into the wiring under the dash.
  18. Apr 15, 2018 at 10:10 AM
    #138
    eddiesteele
    eddie
    Long Beach
    '18 SR5 CM
    Thanks for the reply! I figured it out this morning. I grounded straight to the ground screw and then ran the power to the driver side door well. I read in another thread that for the 2018 CM the cargo light wire is pink. There's probably 5 pink to pinkish wires in there. There's one that is the thinnest it isn't that one then 2 more the next gauge up, they are very similar in color it is one of those, if i remeber correctly it is the slightly darker wire.
    panicman likes this.
  19. May 4, 2018 at 6:12 PM
    #139
    tundragrl
    tundragrl New Member
    Thats odd..nope just love the products!!!!!!:spending:
  20. May 12, 2018 at 8:39 PM
    #140
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I put in the $20 eBay puddle lights tonight. Not a great fit, I used some hot glue to secure them tightly. They seem brighter than OEM. Thanks @BlueBottle For the idea and write up!
    BlueBottle[OP] likes this.
  21. May 12, 2018 at 9:56 PM
    #141
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Nice. Looks plenty bright planes might land by your truck!
    Mines still running strong.
    Pudge[QUOTED] likes this.
  22. May 12, 2018 at 11:44 PM
    #142
    kcaustin66
    kcaustin66 New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    On the puddle lights I have a 2015 Tundra 1794 can I just changed out the bulb to led bulb.
  23. May 13, 2018 at 9:08 AM
    #143
    Pudge
    CT
    You need to change the whole light pod, not just the bulb.
  24. May 24, 2018 at 3:39 PM
    #144
    dynastyevil84
    dynastyevil84 New Member
    2015 red tundra 1794
    Thank you BlueBottle for the site. I installed couple days ago and they look beautiful.
    Bob and BlueBottle[OP] like this.
  25. May 24, 2018 at 6:25 PM
    #145
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Welcome. Great first lost!
  26. Jul 7, 2018 at 12:20 PM
    #146
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    this will be happening fo sho
  27. Aug 26, 2018 at 8:18 AM
    #147
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Totally gonna add these to my SR5. Found some cheapos on eBay here.
  28. Aug 26, 2018 at 8:44 AM
    #148
    thomasbus337
    2020 TRD Sport DC
  29. Aug 26, 2018 at 9:53 AM
    #149
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    More than I wanna spend on them but yeah they look hella good on quality. Either way I’ll have to route wiring and drill a hole.
  30. Aug 26, 2018 at 11:33 AM
    #150
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Exactly why if your going to all that trouble you might as well get quality lights.
    Krezz, Tundra Fan and Pudge like this.
