LED Puddle lights for Platinum & 1794 * DIY
Discussion in 'Lighting' started by BlueBottle, Sep 30, 2016.
  1. Mar 31, 2017 at 1:46 PM
    #61
    FLTrucks
    FLTrucks New Member
    Going to look into this now... it should work some how they are just a 12v source
  2. Mar 31, 2017 at 4:07 PM
    #62
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    A lot brighter???? Yet they use my pictures of a different product on their website??? Fake!!!! I would stay away from this website and product if they like to use other people's pictures with other people's products!!!
    Stay away from this website everyone!!!
    knoxhustle, Lilly and Pudge like this.
  3. Mar 31, 2017 at 6:16 PM
    #63
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    Here's my upgraded LED entry lighting :D
    Prostar 190, Lilly and BlueBottle[OP] like this.
  4. Apr 2, 2017 at 7:32 AM
    #64
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    They turn on when you push the factory remote unlock button. You can set how long they will stay lit using Techstream, and they came stock in the 2nd gen Platinum.
    FLTrucks[QUOTED] likes this.
  5. Apr 2, 2017 at 10:11 AM
    #65
    FLTrucks
    FLTrucks New Member
    Thanks that helps out a lot more.
  6. Jul 24, 2017 at 5:56 AM
    #66
    Hasteen
    Hasteen To be continued...
    Justin
    Providence, RI
    2004 DC SR5 Texas edition 2016 CM 1794 edition
    1ST GEN Toytec 3/1 lift kenda 33s on 17x9 RockTrix RT107 BruteForceFab front bumper ----------------------------------- 3RD GEN rough country 6" Toyo 35's on 22x10 Fuel Assault TRDPro Grille
    that diamond stitching :drool::drool::drool::drool::drool::drool:
    AxelsHumanDad[QUOTED] likes this.
  7. Oct 21, 2017 at 11:04 AM
    #67
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    I’m considering retrofitting a pair of the Bright trax V4 puddle lights on to a SR5. Is there any reason why the Ford kit wouldn’t work for this retro?
    I’m looking at their website with a side by side pic of the Ford and Toyota lights and the lens on the Ford looks like a perfect circle while the Toyota looks more egg shaped.
    I’m planning on drilling a circle big enough for the lamp to fit into the bottom of the housing, then Dremel off the mounting tabs and securing it from inside the mirror housing with JB Weld.
    The only other issue I can see is the light not fitting perfectly flush with the housing because it will be surface mounted and not sunken in a bit like factory.
    speckmon likes this.
  8. Oct 23, 2017 at 8:06 AM
    #68
    famouzstarz
    famouzstarz Da illest!
    ABQ,NM
    Platinum Tundy!
    20" Fuel Wheels, 7" BDS Suspension, Tint, etc..
    #68
    plumber802, Pudge, nk1794 and 4 others like this.
  9. Oct 23, 2017 at 3:53 PM
    #69
    BlueBottle
    '16 Platinum 4x4
    See fine print
    #69
  10. Oct 23, 2017 at 4:56 PM
    #70
    famouzstarz
    ABQ,NM
    Platinum Tundy!
    Fit perfectly no issues popped the old ones out used the connection that came on the new ones plug and play!
    Pretty bright imo, wouldn't hesitate to do it again.
  11. Oct 23, 2017 at 6:32 PM
    #71
    ldale
    ldale New Member
    Txk Tx
    17' Limited Silver Sky Metalic
    Tonno Pro LowPro , TRD Sway Bar, Helwig Leaf Pack
    Can any of our Electrical Wizards confirm or deny whether the Limited has the wires already in the mirror connection? I can see the round area where surgery could be performed in the bottom of the mirror.
  12. Oct 26, 2017 at 5:35 AM
    #72
    Hasteen
    Justin
    Providence, RI
    this wouldve been nice to know before i dropped 75 on the ones i have now.:(
    bookmarked for the next tundra lol
    #72
    NewImprovedRon likes this.
  13. Oct 26, 2017 at 7:30 AM
    #73
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Still need to get mine wired up so i can have puddle lights on my RW. Definitely going to upgrade when i do. Im liking the $20 price of the ebay ones.
    #73
    Pudge likes this.
  14. Oct 26, 2017 at 1:22 PM
    #74
    k3vinryl3
    k3vinryl3 New Member
    Is this same size on 2018 tundra platinum?
  15. Oct 26, 2017 at 9:04 PM
    #75
    Tundra Fan
    Toby
    I would think so, but maybe @Roman can verify part numbers.
  16. Oct 27, 2017 at 10:27 AM
    #76
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  17. Oct 27, 2017 at 4:45 PM
    #77
    happyb
    happyb New Member
    What size bulb is used for the puddle lights? Thanks
  18. Oct 27, 2017 at 5:22 PM
    #78
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Roman likes this.
  19. Oct 27, 2017 at 5:54 PM
    #79
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Maybe I'll get some of the eBay one and add them to tow mirrors
    #79
  20. Oct 30, 2017 at 1:50 PM
    #80
    Roman
    Roman
    Franklin, TN
    Not sure. They're not serviceable without cutting them open.
  21. Nov 22, 2017 at 3:21 PM
    #81
    Dthunting
    Dthunting New Member
    2013 Platinum Edition
    None as of yet.
    Does someone have a DIY video on how to pop off the puddle lamps? I have new LED bulbs but I'm hesitant to start popping off the mirror etc. Or does the light assembly pop off like the Ford's do?
    AxelsHumanDad likes this.
  22. Nov 22, 2017 at 3:56 PM
    #82
    AxelsHumanDad
    2015 CM Platinum
    Tilt the mirror up, you'll see the tabs holding the puddle lights in. Poke at the tab with a plastic tool and the light drops right out.
  23. Nov 22, 2017 at 4:49 PM
    #83
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Bro read the first post. I have a picture and description of it.
    AxelsHumanDad and NewImprovedRon like this.
  24. Nov 22, 2017 at 8:45 PM
    #84
    boloson
    boloson New Member
    Lol! I was looking for your how to to help him & realized we're on it lol
  25. Nov 23, 2017 at 12:29 PM
    #85
    Dthunting
    None as of yet.
    Yeh, I suck. After I sent the post I saw the whole damn thing. Sorry about that. Sure glad I don't have to pop the mirrors off. Thanks!
    AxelsHumanDad and BlueBottle[OP] like this.
  26. Nov 23, 2017 at 1:25 PM
    #86
    BlueBottle
    '16 Platinum 4x4
    See fine print
    All good. Just pushing your buttons. You will find a lot of information on this site by just searching believe it or not. Happy w the lights? Another trick is to program it through techstream to stay on longer. I have mine set at 30 seconds. Factory is 7.5.
  27. Nov 30, 2017 at 8:28 AM
    #87
    Dthunting
    None as of yet.
    Guys - Any suggestions where to buy new puddle lamps assemblies? I'm going to go with LEDs versus the OE product. I live in Wisconsin and was popping these off and the little plastic tab that holds them in place broke off. I now need to replace the complete puddle lamp assembly (both sides) versus the light bulb inside the plastic assembly. I live in Wisconsin and was doing this with the temps were in the 20s. Plastic is brittle when temps are in the 20s.
  28. Nov 30, 2017 at 8:40 AM
    #88
    Tundra Fan
    Toby
    Personally, I would (and did) purchase the ones in the first post. They are the whole assembly and are LED. I don't believe you can replace just the bulb on any of the brands for these lights without cutting into the lens.
    Puddle and cargo lights.....
  29. Nov 30, 2017 at 9:41 AM
    #89
    MGMTundra251
    MGMTundra251 New Member
    2020 Platinum 4x4 MGM
    I ordered the same one from same seller and it didn't fit. Housing was slightly too small and would not clip onto my mirrors. The lense wasn't glued/secured properly onto the housing. I emailed seller and he gave me a full refund. Junk if you ask me.
  30. Nov 30, 2017 at 5:34 PM
    #90
    MGMTundra251
    Don’t waste your time buying cheap ones from China on EBay. Takes about 2 weeks to ship and in my case, it didn’t fit.
    #90
