LED Lightbulbs opinions/advice
Discussion in 'Lighting' started by tundra403, Mar 4, 2019.
  1. May 15, 2021 at 5:23 PM
    #211
    Notarobot
    Notarobot Jagged lines!
    2013 CM
    Are the fan bulbs better or are the modern fan less acceptable? I don't want to melt any wires.
  2. May 21, 2021 at 3:38 AM
    #212
    Rockin 2nd Gen
    Rockin 2nd Gen New Member
    Jay
    Ohio
    2010 Tundra
    5" lift 20x12 fuel with 35" nitto ridge graplers. Full led and secaine 9" android head unit.
    I have the GTR Ultra which are the most expensive at the time. The brighter the bulb the warmer they will get. I have no issues with these. I also run the cougar motor sports H-11 in my driving lights they have a small fan compared to the GTR but i have had no problem with them either. The Cougars i got on Amazon for 40 bucks. The GTR's are around 200$ for a pair.
    I can say they are about the brightest led bulb you can get. In my stock housings they light up everything. I Run the Alpha Rex projector housing now and that focuses the beam more than a reflector so i would have to say not as bright as they were but more hot spot in a projector.
  3. May 26, 2021 at 6:38 PM
    #213
    SilverImage
    SilverImage New Member
    Grey 2017 SR5 TRD
    Ionic Pro 5" nerfs
    Some are saying reflector ON the bottom and some are saying reflector FACING down. Guess I'll have to experiment. The stock halogens suck, and so do the HEADLIGHT EXPERTS leds I paid $100 for. We'll see how the Auxbeams work. I have had excellent luck with Cougar motors in our other 4 'yotas, but they are separate bulbs for hi/lo.
  4. May 26, 2021 at 6:40 PM
    #214
    SilverImage
    Grey 2017 SR5 TRD
    Ionic Pro 5" nerfs
    Some are saying reflector CUP ON the bottom and some are saying reflector CUP FACING down. Guess I'll have to experiment. The stock halogens suck, and so do the HEADLIGHT EXPERTS leds I paid $100 for. We'll see how the Auxbeams work. I have had excellent luck with Cougar motors in our other 4 'yotas, but they are separate bulbs for hi/lo.
  5. May 26, 2021 at 6:44 PM
    #215
    SilverImage
    Grey 2017 SR5 TRD
    Ionic Pro 5" nerfs
    I installed these, and they worked well. No errors and brighter. https://www.amazon.com/gp/product/B06XTG9ZB8/ref=ppx_yo_dt_b_asin_title_o09_s01?ie=UTF8
  6. Jul 19, 2021 at 1:54 PM
    #216
    xdmelarton
    xdmelarton New Member
    Richard
    2017 Tundra TRD Pro CM
    I am glad I found this thread and thanks to @TundraTSS19 for the Auxbeam recommendation and all the info from the guys who installed. I too put the cups facing down and had to flip them to the cup on the bottom but what a difference from the halogen bulbs. Also installed the Diode Dynamics SS3 Sport Fog lights I got from @memario1214 store hotshot offroad during the 4th of july sale and they cannot be beat for the price! I haven't been flashed by one passing vehicle yet and the wide angle coverage to spot deer in the ditches on the interstate and highways in the mornings makes it totally worth it. If anyone is looking for some bad ass fogs, here is the thread.....
    https://www.tundras.com/threads/dio...talled-update-4-17-21-now-with-ss3-max.58478/
    TundraTSS19 and memario1214 like this.
  7. Jul 20, 2021 at 6:57 AM
    #217
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    Hard to believe this thread is still going 2yrs later. Glad it helped you out.
    xdmelarton likes this.
  8. Dec 17, 2021 at 9:29 PM
    #218
    TundraBrew
    TundraBrew New Member
    Regarding the halogen headlight recall, does it not apply to those of us that switched to these LED bulbs? Can we tell the dealership to not disassemble the grill because the lights are aftermarket? Or, are they obligated to physically inspect it due to liability?
  9. Jan 1, 2022 at 6:17 PM
    #219
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    The key to LED bulbs is to buy quality. This is very much a case of you get what you pay for. The expensive bulbs (GTR Lighting Ultra 2, Supernova V.4, etc.) will give amazing results. It'll surprise you how intense they are and how good the beam patterns are. On the other hand, if you buy junk from eBay or Amazon you're going to scatter light all over the place, get flashed by oncoming traffic, and they'll burn out in a year or two from improper heat sink design.
  10. Jan 7, 2022 at 9:18 PM
    #220
    Mdouglas15
    Mdouglas15 New Member
    Michael
    2021 cement tundra sr5 4x2
    Rough country 3” leveling kit in front 17x8.5 method 305 (0 offset front and rear) 285/75/17 falken wildpeak at3 Some rubbing so took off mudflats and cut some plastic, now, no rub full lock forward and reverse Led headlights and fog lamps Led lights in interior as well
    So I threw in the auxbeam($36) LEDs tonight and I gotta say, they are wayyyyy better than the headlight expert lights I purchased!! And they have theeeee shittiest customer service ever, and the lights are not that good for being $100.
    The beam pattern on the left is auxbeam And the pattern on the right in the first pic is headlight experts, for
    $36 I was pretty impressed..
    We will see how long they last and they are not as bright as the headlight experts, but the pattern is what I mostly cared about
    In the 2nd pic is the beam
    Pattern of the new auxbeam, pretty close to stock.
    all of this is on a 21 tundra sr5, no projectors, just standard headlights
    Mater likes this.
  11. Jan 29, 2022 at 4:22 AM
    #221
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    Any longterm updates on the aux beams? Just ordered SS3 pro fogs and may get Auxbeam bulbs as well to get the same color temp while I figure out which replacement headlight I want.
  12. Feb 11, 2022 at 6:41 PM
    #222
    Tundra2Yak
    2016 1794 4x4 CM
    Update: installed the auxbeam bulbs today. Light output isnt great but not bad either. Hardest part of the install was pulling off the grill and trim pieces. Color matches the SS3 pros quite well.
  13. Feb 12, 2022 at 1:39 PM
    #223
    WXman
    WXman New Member
    Kentucky
    Yes, for the life of me I can't figure out how to release the tabs on the lower inside of the grille without breaking them. What a PITA those are. 2 of the 4 on my current grille are already broken off.
  14. Apr 13, 2022 at 6:36 PM
    #224
    biebs96
    PA
    Have any of you guys running these Auxbeams noticed they are brighter with the truck off vs running.
    i notice if I leave my lights on and shut the truck off they get a tad brighter. I’m just attributing that to the battery and alternator having to power everything else.
    thanks in advance
  15. Jan 27, 2024 at 11:35 PM
    #225
    chuy948
    chuy948 New Member
    jesus
    2016 Black Tundra SR5 TRD off Road
    Anyone have the auxbeam link on Amazon a current link? I have a 2016. On this version the high beam and low beam is one bulb or 2 bulbs.
