LED Lightbulbs opinions/advice
Discussion in 'Lighting' started by tundra403, Mar 4, 2019.
  1. Mar 4, 2019 at 6:51 AM
    tundra403
    tundra403 [OP] New Member
    KG
    2018 Tundra SR5 4x4 TSS Off Road - MGM
    -Internal LED Lights -Added VLED's Footwell light strip
    Yes... I eventually want to swap out the Halogen Units for the '19 black LED housing units.. but until the funds are right.. I am seeking the best bulbs to swap with..
    Has anyone gone with either of these for fogs/heads? they seem nice, and have decent reviews. I did just get their smaller LED bulbs to replace the interior lights in my wife's jeep.
    Only annoyance i have is you have to remove the whole damn unit to change a bulb.. so why not just change the unit then....
    anyways.. heres the bulbs.
    9003 Headlights. - https://www.amazon.com/dp/B07L8R6NK...njZn-VOmUsG8R8HBWtU5DEPIXNjFySAzyIejaHVE&th=1
    9006 Fogs - https://www.amazon.com/dp/B07L8R6NK...njZn-VOmUsG8R8HBWtU5DEPIXNjFySAzyIejaHVE&th=1
  2. Mar 4, 2019 at 6:58 AM
    War Machine
    War Machine SSEM # 5 3MW
    I’ve not used this brand, but have had great luck with Hikari. They are more expensive though.
    HIKARI Ultra LED Headlight Bulbs Conversion Kit -H11 (H8,H9), Prime LED 12000lm 6K Cool White,2 Yr Warranty https://www.amazon.com/dp/B077BT6M6Z/ref=cm_sw_r_cp_tai_nYtFCbG3VGHZ1
    I used a cheaper one in the fogs that wasn’t as bright. Using hikari on both was too blinding.
    Keep in mind that putting LED lamps in your stock housing is going to cause an issue for other drivers. The reflector will scatter light everywhere, and hits oncoming traffic pretty hard.
    rt_tundra_co and 040Tundra like this.
  3. Mar 4, 2019 at 7:01 AM
    Vleds
    phogallen, 040Tundra and B737 like this.
  4. Mar 4, 2019 at 7:04 AM
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    Auxbeam NF-S1 for headlights and fog lights. Very good light output and retains stock beam pattern. The bulbs are built exactly like the stock halogen bulb with the reflector cup for the low beam.
    Headlights - Auxbeam LED Headlight Bulbs NF-S1 Series LED Headlights with 2 Pcs of H4 9003 HB2 P43T CSP LED Headlight Conversion Kit 50W 8000lm 6000K Hi-Lo Beam - 1 Year Warranty https://www.amazon.com/dp/B074GZ3S4P/ref=cm_sw_r_cp_apa_i_V1tFCbQ875KEE
    Fog lights - Auxbeam H11 LED Headlight Bulb NF-S1 Series LED Headlights with 2 Pcs of High Brightness CSP Chips H11 LED Bulbs H8 H9 Conversion Kit 50W 8000lm 6000K Single Beam - 1 Year Warranty… https://www.amazon.com/dp/B074GX852M/ref=cm_sw_r_cp_apa_i_C4tFCbZAFRY8N
  5. Mar 4, 2019 at 7:12 AM
    tundra403
    KG
    yea i do like them.. they just pricey.. I did go with the VLEDS LED strip for the Footwell lights in my 18 Tundra $40 for the kit.. Looks awesome too. Plan to get the rear seats soon. Really lights up the car when you add on the LEDs for the courtesy lights
  6. Mar 4, 2019 at 7:13 AM
    tundra403
    KG
    Awesome, I will look into these. Anyone found an easy way to change the Headlights or is the only way to remove the housing?
  7. Mar 4, 2019 at 7:17 AM
    TundraTSS19
    San Antonio, TX
    There is only one way to do it but very easy. There are YouTube videos that show you how to do it. I can have them both out in 15 min
    tundra403[OP] likes this.
  8. Mar 4, 2019 at 7:18 AM
    bfd300
    bfd300 New Member
    I literally just got done installing the Auxbeams. Tonight will tell.
    SWIPE and tundra403[OP] like this.
  9. Mar 4, 2019 at 7:21 AM
    tundra403
    KG
    yea let me know!
  10. Mar 4, 2019 at 7:24 AM
    War Machine
    It is easy, but a ridiculous design. Having to remove all of that to change a lamp is a joke. Imagine having a lamp go out on a trip, and having to all of that to fix it. You should be able to change one out in a Walmart parking lot with no tools.
    Most of us can do it, only because we have. Imagine someone who hadn’t before, or one of our wives out of town having to deal with it.
  11. Mar 4, 2019 at 7:29 AM
    tundra403
    KG
    does the big ole rubber gasket still get used, or is the fan module of the LED light in the way and the gasket need to be removed completely.
  12. Mar 4, 2019 at 7:33 AM
    TundraTSS19
    San Antonio, TX
    The Auxbeam doesn't have a fan but only a heatsink. You will still utilize it. The bulb separates from the black plastic mounting base on the bulb by simply rotating the bulb and pulling it off. Mount black mounting tab to the housing and then place boot back over top and secure it. Next all you have to do is place the bulb into the housing with the metal reflect tab facing downwards and you're done.
  13. Mar 4, 2019 at 7:37 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Another vor for Vleds
    phogallen likes this.
  14. Mar 4, 2019 at 7:49 AM
    TundraTSS19
    San Antonio, TX
  15. Mar 4, 2019 at 7:50 AM
    tundra403
    KG
    dude.. nice.. whats the scoop. Always on? or just when needed?
  16. Mar 4, 2019 at 7:55 AM
    tundra403
    KG
    I'll have to post a pic of my foot well tonight, best $40 spent. I will spend anohter $40 soon and do the back. super simple and looks awesome
  17. Mar 4, 2019 at 8:08 AM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Auxbeams, just made the swap and love it. Not real scatter and good cut off. No way to do it without removing the housings, grill etc. Even with taking it all apart it only took me about 30 minutes.
    SWIPE, TundraPro2019 and TundraTSS19 like this.
  18. Mar 4, 2019 at 8:09 AM
    TundraTSS19
    San Antonio, TX
    Wired to the little park brake light bulb circuit. Lights come on when I press unlock on keyfob or when ant door opens up just like the dome lights. They face out with done lights or turn off when I press lock button on keyfob or if vehicle is running and I open and close the doors.
  19. Mar 4, 2019 at 8:17 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    West Texas Tundra likes this.
  20. Mar 4, 2019 at 8:56 AM
    tundra403
    KG
    you got the kit/kits you used? or a write up? this is pretty dope.
  21. Mar 4, 2019 at 10:08 AM
    TundraTSS19
    San Antonio, TX
    Sorry I don't have a write up but it was pretty easy. I'll have to take some pictures of what I did. Just clean the surface before mounting with leds. They have good 3M tape on them. For the pass side I got a spool of 18 Guage wire to run the wires from the pass side leds through the back of the inside of the cave and tucked it away to run online with the driver side. All wiring is splices together and runs off the little parking brake bulb socket wiring. I didn't install the little bulb back. Don't need it.
    tundra403[QUOTED][OP] likes this.
  22. Mar 4, 2019 at 10:11 AM
    tundra403
    KG
    ah.. are you talking about the footwell bulb? the 74 bulb size? I took the bulb out, but replaced it with the VLED footwell strips for driver/passenger. That light does not come on for me when unlocking. Only the opening/closing of doors. I'll double check, but i am pretty sure the unlocking didnt turn on my lights. until i opened doors.
  23. Mar 4, 2019 at 11:35 AM
    tundra403
    KG
    @TundraTSS19 nvm.. i just got back from lunch and tested it while at the truck.. you was right.. the footwell lights do come on when the car is unlocked. Thats cool though. Now i know what to tap into. certainly I wont over load it.. Just hit me up when you get a chance on the lights you used, or something similar. Thanks!
    btw, this is what i used inside for the footwell bulb.. looks great. https://www.vleds.com/vehicle-speci...undra-interior/footwell/tundra-fwk-front.html
  24. Mar 4, 2019 at 12:11 PM
    Tierhog
    Tierhog SIG-AHOLIC
    That makes me feel better. Did the Amazon thing.. Hoping I have everything before I tear everything apart.. Lol
    Another competitor has a YouTube video .
    Is there a specific orientation to the bulbs before I button everything up ?
  25. Mar 4, 2019 at 12:36 PM
    TundraTSS19
    San Antonio, TX
    Yes. Make sure that the metal reflector cup is facing on the bottom.
    Tierhog[QUOTED] likes this.
  26. Mar 4, 2019 at 12:39 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    PSA: GET DUST COVERS FOR THEM!!!
  27. Mar 4, 2019 at 12:41 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    i have a 2nd gen so its probably different, but how did you tap into a lead thats + when the door opens?
  28. Mar 4, 2019 at 1:18 PM
    TundraTSS19
    San Antonio, TX
    The little parking brake bulb socket has the power and ground you need. I just took the bulb out and tapped into that and ran all the wiring to it on the driver and passenger side. The leds don't use hardly any power. Works great.
    TRD-tv[QUOTED] likes this.
  29. Mar 4, 2019 at 1:19 PM
    TundraTSS19
    San Antonio, TX
    The factory dust cover is all you need. You don't have to modify it because the black mounting tab removes from the bulb so you can mount it and place the cover over top of it before inserting the bulb.
    TRD-tv[QUOTED] and tundra403[OP] like this.
  30. Mar 4, 2019 at 1:21 PM
    tundra403
    KG
    I am going to see if i can trace the wire and find out where it goes and tap into it somewhere else. I utilize the socket for the footwell strips. what kind of lights did you use on the outside? just some cheap strips or something durable?
