LED Lightbulbs opinions/advice
Discussion in 'Lighting' started by tundra403, Mar 4, 2019.
  1. Dec 15, 2020 at 6:20 PM
    #181
    gb_beringei
    gb_beringei New Member
    Central Maine
    2019 SR5 SX Double Cab
    I finally got the LED bulbs installed tonight and they are exactly what I was looking for. They're noticeably brighter, but in a functional way rather than just being obnoxiously bright. The bulbs have a bit of additional throw/range straight back on them which is useful. But I dont really need straight-back illumination. Where these things shine is on the lateral spill (like at 45 degree angles out from the rear of the truck). There is tons of useful light where there wasnt previously so there is a good bit more visibility backing up while turning in the dark or if you're backing up on a narrow trail with thick brush on either side of you.
  2. Dec 31, 2020 at 11:49 AM
    #182
    YodaPower36
    YodaPower36 New Member
    Ryan
    Kennett Square, PA
    2017 Tundra SR5 Double Cab
    Exterior: 3.5 rc lift Fuel Vandal 20x9 1 mm offset on 35’s, Trd dual exhaust, Spyder Industry Steps, rekgen mud flaps, Trd pro grille, Diode Dynamic SS3 fogs, YotaLED grille lights, ApexOffroad bumper shims. Interior: Heated seats, RC seat covers, Full head unit and stereo replacement. KENWOOD 1057xr, Kicker amp/sub combo,
    Hey are you still able to adjust the headlights with these from the switch inside the cab?
  3. Dec 31, 2020 at 11:54 AM
    #183
    YodaPower36
    Ryan
    Kennett Square, PA
    Does the headlight adjustment inside the cab work with these bulbs?
  4. Dec 31, 2020 at 4:45 PM
    #184
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    You can adjust the bulbs from inside the cab with no issue. New bulbs don't affect the mechanism that moves the bulbs up and down.
    YodaPower36[QUOTED] likes this.
  5. Jan 5, 2021 at 10:08 AM
    #185
    2020TundraVooDooBlue
    2020TundraVooDooBlue New Member
    Going to be ordering these today. I will let you guys know how it goes.
  6. Feb 8, 2021 at 6:25 PM
    #186
    PonyMan
    PonyMan Old Man
    Central, Louisiana
    2021 Tundra CrewMax 4WD Limited Nightshade Special Edition MGM
    So, can anyone confirm these work with no issues on the 2021 CM? About to pull the trigger.
  7. Feb 11, 2021 at 12:48 PM
    #187
    MillMatter
    MillMatter New Member
    Pensacola, FL
    2014 1794 Edition 4x4 CrewMax Super White
    6” pro comp lift, 35x12.50 Toyo R/T, 22” chrome Fuel Hostage, Magnaflow custom dual in dual out exhaust with OEM chrome tips w/ Toyota logo, tint, smooth finish color matched fender flares, color match grille surround and hood bulge, 14-17 TRD Pro grille custom painted all white (letters remain matte silver), classic Toyota tri-color logo in grille (blue color scheme), chrome step bars, Century Sillhouette tonneau, Pendaliner drop in bed liner, custom company graphics, chrome TRD decals custom painted to color match company graphics (blue), ESP under seat storage, center console organizer, BumperShellz color matched front bumper end caps. Tech12Volts/Taylor's Audio Sound System: Kenwood DMX1057XR head unit, Infinity Reference 5-ch amp, Hertz CK165L front, Hertz K170 rear, 2 JL Audio W0 10" subs in ported box behind seat, bass knob.
    I have those Auxito LED bulbs as well and have yet to install because I am getting a new grille and surround soon so I will just wait to do it all at once. Interested in the feedback from you guys.
  8. Feb 12, 2021 at 8:32 AM
    #188
    pearlpower
    pearlpower New Member
    2014 CrewMax in Radiant Red
    Has anyone upgraded the factory LED bulbs for something brighter? High beams are great, one of the brightest I have come across, the low beams LEDs are just good, not great, so just exploring options.
  9. Feb 15, 2021 at 4:21 PM
    #189
    TundraBrew
    TundraBrew New Member
    Hey guys, read through this thread a couple times and bought the Auxbeams. Installed the headlights today, no issues. Just waiting til it gets dark.
    Tried to install the fogs and I could not push them in far enough to get the 3 tabs to engage in their slots. If you look at side shot images of the two bulbs you can see that the distance from the tabs/flange to the gasket/base is much less on the Auxbeam compared to OEM.
    Did I get the wrong bulbs (S1-H11), or do I need to pull my skirt up, and push harder?
  10. Feb 15, 2021 at 4:57 PM
    #190
    TundraTSS19
    San Antonio, TX
    Make sure you have the tabs oriented correctly and push and turn. Those are the correct bulbs.
  11. Feb 15, 2021 at 5:10 PM
    #191
    TundraBrew
    Thanks for the quick reply. There are 3 tabs - I was trying to install the bulbs so that the LEDs would face out the sides, and one of the tabs would be at 12:00. Pretty sure this is the only way.
    Looking into the fog assembly from the front, I could see all 3 tabs insert into their respective slots, but I needed another 1 or 2mm to push them in far enough to lock into place.
    This is for a 2019 CM SR5, if it matters.
  12. Feb 16, 2021 at 6:38 PM
    #192
    TundraBrew
    For the money, I'm very happy with the output of the Auxbeam headlights. Brighter than stock halogens without being obnoxiously bright. As someone else mentioned, I adjusted the beam downward slightly. I also experienced slight interference with FM radio, but only for a few seconds and just that one time.
    TundraTSS19, I respect your knowledge on this topic but I decided to return the fogs. Today was the last day for a free return anyway. I'll try the Sealight or Marsauto next and see how it goes. Good news is that I can access the fog lights from under the bumper, without removing anything. Probably because I don't have a skidplate.
    Anyone have experience with either of these?
  13. Feb 16, 2021 at 6:55 PM
    #193
    PonyMan
    PonyMan Old Man
    Central, Louisiana
    What was the issue with the auxbeam fog light bulbs?
  14. Feb 17, 2021 at 6:46 AM
    #194
    TundraBrew
    See my previous post (#189). Couldn't get them to lock into place. Didn't want to force it.
  15. Feb 17, 2021 at 7:53 AM
    #195
    Rockin 2nd Gen
    Rockin 2nd Gen New Member
    Jay
    Ohio
    2010 Tundra
    5" lift 20x12 fuel with 35" nitto ridge graplers. Full led and secaine 9" android head unit.
    I just installed AlphaRex Pro in mine so i am in the middle of replacing the halogen h-7 My GTR Ultra 2's are on the way. But as far as the Stock reflector housing i ran the S-v.4 in the low beam h-11 and cougar motor sports for the high beam both were absolutely awesome in the reflector housing. The cougars were like 40 bucks on Amazon and had no driver plug and play with no issues. The sv4 are a bit pricey but worth the money.
  16. Mar 3, 2021 at 4:13 PM
    #196
    PonyMan
    PonyMan Old Man
    Central, Louisiana
    @TundraTSS19 Im trying to install these on my 2021 CM, but I can’t figure out how to get the rubber boot seal back on with the large rear part of these bulbs. Any suggestions?
  17. Mar 3, 2021 at 4:15 PM
    #197
    TundraTSS19
    San Antonio, TX
    You should be able to twist and separate the bulb from the mounting plate and then install boot first and then insert the bulb.
    PonyMan[QUOTED] likes this.
  18. Mar 3, 2021 at 4:16 PM
    #198
    PonyMan
    PonyMan Old Man
    Central, Louisiana
    Thanks I’ll give that a try!
  19. Mar 3, 2021 at 4:37 PM
    #199
    PonyMan
    PonyMan Old Man
    Central, Louisiana
    @TundraTSS19 Wait a sec, ok you’re talking about the plastic black ring right? So you use the existing wire clip to secure the black plate, install the boot, then insert the bulb? What holds the bulb in, friction from the small O ring around the bulb base? Doesn’t seem like much of the bulb protrudes inside the headlight housing?
  20. Mar 3, 2021 at 4:47 PM
    #200
    PonyMan
    PonyMan Old Man
    Central, Louisiana
    @TundraTSS19 i think I’ve got it figured out, it twists once in place and locks into the black ring mounting plate? Is there a certain orientation of the heat sync housing that dictates the bulb top and bottom orientation? Sorry for all the questions, just had everything taken apart and thought I screwed up somehow and put everything back together. Just want to get my head on straight before I hit it again tomorrow.
  21. Mar 5, 2021 at 7:08 PM
    #201
    TundraTSS19
    San Antonio, TX
    If I remember correctly the reflector cup should be facing downward.
  22. Apr 5, 2021 at 6:10 AM
    #202
    Guys, just got the AuxBeam headlight and fog lights installed. WOW. What a difference. I have to admit though, I did put them in upside down the first try because I was not paying attention! I fixed them yesterday and drove around last night when it got dark. Man, they are nice for sure! Very easy upgrade!
  23. Apr 21, 2021 at 7:11 AM
    #203
    TNTundra53
    TNTundra53 New Member
    I need info and pics on how you did the light bar in the lower valance.
  24. Apr 22, 2021 at 12:01 PM
    #204
    Rockin 2nd Gen
    Jay
    Ohio
    2010 Tundra
    Just got your message. I have not been on the forum for a bit i have been slammed with stuff. I did not take any photos of the install but there are some around. I tried a few ways to start with until i figured out just what needed removed. Dont bother with the valance you will need to remove the front bumper its not that difficult. The cover that is between the bumper and the hood you can leave on but have to remove all the clips that attach it to the bumper. What you are trying to get to is the aluminum crash bar support. I put the light bar on the crash bar where i wanted it, mine is a 42" curved i got on ebay for 70 bucks. The curved will fit better than a straight. I wanted the 42" because i want all the valance slots to emit the light not light some of the small 24" jobs. Sit the light bar on top of the crash bar. I even held my bumper back on to make sure my alignment was right, then mark your mounting hole and pre-drill first then drill the appropriate size hole for what ever bolt you will be using. Myself i used a self tapping screw then bolt your light on and put your bumper back on. It took longer to figure out that i only needed to remove the bumper. The light has worked flawless for nearly a year so far and yes it will make people flash you. But i can see sooooo well. Here is the crash bar.
    You only need to remove 52119A in the print. You mount the bar to top of aluminum crash bar 52131A
    upload_2021-4-22_14-51-36.jpg[​IMG][​IMG][​IMG]
  25. Apr 22, 2021 at 12:10 PM
    #205
    Rockin 2nd Gen
    Jay
    Ohio
    2010 Tundra
  26. Apr 22, 2021 at 12:46 PM
    #206
    COElkHunter
    COElkHunter New Member
    Jeremy
    2012 Silver Tundra TRD limited Crewmax 4x4
    3" OME lift w/ UCAs. ARE overland shell w/ ARE roof rack. 34" Falken Wildpeaks. ARB awning. Road shower. Wilco Offroad Hitchgate Solo High Clearance. LED lighting upgrades. Lockerdown console safe. Weathertech floormats. Duluth deluxe rear seat cover to go under the offroad approved car seats.... :P
    I did the LED bulb swap with the kit from Toy Tech. High and low beam. You can just loosen the housing up and slide the battery back a bit to get at it, then pull the bracket off on the washer fluid to get your hand in on the other one. Super bright, and I trust what those guys sell a bit more than Amazon, had some bad luck with China brands for interior leds. Ordered a set of the Sealight interiors and they have been great.
    Put a set of less expensive Sealight brand in my wife's Lexus, they are not quite as bright, but about 1/2 the cost, I'll see how the durability stacks up.
    Neither of them had any issues as far as being plug and play.
  27. Apr 22, 2021 at 8:27 PM
    #207
    Jkline123
    Jkline123 New Member
    Jacob
    18 TRD White
    Just looking to get an upgrade on my truck- don’t know a whole ton about this stuff but looking to change to some nice LEDs all around. Something simple to install and good quality?
    also- if I’m going to get a bumper with a light bar, will this also light up with the regular headlights? Just wondering if anyone has a suggestion on those as well!
    thanks
  28. Apr 25, 2021 at 6:31 AM
    #208
    DUKFVR
    DUKFVR New Member
    Houston & Young County TX
    2020 Cement Tundra DC SR5, Stage 1 Icon kit, LT75/60/20 Toyo AT III, Ranch Hand Midnight Bumper Replacement
    Thanks Everyone for the help & tips. Installed the auxbeam today & now will see what we have tonite.
  29. May 11, 2021 at 6:25 PM
    #209
    Jkline123
    Jacob
    18 TRD White
    How are they?
  30. May 13, 2021 at 7:26 AM
    #210
    Rockin 2nd Gen
    Jay
    Ohio
    2010 Tundra
    Depending on your state laws you will want the auxiliary switch option so you can turn the light bar on when you need it. Some states have a rule for how many lights you can run and at what candle power they put out. My light bar will light everything up so i only run it on the back roads or in dangerous weather and turn it off with on coming traffic as it will definitely blind them. I am also running the alpha rex led housings with the GTR Ultra 2 low beam which is like looking at the sun.
