LED Lightbulbs opinions/advice
Discussion in 'Lighting' started by tundra403, Mar 4, 2019.
  1. May 12, 2019 at 8:53 AM
    #121
    Mathew14
    Mathew14 New Member
    2018 c-cab 4.6 2wd TSS
    Na
  2. May 12, 2019 at 8:54 AM
    #122
    Mathew14
    Mathew14 New Member
    Na
    Heres whay i have for high vs low. Not the best pic i know.
  3. May 12, 2019 at 10:07 AM
    #123
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    You got the wrong bulbs. They don't even look like they're manufactured like a halogen bulb so I can't even give you any advice on those bulbs or performance. Everyone has been getting the Auxbeam NF-S1 bulbs in the H4 (headlight) and H11 foglight for 2014-2019. The reflector on those bulbs will be on the bottom.
  4. May 12, 2019 at 5:51 PM
    #124
    TopNotch
    TopNotch New Member
    '15 Tundra 1794
    Just read this thread and did some looking around and seems like most everyone likes the Auxbeam.
    I just ordered the fog lights mentioned here but ordered these Auxbeam bulbs for my headlights instead. I think they are slightly newer design and maybe updated LED chips???
    Auxbeam H4 Led Headlight Bulb F-S6 Series Led Headlights with 2Pcs of H4/9003/HB2/P43T Led Conversion Kit 60W 6000LM SMD Led Chips -1 Year Warranty
    I'll let you know how they work out.
  5. May 12, 2019 at 6:38 PM
    #125
    TundraTSS19
    San Antonio, TX
    Cool but no thanks for me on those either. They have fans and so they'll be noisy and the leds are not aligned light halogen bulbs are therefore I don't believe it will have a proper cut off or alignment. The nf-s1 is fanless.
  6. May 12, 2019 at 6:45 PM
    #126
    Mathew14
    Mathew14 New Member
    Na
    kbark likes this.
  7. May 12, 2019 at 6:46 PM
    #127
    Mathew14
    Mathew14 New Member
    Na
    Before i order these are the correct ones right?
    Also does anyone need any H4 T1 m
  8. May 12, 2019 at 6:50 PM
    #128
    TopNotch
    TopNotch New Member
    '15 Tundra 1794
    You do make a good point with the fan... I didn't think about that. Also I didn't realize they didn't mimic the halogen. I guess I should stay with the proven bulb.
    Order switched.
    TundraTSS19[QUOTED] likes this.
  9. May 12, 2019 at 8:34 PM
    #129
    TundraTSS19
    San Antonio, TX
    That's it
  10. May 13, 2019 at 4:13 AM
    #130
    Mathew14
    Mathew14 New Member
    Na
    So i ordered the nf-s1. With the ones i uave in righy now the t1. is there any possibility i put them in wrong fir the beams to be so offset and ny highbeams useless? Just curious
    kbark likes this.
  11. May 13, 2019 at 5:05 AM
    #131
    TundraTSS19
    San Antonio, TX
    Definitely could be a possibility. You can try to rotate them and find out. With the NF-S1, you install the bulbs with the reflector cup on the bottom.
  12. May 13, 2019 at 5:18 AM
    #132
    sundance
    sundance New Member
  13. May 13, 2019 at 5:21 AM
    #133
    TundraTSS19
    San Antonio, TX
    Beamtech are a good choice too. They're probably manufactured by the same company under a different name. The Auxbeam and beamtech look identical.
    sundance[QUOTED] likes this.
  14. May 13, 2019 at 6:32 AM
    #134
    Mathew14
    Mathew14 New Member
    Na
    I have the current ones installed with the cup on the bottom with the shiny smooth (reflective) side facing the front of the light
  15. May 13, 2019 at 6:33 AM
    #135
    TundraTSS19
    San Antonio, TX
    You may need to try a different position since those bulbs aren't built like a regular halogen bulb. I know for a fact this is how the NF-S1 orientation needs to be.
  16. May 13, 2019 at 6:39 AM
    #136
    Mathew14
    Mathew14 New Member
    Na
    I think ill just tey an return them since i already have the nf-s1 on the way lol. Tha ks for the info guys.
    TundraTSS19 likes this.
  17. May 19, 2019 at 6:23 PM
    #137
    TopNotch
    TopNotch New Member
    '15 Tundra 1794
    Just installed my Auxbeam headlights and fog lights. I have to say that the fog lights are very impressive but I'm under impressed with the headlights. I feel like the output with just the headlights is under powered and on high beam they are much better.
    I've got them oriented like the stock bulb with the metal cup on the bottom. Is that correct for this bulb? I also have my headlights set to 0 on the adjustment dial.
    Here are some pictures but they make them seem better than what I experienced.
    TundraTSS19 and Trooper2 like this.
  18. May 20, 2019 at 7:00 AM
    #138
    TundraTSS19
    San Antonio, TX
    Yep. You got it right. Looks good. I have my dial set to 1
  19. Jun 3, 2019 at 4:06 PM
    #139
    hillbillytoyo
    hillbillytoyo Just a country boy
    Daniel
    WV
    21 Limited Cement CM TRD OF
    I installed the Auxbeam headlight and fogs Saturday. Very easy using a drill driver and small screwdriver. The dogs were much harder to change than the headlights. I ended up pulling the whole fog light out the front. Great write up thanks guys.
  20. Jun 3, 2019 at 4:27 PM
    #140
    Professional Hand Model
    Hand Protectors
  21. Jun 4, 2019 at 3:09 PM
    #141
    prerunnerseth
    prerunnerseth New Member
    Apex, NC
    2015 MGM Limited 4x4
    are you guys just leaving off the rubber boot with the auxbeams?
  22. Jun 4, 2019 at 3:14 PM
    #142
    Hand Protectors
    No sir. That rubber boot is important regardless of bulb. You need to find a way to make it fit.
  23. Jun 4, 2019 at 3:48 PM
    #143
    Macreggg
    Macreggg TRD No
    Mel
    Los Angeles, CA
    2019 Tundra CM Super White
    wheels/tires suspension protection
    any recommendations for a nice yellow fog light bulb replacement?
  24. Jun 5, 2019 at 1:18 PM
    #144
    TundraTSS19
    San Antonio, TX
    If you twist the black base on the Auxbeam bulb it wills eosrste where you can mount the back base and put the boot over top of it. After that you insert the bulb and make sure the cup is on the bottom and it should lock in just fine
  25. Jun 7, 2019 at 5:24 AM
    #145
    prerunnerseth
    Apex, NC
    Duh! Thanks for this. Got them in yesterday. no problem once i removed the base and mounted it in first. I should have realized this.
  26. Jun 7, 2019 at 7:36 AM
    #146
    dsotm
    dsotm New Member
    2016 SR5 Crewmax 4x4
    How bright are the Auxbeam compared to stock halogens?
  27. Jun 7, 2019 at 7:59 AM
    #147
    kleiker0303
    kleiker0303 New Member
    Kyler
    Kansas City
    ‘16 Platinum
    Bilstein 6112 @ 1.9" Bilstein 5100's in rear Afe drop in filter Afe intake tube Afe throttle body spacer Afe catback with vibrant resonator added Stubby antenna TRD front grill Paint matched door handles Paint match mirror caps RCI skid plate All LED bulbs Undercover flex cover 20% tint all around Husky floor liners ESP under seat storage 2018 headlight mod Baja designs fog light kit 275/60/r20 falken wildpeak at3w 20x9 fuel ripper
    I've had good luck with hikari's in multiple vehicles. They are bright and seem to be well built
    omgboost likes this.
  28. Jun 7, 2019 at 10:00 AM
    #148
    TundraTSS19
    San Antonio, TX
    If you start from the beggining of this thread there have been multiple pictures provided for your viewing pleasure and decide
  29. Jun 12, 2019 at 7:38 PM
    #149
    hillbillytoyo
    Daniel
    WV
    I've encountered a problem after my Auxbeam install maybe you guys can help me out. When I turn my lights on my FM radio reception goes to pot. Has anyone else had this problem?
  30. Jun 12, 2019 at 7:51 PM
    #150
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I just installed the Hikari led. Was able to snag it during a lightning deal for under $25. Looks good and very bright. Didn’t see much glare from the stock reflectors. I’m going to adjust the driver side downward a bit. The photo is with the garage about 3 feet away.
