LED Lightbulbs opinions/advice
Discussion in 'Lighting' started by tundra403, Mar 4, 2019.
  1. Mar 4, 2019 at 1:27 PM
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    PryEU Daylight White 6000K LED Strip Lights 12V Waterproof for Auto Car Truck Boat Motorcycle Interior Lighting 12'' 30CM 3528 SMD UL Listed Pack of 4 https://www.amazon.com/dp/B00YXBEHQK/ref=cm_sw_r_cp_apa_i_SGzFCbA5MZ0FH
    tundra403[QUOTED][OP] likes this.
  2. Mar 4, 2019 at 1:46 PM
    tundra403
    tundra403 [OP] New Member
    KG
    2018 Tundra SR5 4x4 TSS Off Road - MGM
    -Internal LED Lights -Added VLED's Footwell light strip
    Awesome man! appreciate it! I like the cool white, but i may have to think about the blue.. i do like blue.
  3. Mar 4, 2019 at 5:18 PM
    bfd300
    bfd300 New Member
    Took a drive tonight on dark roads and busy roads. Not one flash and there are on the money. Plenty bright and no scatter. Buy em OP.
  4. Mar 4, 2019 at 5:23 PM
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Running Auxbeam for both Heads and Fogs until I upgrade to 2018s. No complaints. Light output was defenitely upgraded.
    From Amazon..
    Heads $32.99
    Fogs $32.99
    TundraTSS19 likes this.
  5. Mar 4, 2019 at 5:32 PM
    jwl019
    jwl019 New Member
    N.E., Louisiana
    2016 Tundra CM 4wd TSS
    Tacotunes SQ1 package Bilstein 5100's @ 1.5" plus 2 shims Toyotec Shackles at 1" Firestone Ride Rite Airbags SCS SR8's 285/70r18 Nitto Ridge Grappler's Bed Cover Tow Mirrors Windows Tinted Window Visors Weathertech Floor Mats
    Will I need anything else like a conversion kit to run these in my '16 SR5? I do not have led drl's on mine.
  6. Mar 4, 2019 at 5:35 PM
    bfd300
    bfd300 New Member
    Not at all.
    jwl019[QUOTED] and Major like this.
  7. Mar 4, 2019 at 5:40 PM
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
    Nope. Plug and play, The base is quite larger than the factory so that was a challenge but I made it work.
    jwl019 likes this.
  8. Mar 4, 2019 at 5:59 PM
    TundraTSS19
    San Antonio, TX
    Glad to hear. I've been the one that started and have been suggesting these from the start after doing a lot of research. Before I got the Auxbeam NF-S1, I had tried a highly recommended lighting dark led bulbs and they were pure trash. Light everywhere with no good pattern. These are a better alternative to dropping a ton of money for the 2018 led headlight assemblies. Get the H11 Auxbeam NF-S1 bulbs for the headlights and it will be even better. I adjusted my headlights down one click to 1.
    duece292 and bfd300[QUOTED] like this.
  9. Mar 4, 2019 at 6:38 PM
    CAM1794
    CAM1794 New Member
    Chad
    2017 MGM 1794
    @TundraTSS19 Thanks for the links and input. I just ordered these. Factory lights are terrible on my 2017 1794. Hope this is a significant upgrade!
  10. Mar 4, 2019 at 6:43 PM
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    How well do these throw compared to the stock halogens?
  11. Mar 4, 2019 at 6:47 PM
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
    SWIPE, TundraTSS19[QUOTED] and TRD-tv like this.
  12. Mar 4, 2019 at 6:52 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    im gonna throw mine in once it warms up. did u bother doing the HI's? is it worth getting those too u think?
  13. Mar 4, 2019 at 7:12 PM
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
    I'm in a 3rd Gen, we don't have seperate Hi-Beams, but for the cost...Sure why not. LOL
    TRD-tv[QUOTED] likes this.
  14. Mar 4, 2019 at 7:42 PM
    TundraTSS19
    San Antonio, TX
    If you go back to the beginning of this thread I posted pictures
  15. Mar 5, 2019 at 5:32 AM
    TundraTSS19
    San Antonio, TX
  16. Mar 5, 2019 at 6:39 AM
    tundra403
    KG
  17. Mar 5, 2019 at 9:31 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Questions.. By default it seems orientated this way.. Did you use the chuck adjustment?
    And what about the retaining wire? Lol
  18. Mar 5, 2019 at 9:45 AM
    Tierhog
    Tierhog SIG-AHOLIC
    Looks like Chuck is used as its upward by default
  19. Mar 5, 2019 at 9:55 AM
    #49
    Tierhog
    Tierhog SIG-AHOLIC
    Ok folks the chuck is a joke, only machined with one hole so since you can't rotate the ears, this is a fit or no fit scenario
  20. Mar 5, 2019 at 9:55 AM
    #50
    tundra403
    KG
    @Tierhog i havent installed these, but i am having a hard seeing what you are referring to. they should only go one way.
  21. Mar 5, 2019 at 10:05 AM
    #51
    Tierhog
    Tierhog SIG-AHOLIC
    It looks like the cup orientation is where I have the questions.. If it's only one way the tabs dictate the position
    What about getting the dust cover over the heat sink.. Lol
  22. Mar 5, 2019 at 10:08 AM
    #52
    tundra403
    KG
    @TundraTSS19 any thoughts for the guy?
    certainly there is a way to slip it on and pull it through, just gonna take some finagling.
    Tierhog[QUOTED] likes this.
  23. Mar 5, 2019 at 10:10 AM
    #53
    Tierhog
    Tierhog SIG-AHOLIC
    Looks like I either stretch the boot or remove the base from bulb and slip boot on and reinstall base.. Hmm
  24. Mar 5, 2019 at 10:13 AM
    #54
    Tierhog
    Tierhog SIG-AHOLIC
    Ok.. Looks like dust cover stretch time.. Lol
  25. Mar 5, 2019 at 10:21 AM
    #55
    Tierhog
    Tierhog SIG-AHOLIC
    Thanks for the help.. I appreciate it I'll try some more, but might return to Amazon as a no fit
  26. Mar 5, 2019 at 10:26 AM
    #56
    tundra403
    KG
    Give some of the other guys a chance/time to reply.. it has to fit. unless that specific one is a lemon.. @TundraTSS19 @Major any help for @Tierhog
    Tierhog likes this.
  27. Mar 5, 2019 at 10:26 AM
    #57
    jwl019
    jwl019 New Member
    N.E., Louisiana
    Can you take a few more pics of the housing while you have it apart? It might help @TundraTSS19 explain it more. Seems like he said you can pull the bulb apart from the black plastic base and flip it the correct way, but I may be wrong on that.
  28. Mar 5, 2019 at 10:31 AM
    #58
    Tierhog
    Tierhog SIG-AHOLIC
    The first one is showing the diameter of the heat sink in relation to the dust boot hole.. Lol.. This thing doesn't stretch that much.. Bwahahahah
    The second one gives you an idea of the receiver tab orientation..
  29. Mar 5, 2019 at 10:35 AM
    #59
    TundraTSS19
    San Antonio, TX
    If you rotate the bulb you can pull it out and separate it from the black mounting tab and then install the boot over top of it before you install the bulb into it. Rotate bulb so the metal reflector cup is on the button.
  30. Mar 5, 2019 at 10:38 AM
    #60
    TundraTSS19
    San Antonio, TX
    The bulbs fit or else I would have never suggested it. You just have to read my posts. The bulb can be rotated to unlock the black plastic mounting tab to install into the halogen housing and lock the locking ring onto it. Take the factory boot over and install it. Then you can put the bulb through the boot and lock it into the black mounting tab by rotating it with metal reflector facing the bottom. Don't forget to plug it up and done.
