Led bulb conversion
Discussion in '1st Gen Tundras (2000-2006)' started by Cummins3500, Jul 27, 2020.
  1. Jul 27, 2020 at 6:59 PM
    Cummins3500
    Cummins3500 [OP] Never finishes.....
    Logan
    So I figured I’d do a little freshinh up on the ol girl.
    I took a chance on a set of these tail lights since I like the blacked out look
    https://www.carid.com/2006-toyota-t...9691.html?parentsubmodel[]=SUBMODEL|Fleetside
    Anyways I’d like to add led bulbs. Anybody Added led bulbs to the stock housing? How’d it work out for ya?
    or should I just return the linked lights above and go with the red leds?
    Got a link for led bulbs and a good blacked out third brake light?
  2. Jul 27, 2020 at 8:34 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I run LED switch backs in my front park/turn signals and they work great. I also have them in my reverse lights. I’ve considered running them in brake lights but haven’t gotten around to it. You’ll need to get an LED resistor that can be found on Amazon for $10-$15.
  3. Jul 28, 2020 at 4:54 AM
    Cummins3500
    Logan
    Those resistors just splice in line on the tail light wiring harness? Will I need resistors on each function that gets led bulbs?
    I’d like to do led bulbs in taillights, brake lights, and turn signals in those new lights.
  4. Jul 28, 2020 at 6:21 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I replaced the old oxidized headlights on my 2002 with brand new OEM Toyota headlight housings, and then I installed a set of plug and play V.4 LED headlight bulbs. They are great, and I have experienced zero issues or complaints.
  5. Jul 28, 2020 at 6:41 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Skip the resistors and buy a LED flasher. Then you can use whatever LED you want without adding resistors. I've had good luck with the Sylvania and Phillips LEDs.
  6. Jul 28, 2020 at 7:14 AM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    You do not need to “splice” anything. Simply buy a new flasher relay (smartdiode or similar). I just did this on my truck with positive results. Here is what I used:
    I suggest these for reverse instead of what I bought:
  7. Jul 28, 2020 at 9:02 AM
    SouthPaw
    2000 Limited 4x4 AC
  8. Jul 28, 2020 at 10:26 AM
    Cummins3500
    Logan
    Sorr far all the questions fellas, but I appreciate the info. This is the first time I’m installing bulbs instead of just buying led tails and some other headlights
    so once I buy a new flasher relay that covers me for turn signals front and rear and then I’m good to add leds for all other functions? Does it matter that my truck has the drl’s?
  9. Jul 28, 2020 at 12:40 PM
    SouthPaw
    2000 Limited 4x4 AC
    LED headlights - you will need resistors. If you don't you'll most likely have your brights symbol on and no fog light function. Few guys have put them and haven't had to do anything so maybe you get lucky.
    LED bulbs (taillight/turn signal) - You will need a relay.
  10. Jul 28, 2020 at 12:43 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    The flasher will allow you to use LED turn lights front/rear, nothing else needed. It's built to function with lower resistance. The other tail lights/running lights (outside of the headlights) shouldn't be an issue.
    Stuck in the '00s likes this.
  11. Jul 28, 2020 at 3:46 PM
    Cummins3500
    Logan
    Thanks for the prompt replies, one more question and I should be ready to start ordering stuff
    where’s that flasher get installed at? In the fuse box under the hood or is it under the dash?
  12. Jul 28, 2020 at 7:23 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    @Cummins3500 Under the dash above the E-Brake Pedal, below fuse panel.
    Tundra2 likes this.
  13. Sep 8, 2020 at 8:43 PM
    2truckornot2truck
    2truckornot2truck Aspiring Truck Guy
    Felix
    TX
    2006 Tundra DC SR5 V8
    None yet! Does steering wheel cover count? :)
    What did I do wrong:
    I have a 2006 Tundra and I purchased these but they did not turn on - they had a loose fit. Here is a picture of my bulb and the LED bulb side by side.
    https://www.amazon.com/gp/product/B06XVT9D1W/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    and these:
    https://www.amazon.com/gp/product/B06WD7Z4R7/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    I was intending to replace my brake lights and turn signal lights - also actually want to replace the front marker lights and signal lights.
    Should I have gotten the 3156 bulb for rear turn? That still doesn't explain why the 3157 did not work for the brake lights...
    Here are 2 links both pointing to turn signal bulbs for the 2006 Tundra:
    https://www.superbrightleds.com/mor...040/?year=2006&make=77&model=1675&scc_id=1442
    https://www.autozone.com/electrical...led-mini-bulb-3157azevoled/770350_0_1556_2805
    Shouldn't be that hard? I did buy the relay that was recommended here.
  14. Sep 8, 2020 at 11:34 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Try removing the bulb and installing it 180° from the way you had it, LED's are polarity sensitive. If that doesn't work you may have to bend the contacts outwards a little to give you a better fit.
  15. Sep 9, 2020 at 2:40 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    This may be a difference in years but my DC had 7443 for brake lights and 7440 for turn
  16. Sep 9, 2020 at 5:39 PM
    2truckornot2truck
    Felix
    TX
    Yeah, I think I get it now! I ordered the wrong bulb size even though I thought I had checked my references. The owner's manual has a mysterious blank for the bulb size of the rear lights. Hopefully 7443 and 7440 are interchangeable since what I ordered covers both. Looks like 3157A for the front - 4 of them.
  17. Sep 10, 2020 at 3:53 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    They're not the same.
    7443 is a dual-element bulb with 4 contacts at the base, 7440 is single element with 2 contacts at the base.
  18. Sep 10, 2020 at 5:48 AM
    2truckornot2truck
    Felix
    TX
  19. Dec 16, 2020 at 4:54 PM
    Cummins3500
    Logan
    *order from diode dynamics.com
    *Tail Light LEDs for 2005-2006 Toyota Tundra (pair)
    SKU: DD0115P
    Bulb Size: 7443
    Color: Red
    Bulb Model: XP80 (510 lumens)
    *Rear Turn Signal LEDs for 2005-2006 Toyota Tundra (pair)
    SKU: DD0114P
    Bulb Size: 7440
    Color: Amber
    *License Plate LEDs for 2000-2020 Toyota Tundra (pair)
    SKU: DD0029P
    Bulb Size: 194
    Color: Pure White (5000K)
    Bulb Model: HP5 (92 lumens)
    *LED Flasher for 2000-2006 Toyota Tundra (non-DTRL)
    SKU: DD4015
    Flasher Type: CF18 SmartTap
    *Tail lights:
    https://www.protuninglab.com/alt-jh-ttu04-oe-rsm.html
    now that I have had these on the truck awhile, I will say it was pricey but definitely worth it
    alb1k likes this.
  20. Dec 16, 2020 at 7:28 PM
    tunyota
    tunyota Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
    @Cummins3500 - any photos?
    The only exterior lightbulbs I have replaced to date are the cargo lamp bulbs and reverse bulbs with the purpose to aid with visibility. I have recently finished installing all LEDs in the interior with the exception of the cigarette lighter assembly as it requires so soldering. I initially ordered SYLVANIA ZEVO 194s, 921s, and DE3425. However, given their costs, I opted for much more affordable options from Amazon when replacing the remaining interior incandescent bulbs. I have provided links to the posts with photos if you care to check them out. I am really pleased with how everything turned out. I do not think I will be replacing any other exterior bulbs.
    The driver-side footwell light was burnt out in the first link/photos, and the second link shows recently replaced/upgraded LEDs in the footwell, ashtray, ignition key ring, center control/panel assembly, and glove compartment.
    https://www.tundras.com/threads/greetings-from-santa-barbara-county-ca.66579/#post-1732045
    https://www.tundras.com/threads/instrument-cluster-screw-up.77807/#post-2022484
  21. Dec 17, 2020 at 4:30 AM
    Cummins3500
    Logan
    @tunyota, I’ll see what I can do this evening for some photos
    the 3rd brake light is next. I had a blacked out one order but they can’t get me ship date so I’m gonna try some nightshade spray and leds. Then on to the interior.
    I’ll give your linked threads a look, I appreciate it :thumbsup:
  22. Dec 17, 2020 at 4:45 AM
    Professional Hand Model
    Hand Protectors
    The cig lighter light bulb is doable without complete removal or soldering. Access is from ashtray and you need good hand skills and proper tools otherwise you’ll mangle it. Check my build page.
    tunyota[QUOTED] likes this.
  23. Dec 17, 2020 at 5:27 PM
    Cummins3500
    Logan
    Getting a decent picture of the tails lit up is proving rather difficult with an iPhone.
    can I just tint the inside of my 3rd brake light? so I don’t have to fool with clear and stuff on the outside
    @Professional Hand Model Hats to you on that one sir, I’d like to do my whole interior
  24. Dec 17, 2020 at 6:04 PM
    tunyota
    @Professional Hand Model - Thanks for commenting. Where can I find a link to your build page? I am not seeing it when reviewing your profile etc. I am most familiar with accessing this bulb as I have disassembled and reassembled the upper and lower dash sections numerous times. Removing the ashtray and rotating the cigarette lighter assembly 90 degrees clockwise is the easiest way to access without removing the center console as you noted. I would be interested to see how you were able to remove and replace the incandescent bulb from the plastic housing for which the bulb is a part of. I can confirm the bulb is soldered to the (2) pins that protrude out of the opposite side of the plastic housing.
  25. Dec 17, 2020 at 6:54 PM
    tunyota
    @Cummins3500 just wanted to share if you weren't already aware "Blacked-out tail lights are illegal in all 50 states... This is for safety purposes. Other drivers need to be able to see when you’re braking, coming to a stop, and getting ready to turn. Having tail lights that are clearly visible is crucial to avoiding accidents." I can speak from experience as I was rear-ended by another driver in part because I had blacked out taillights and as a result totaled my 1996 Impala SS. Had they not been blacked-out/heavily tinted the driver most likely would have been able to see better thus avoiding a collision. Hard lesson learned.
    Stuck in the '00s and Tundra2 like this.
  26. Dec 17, 2020 at 11:57 PM
    tunyota
  27. Dec 18, 2020 at 12:16 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    This is what I did also, but yours is a lot cleaner than my mangled mess. I took after @bmf4069 on that job. :rofl:
  28. Dec 18, 2020 at 3:35 AM
    Hand Protectors
  29. Dec 19, 2020 at 4:20 PM
    Cummins3500
    Logan
    @tunyota, good work, I’m not sure how comfortable I am takin my dash apart lol. Looks good though
    also, my tails aren’t the blacked out hard covers, they’re a smoked lenses. I put the brightest led bulbs you can get from diode dynamics. They actually look brighter than stock. Tn law just mentions a red bulb in tail lamps, and brake light position. Ga however, they have a catch all phrase that they could write me on if they want per a buddy mine that works for Cobb county. He said the odds of me getting wrote are pretty slim. I’d like to tint my third brake light to match. It also will get the brightest diode dynamics bulbs.
    tunyota likes this.
