Leaking axle seal
Discussion in '1st Gen Tundras (2000-2006)' started by jbar322, Jul 6, 2020.
  1. Jan 15, 2022 at 3:17 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  2. Jul 5, 2024 at 6:28 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Anyone know if this is the same depth for the pass side of a 2nd gen for this seal
  3. Jul 6, 2024 at 1:33 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Timmy shows the process of tapping in the passenger side seal and measuring (although on a 3rd gen T4R). Have done this on 03 Tundra with aftermarket seal at right depth that leaked then replaced with Toyota seal (that appeared to have a very minor lip difference) at appropriate depth measured by caliper that didn't leak but also verified front differential and actuator breathers were clear.
  4. Jul 6, 2024 at 11:02 AM
    MEWaters
    MEWaters New Member
    Maine
    I tapped into same depth as oem seal with NAPA and I’m still leaking. Small drops collecting on the diff housing vs leaking like a sieve. The old seal was destroyed so I’m still in a better place than I was. Will have to get a Toyota seal and redo but I can at least drive it right now.
    Don’t burn me at the stake. My 2nd gen is 2UZ :bananadead:
    FrenchToasty likes this.
  5. Jul 6, 2024 at 11:53 AM
    shifty` Inside his chest they found ten thousand pencils
    Is it possible your diff breather isn’t working, so you’re building up excess pressure inside the axle housing?
    MEWaters[QUOTED] and ToyotaDude like this.
  6. Jul 6, 2024 at 12:44 PM
    ToyotaDude
    ToyotaDude Member
  7. Jul 6, 2024 at 5:47 PM
    MEWaters
    MEWaters New Member
    Maine
    Positive. The front diff breather has been moved just like the rear
